    3 different Alexa modules, which one is the best?
    32 Posts 10 Posters 29.3k Views 12 Watching
    • L
      lucallmon @rchase
      @rchase it depends on what you want to do. Good luck getting MMM-Mirrormirroronthewall to actually work. Have you looked at the github repository? There is no clear installation instructions. Your best bet is to install AlexaPi separate from MM then install the module MMM-AlexaPi.
      rchaseR 1 Reply Last reply
      • rchaseR
        rchase @lucallmon
        @lucallmon ah bummer I hope I can get it to work with all the features it says it has
        To me this Alexa module is the only reason Im interested in Magic Mirror, a mirror that shows a clock and weather info is kind of neat but doesnt justify its cost at all to me, however being able to turn my Belkin Wemo lights on/off with Alexa commands, being able to do quick google searches, get answers to short fact based questions by voice, pull up a youtube video with a voice command, thats where the magic mirror makes sense to me, those are the features im looking for
        If anyone reading this is using alexa as i described i would like to hear your experience with it and if it is working as you expected!
        L 1 Reply Last reply
        • T
          The_Mingler
          @rchase
          I have alexa on my mirror and I used MirrorMirrorOnTheWall. It works well once you get through the oddly non-linear instructions. You have to do one thing on one page and make sure you did another group of to-do’s on another page and so on and in the end hope you hit everything. All in all though I find it very useful as I think Alexa is a powerful platform to have at your disposal. You can enable the full library of Alexa apps (and even your own custom Alexa apps in development mode). I modified the MirrorMirrorOnTheWall app (an awful lot) to have a lot more functionality and a little more practicality. In doing so I realized that when you do I don’t have experience with the other Alexa ports to the MM but with MMonTW I felt that every time I wanted to add even some basic functionality there were a ton of steps. I have to change the intent schema, then the invocation utterances, then the function that is triggered, then push it to the registered Iot device (which is your pi from when you were setting it up), but then you need to make sure you are subscribing to that specific topic there. It can be cumbersome but all in all when you know your way around it and you have an amazon alexa in your mirror it is pretty cool. I’d say go for it. Though its been months since I did mine and I am preparing for a 3000 mile move so I might not be as much help as I’d like to be if you get stuck.
          • rchaseR
            rchase @The_Mingler
            @The_Mingler Great this is exactly what I was hoping to hear, thanks! Have you ever pulled up a Youtube video through an Alexa command and does that work as expected? That sounds like one of the coolest things to me
            T 1 Reply Last reply
            • T
              The_Mingler @rchase
              @rchase
              Yeah I thought that was one of the more attractive features of it. It was cool! I had to make a few tweaks to clear the screen afterwards though. It always pulls the same video for a search term (the first video in the search results), but this can be fixed programmatically to pull a random video in the top 5 or 10 results, or a specific video number in the results (but for that you need to change the utterances to accept a number as well and pass that into the function). But yeah, it was cool! One recommendation is read the instructions, and read them again. If you are like the rest of us on here, you kinda read and then you sorta skip to the numbered instructions and go from there. You need to read the paragraphs and the forum and they will tell you everything you need to know. But yeah it is pretty awesome.
              Oh yeah, in order to have Alexa active for the MMonTW to work properly, there are three scripts (including an authentication one with Amazon) that need to be running. I usually start these up manually and haven’t looked into auto-starting them upon pi startup (like most do with their mirror). Hopefully that is possible.
              • rchaseR
                rchase @The_Mingler
                @The_Mingler Nice! Alright that sounds pretty sweet though.
                Anyone successfully controlled some Belkin WeMo stuff from Alexa? I feel like it wont be too hard to get this part figured out, since WeMo claims its supported anyways, I just dont know if there is extra configuration running from an RPI vs a normal echo/dot
                • L
                  lucallmon @rchase
                  @rchase check out my MM build here and you can see how mine works. If you want to try and learn what you can about the MirrorMirrorOnTheWall module, try here but good luck.
                  • romainR
                    romain
                    Well, good luck. I try to make Alexa work from quite sometime now and I still getting any result. I tryed both MMM-Alexa and MMM-MirrorMirrorOnTheWall . Both module have incomplete instruction to me. They explain how to setup some stuff but not how to test it. So… even after following all the instruction I could find, I just end up stupidly talking in my mic with no answer or whatever. And no instruction on what should happen. How to know if AlexaPi is correctly installed ? no clue. How do I know that the module is well config within the mirror ? I guess you’ll know when you figure it out by yourself.
                    I would like a step by step video from someone doing it to see if my “issues” are hardware related or software related (I mean, if the issue is my mic not being picked up or if my config is wrong.) If I could “see” someone doing it, I could see what I am doing wrong.
                    Anyway. Best of luck
                    B M 2 Replies Last reply
                    • L
                      lucallmon
                      I have installed AlexaPi separate from MM 3 times with success each time. I feel like the AlexaPi I’m not sure where you guys are getting hung up. I’d be willing to walk you through it when I have time. I can do that on gitter.
                      johnnyboyJ romainR 2 Replies Last reply
                      • johnnyboyJ
                        johnnyboy @lucallmon
                        • romainR
                          romain @lucallmon
                          @lucallmon Great, what is your timezone ? when am I the most likely to find you ? Even though you not available to gitter us your magic right now, I’ll like to be ready when you are
                          • L
                            lucallmon @romain
                            @romain I’m US eastern.
                            • mahabub99M
                              mahabub99
                              @rchase said in 3 different Alexa modules, which one is the best?:
                              I think MMM-Alexa by sakirtemel is the best.
                              Because it’s pretty good from other.
                              https://annabellaw.com/
                                borrigan @romain
                                @romain said in 3 different Alexa modules, which one is the best?:
                                Hi @romain , did you get to test all modules and conclude which one is the best? I am totally lost with MMM-Alexa. I installed it and can see the yellow square in the MM interface but I don’t know how to get it working. Documentation says:
                                " You can easily develop your own module and control this module or get notified about events happening"
                                But it does not say how to develop this module :(
                                Any clues will be greatly appreciated.
                                romainR 1 Reply Last reply
                                • romainR
                                  romain @borrigan
                                  @borrigan Hello. I end up successfully setting MMM-AlexaPi and MMM-alexa.
                                  they both have adventages and inconvinient
                                  -MMM-AlexaPi
                                  • This module isn’t a stand alone module. You need to install AlexaPi on you pi ( https://github.com/alexa-pi/AlexaPi )
                                  • This module is ONLY to show the status of AlexaPi. And this is AlexaPi that allow you to talk to Alexa. Meaning you don’t need the mirror at all to use it. But it’s neat because you can “see” what’s happening. Also Alexa saying “yes” when you say her name.
                                  • It might or might not be easy to setting up. Some people won’t have any issue using it by following the setup instruction and other would have to tweaks some things.
                                  • slower than MMM-alexa
                                  -MMM-alexa
                                  • It is a stand alone module. Meaning you just need this module to talk to Alexa.
                                  • The square indicate you the status . yellow is bad configuration if I recall correctly. Red is ready to listen. green is listening.
                                  • It is not activated by voice. You need either a button or to send the right notification to the module to make Alexa listen to you.
                                  • It seem to not answer as much as MMM-AlexaPi
                                  • You need to add https://sakirtemel.github.io/MMM-alexa/ to the allow return URL in your avs security settings of your device . And need to generate the first token by going in that first url and enter the requested information
                                  • faster than MMM-AlexaPi
                                  in both case I had to tweak some of my sound configurations files so my microphone is picked up and the output is my speaker.
                                  Because MMM-Alexa needed to be activated manually or by another module (and the fact it seem to provide less answer) I think MMM-AlexaPi is better. Even though AlexaPi seem a bit slower to answer. To trigger MMM-Alexa I used the voicecontrol module (it’s a module that convert voice into notification. I set up the word “Alexa” to send the right notification to mmm-alexa) but the voicecontrol module seem to have a loooooooooot of false positive. It was activated way to much even if I didn’t talk sometime.
                                  I didn’t successfully made mirrormirroronthewall worked though (I might try again later. I didn’t tryed since I made the other two works)
                                  I think mirrormirroronthewall is probably the best module of all three since is suppositivly allow you to do more than the other two that only allow you to ask question to alexa and get answers from it.
                                  as for the
                                  You can either use an already existing moduel like “voicecontrol” to do that.
                                  or developping something yourself. to do that:
                                  You can for example take as a template the helloworld module in the ~/MagicMirror/modules/default as a template . copy/past it in the ~/MagicMirror/modules , rename the folder to something else. let’s say “toto” as an example, then rename the file inside it to match that name. helloworld.js should now be toto.js . now open the toto.js and replace all the hello words by toto.
                                  Then delete the text: "Hello World!" and the wrapper.innerHTML = this.config.text; since you don’t need to display anything.
                                  Now you can write this.sendNotification('ALEXA_START_RECORDING', {}); where was the wrapper.innerHTML = this.config.text;
                                  And that send the notification to start recording what you are saying to mmm-alexa. However that example will only work once.
                                  If you never code something before, I don’t recomand you to do the developping of a module like this yourself. It’s better to use an already existing module.
                                  /!\ if your sound configuration isn’t good, you might not be able to use voicecontrol and mmm-alexa in the same time.
                                  Explaining the sound configuration here would be pointless since you might not have those issue.
                                  johnnyboyJ 1 Reply Last reply
                                    borrigan
                                    Thank you very very much @romain ! I will go for AlexaPi with MMM-AlexaPi. I spent all yesterday trying to set it up, and I will continue today, your input is very valuable. Just a few newbie, extra questions:
                                    • AlexaPi service, when running, is “Always On”? It is always listening? How to test it directly without having integrated with MMM-AlexaPi Yet?
                                    • Where can the activation word be configured? If I just say “Alexa”, should it work?
                                    • Finally, I spent hours troubleshooting the microphone. It is a very standard Logitech Microphone. I just could not get it working.
                                    Here are:
                                    Result from >lsusb command:
                                    pi@raspberrypi:~ $ lsusb
                                    Bus 001 Device 006: ID 17ef:6019 Lenovo
                                    Bus 001 Device 005: ID 04b3:3025 IBM Corp. NetVista Full Width Keyboard
                                    Bus 001 Device 004: ID 046d:0a03 Logitech, Inc. Logitech USB Microphone
                                    Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
                                    Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
                                    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                                    result from the > arecord -L command:
                                    pi@raspberrypi:~ $ arecord -L
                                    null
                                    Discard all samples (playback) or generate zero samples (capture)
                                    pulse
                                    PulseAudio Sound Server
                                    sysdefault:CARD=Microphone
                                    Logitech USB Microphone, USB Audio
                                    Default Audio Device
                                    front:CARD=Microphone,DEV=0
                                    Front speakers
                                    surround21:CARD=Microphone,DEV=0
                                    2.1 Surround output to Front and Subwoofer speakers
                                    surround40:CARD=Microphone,DEV=0
                                    4.0 Surround output to Front and Rear speakers
                                    surround41:CARD=Microphone,DEV=0
                                    4.1 Surround output to Front, Rear and Subwoofer speakers
                                    surround50:CARD=Microphone,DEV=0
                                    5.0 Surround output to Front, Center and Rear speakers
                                    surround51:CARD=Microphone,DEV=0
                                    5.1 Surround output to Front, Center, Rear and Subwoofer speakers
                                    surround71:CARD=Microphone,DEV=0
                                    7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
                                    iec958:CARD=Microphone,DEV=0
                                    IEC958 (S/PDIF) Digital Audio Output
                                    dmix:CARD=Microphone,DEV=0
                                    Direct sample mixing device
                                    dsnoop:CARD=Microphone,DEV=0
                                    Direct sample snooping device
                                    hw:CARD=Microphone,DEV=0
                                    Direct hardware device without any conversions
                                    plughw:CARD=Microphone,DEV=0
                                    Hardware device with all software conversions
                                    Log from AlexaPi
                                    ● AlexaPi.service - Alexa client for all your devices
                                    Loaded: loaded (/usr/lib/systemd/system/AlexaPi.service; enabled)
                                    Active: active (running) since Mon 2017-04-24 10:59:14 CDT; 7s ago
                                    Docs: https://github.com/alexa-pi/AlexaPi/wiki
                                    Main PID: 1626 (python)
                                    CGroup: /system.slice/AlexaPi.service
                                    ├─1626 /usr/bin/python /opt/AlexaPi/src/main.py --daemon
                                    ├─1638 /usr/bin/pulseaudio --start --log-target=syslog
                                    └─1657 sox -q /opt/AlexaPi/src/resources/hello.mp3 -t alsa default vol -6 dB pad 0 0
                                    Apr 24 10:59:20 raspberrypi pulseaudio[1638]: [pulseaudio] module-udev-detect.c: Tried to configure /devices… 10s
                                    Apr 24 10:59:21 raspberrypi python[1626]: Exception in thread Thread-1:
                                    Apr 24 10:59:21 raspberrypi python[1626]: Traceback (most recent call last):
                                    Apr 24 10:59:21 raspberrypi python[1626]: File “/usr/lib/python2.7/threading.py”, line 810, in __bootstrap_inner
                                    Apr 24 10:59:21 raspberrypi python[1626]: self.run()
                                    Apr 24 10:59:21 raspberrypi python[1626]: File “/usr/lib/python2.7/threading.py”, line 763, in run
                                    Apr 24 10:59:21 raspberrypi python[1626]: self.__target(*self.__args, **self.__kwargs)
                                    Apr 24 10:59:21 raspberrypi python[1626]: File “/opt/AlexaPi/src/alexapi/triggers/pocketsphinxtrigger.py”, …hread
                                    Apr 24 10:59:21 raspberrypi python[1626]: inp = alsaaudio.PCM(alsaaudio.PCM_CAPTURE, alsaaudio.PCM_NORMAL, …ce’])
                                    Apr 24 10:59:21 raspberrypi python[1626]: ALSAAudioError: Input/output error [front:CARD=Microphone,DEV=0]
                                    Hint: Some lines were ellipsized, use -l to show in full.
                                    Thank you so much for your help, I don’t mean to take too much from your time but I am really frustrated :(
                                    Gerardo
                                    Mexico City
                                    • romainR
                                      romain @borrigan
                                      @borrigan
                                      you should hear “hello” when it start and then if you say Alexa you should hear “yes” then you can ask a question. It is always listening.
                                      A little tips for you, before using the service, try to run AlexaPi yourself. It provide you more debugging info that way.
                                      To do it, first desactivate the service with the terminal by writing sudo systemctl stop AlexaPi.service; sudo systemctl disable AlexaPi.service (you can reactivate later by doing sudo systemctl enable AlexaPi.service).
                                      Then you can run AlexaPi yourself by writing in the terminal /opt/AlexaPi/src/main.py -d (If you you putted it on that location anyway).
                                      in the yaml file in /etc/opt/AlexaPi/config.yaml there is a section pocketsphinx: (this is what is use to detect words I believe). in that section you have a key phrase: with "alexa" as a value. you can simply change the word to another word. Do not choose an over complicated one though, I think pocketsphinx try to guess what it supposed to sound like based on the spelling so if you choose a word not in English it might not guess correctly. You shoudl let alexa untill you get it to work though, because we know that one work for sure. You can test other word later.
                                      I am no expert in sound but I going to try to help you.
                                      First, I rather have the output from arecord -l rather than arecord -L . the later give to much information to my understanding.
                                      The output of my arecord -l look like this:
                                      pi@raspberrypi:~ $ arecord -l
                                      **** List of CAPTURE Hardware Devices ****
                                      card 1: Device [USB Audio Device], device 0: USB Audio [USB Audio]
                                        Subdevices: 1/1
                                        Subdevice #0: subdevice #0
                                      I can see it’s “card 1” and “device 0” . that’s what I am interesting about.
                                      then, my aplay -l give me
                                      pi@raspberrypi:~ $ aplay -l
                                      **** List of PLAYBACK Hardware Devices ****
                                      card 0: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA]
                                        Subdevices: 8/8
                                        Subdevice #1: subdevice #1
                                        Subdevice #2: subdevice #2
                                        Subdevice #3: subdevice #3
                                        Subdevice #4: subdevice #4
                                        Subdevice #5: subdevice #5
                                        Subdevice #6: subdevice #6
                                        Subdevice #7: subdevice #7
                                      card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 ALSA [bcm2835 IEC958/HDMI]
                                        Subdevices: 1/1
                                        Subdevices: 1/1
                                      I using the default speaker output, which is the bcm2835 Alsa device which is “card 0” and “device 0”
                                      Knowing that you can test if your device working by doing the following:
                                      meaning you should be able to do a aplay -D hw:0,0 /usr/share/sounds/alsa/Front_Center.wav to test your speaker where “hw:0,0” (you could also put “plughw:0,0”) is your output device. Not sur what does “hw” and “plughw” mean, but the numbers are the card number and the device number. 0,0 in my example (remember the aplay -l above)
                                      this will use the vlc handler i beleive. You can test it the same way with play instead of aplay for the sox handler.
                                      you can test your michrophone in the same way by doing arecord -r 48000 -f S16_LE -D hw:1,0 -d 5 test.wav this will tell to record with the device hw:1,0 (in my example the card 1, device 0) for 5 second at a rate of 48000Hz and as S16_Le type (not sure what that is) and the result will be put in a file name test.wav. You can then play or aplay that file to see if the recording whent well.
                                      If you manage to make those command work. In the /etc/opt/AlexaPi/config.yaml there is a section sound: with a key “input_device:” and a key “output_device:” . Both of those key have for value “default” . for the output it’s easy, the default is the system defautl output which is hw:0,0 in my example. so you can let default or put “hw:0,0” instead if you want to use that output like me.
                                      The tricky part is the input. The input is your michrophone, but there is no “default” michrophone in the pi right ? so the chance AlexaPi understand what you are talking about are prett slim in my opinion.
                                      But when I wrote “hw:1,0” or “plugwh:1,0” instead of default , I had an error. For some reason it didn’t wanted to take that value. That’s when trickery was needed for me. I’m sure some people hadn’t to do that but I did.
                                      I creat a alsa configuration file name “asound.conf” with the following in it :
                                      pcm.myTest {
                                          type dsnoop
                                          ipc_key 816357492
                                          ipc_key_add_uid 0
                                          ipc_perm 0666
                                          slave {
                                              pcm "hw:1,0"
                                              channels 1
                                      pcm.!default {
                                              type asym
                                              playback.pcm {
                                                      type plug
                                                      slave.pcm "hw:0,0"
                                              capture.pcm {
                                                      type plug
                                                      slave.pcm "myTest"
                                      This overrite what is the “default” configuration.
                                      type asym mean my playback and default arn’t on the same sound device.
                                      the playback.pcm describe what is my output device. In my example you can see i putted “hw:0,0” because I use the default output.
                                      the capture.pcm describe the input device (microphone). I put “MyTest” as a name which is describe above in the file (the name isn’t very explicit but I was testing and never changed it >.> )
                                      I am not going to enter in the detail for the myTest thing, but basically, it’s tell that the michrophone can be use in multiple application at the time and that it is the “hw:1,0” (remember the arecord -l thing above in the post)
                                      This asound.conf file should be put in the /etc/ folder.
                                      Well. That’s it. That’s what I had to do to make my microphone work for AlexaPi. Adapt this to your own devices and it might work like me.
                                      Remember to test it whitout the service first and when that’s work you activate the service and see if it still work or not. and if not we’ll try to understand why.
                                      B UnboredU 3 Replies Last reply
                                      Reply Quote 2
                                      • johnnyboyJ
                                        johnnyboy @romain
                                          borrigan @romain
                                          @romain thank you very very much for all this feedback. I was definitely missing some pieces of the puzzle. I will try this again today and post my findings here. Have a great day!
                                          • romainR
                                            romain @johnnyboy
                                            @johnnyboy I struggle because of this @johnnyboy at first. But the lambda service is working both with us and ireland (west-eu or eu-west. don’t remember exactly now).
                                            I end up have skill that was working. On the amazon interfaces anyway by choosing that instead of us. (even though I’m in france. I had no error anymore on the amazon test aera)
                                            I had to change the hard coded region in the code though (easy fix).
                                            I think I had no more error at the end (don’t remember for sure). But nothing was happening when I talked (maybe it was again a microphone issue. Not really sure about that)
                                            I also did not understood how to use the npm start dev correctly at that time so maybe I would be able to do a better job at finding the issue now.
                                            Maybe I try today, maybe I never try again. we’ll see (it’s not my raspberry pie I using so I am limited in when I can use it. So I rather do what I am ask to first before trying again)
