    Wifi isolation for pir sensor
    7 Posts 2 Posters 3.6k Views 2 Watching
    • johnnyboyJ Offline
      johnnyboy @vicdilou
      • V Offline
        vicdilou @johnnyboy
        @johnnyboy the sensor will be about sixty centimeters of raspberry
        johnnyboyJ 1 Reply Last reply Reply Quote 0
          johnnyboy @vicdilou
          • V Offline
            vicdilou @johnnyboy
            @johnnyboy I used several cables
            I have to put all the cables in the ferrite bead ?
              johnnyboy @vicdilou
              • V Offline
                vicdilou @johnnyboy
                @johnnyboy There is no break in connection I think, I use this to test the sensor and it says always “Motion detected”.
                from gpiozero import MotionSensor
                import time
                pir = MotionSensor(4)
                while True: #repeat this forever
                    if pir.motion_detected: # if motion is detected print the message
                        print("Motion detected!")
                    if not pir.motion_detected: # if no motion is detected print the message
                        print("No motion detected!")
                    time.sleep(1)
