    Wifi isolation for pir sensor
    7 Posts 2 Posters 3.7k Views 2 Watching
    • V Offline
      vicdilou @johnnyboy
      @johnnyboy the sensor will be about sixty centimeters of raspberry
      johnnyboyJ 1 Reply Last reply Reply Quote 0
      • johnnyboyJ Offline
        johnnyboy @vicdilou
        • V Offline
          vicdilou @johnnyboy
          @johnnyboy I used several cables
          I have to put all the cables in the ferrite bead ?
            johnnyboy @vicdilou
            • V Offline
              vicdilou @johnnyboy
              @johnnyboy There is no break in connection I think, I use this to test the sensor and it says always “Motion detected”.
              from gpiozero import MotionSensor
              import time
              pir = MotionSensor(4)
              while True: #repeat this forever
                  if pir.motion_detected: # if motion is detected print the message
                      print("Motion detected!")
                  if not pir.motion_detected: # if no motion is detected print the message
                      print("No motion detected!")
                  time.sleep(1)
