    Alexapi - Any UK Users on here?
    7 Posts 2 Posters 3.4k Views 2 Watching
    • johnnyboyJ
      johnnyboy
      • michael24hM
        michael24h
        im in london UK
        johnnyboyJ 1 Reply Last reply Reply Quote 0
        • johnnyboyJ
          johnnyboy @michael24h
          michael24hM 1 Reply Last reply Reply Quote 0
          • michael24hM
            michael24h @johnnyboy
            @johnnyboy
            I in Herne Hill SE24.
            yeah no problem mate, I will check which one Bring up mic. icon on to my mm-clock. and let you know. I did run in to same problem. MMM-AlexaPi did not bring mic. icon as expected.
            • johnnyboyJ
              • michael24hM
                michael24h
                Hi
                I did restore my sd card from backup. and start instoling modules. backup only have default modules on it and alexa. Mic icon did not show up until I installed MMM-IMDBComingSoon. Pretty sure last time when I reinstall completely my mm-clock, I have installed something else, different module. I’m not sure which one. Anyway mic show up after i add this module.
                Each time installing new module I reboot device.
                I’m not too sure how helpful this can be for you, also it’s no make any changes the any thing except instilling modules and Adding the module to my config/config.js until mic icon show up.
                			module: 'MMM-Remote-Control',
                		    // position: 'bottom_right',
                			//ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "......ip....address..."],
                			ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "....ip......address...."],
                			module: 'alert',
                			module: "updatenotification",
                			position: "top_bar"
                			module: 'calendar_monthly',
                			position: 'top_left',
                			module: 'currentweather',
                			position: 'top_right',
                				locationID: '......................',  //ID from http://www.openweathermap.org
                				appid: '.........................'
                			module: 'clock',
                			position: 'top_center',
                				displayType: 'analog',
                				clockBold:	'true',
                				analogSize:	'240px',
                				analogFace: 'face-008',
                				secondsColor: '#bf1a1a',
                			module: 'weatherforecast',
                			header: 'Weather Forecast',
                				locationID: '............',  //ID from http://www.openweathermap.org
                				appid: ......................................',
                				onlyTemp: true
                			module: 'MMM-SystemStats',
                			position: 'bottom_right', // This can be any of the regions.
                			classes: 'small dimmed', // Add your own styling. Optional.
                				updateInterval: 10000,
                				animationSpeed: 0,
                				//header: 'System Stats', // This is optional
                			module: 'MMM-AlexaPi',
                			position: 'lower_third',
                				alexaTimeout: '15000',
                				alexaHBTimeout: '10000',
                            // If no config is set, defualt values are used
                			module: 'MMM-Globe',
                			position: 'bottom_left',
                			style: 'geoColor', // natColor, geoColor, airMass, fullBand, europeDiscNat, europeDiscSnow, centralAmericaDiscNat
                			imageSize: 175,
                			updateInterval: 10*60*1000
                            module: 'MMM-IMDBComingSoon',
                            header: "Upcoming Films",
                                apikey: "......................................................",
                                reloadInterval: 8 * 60 * 60 * 1000, //8 hours
                                dataSwapInterval: 60 * 1000, //1 min
                                animationSpeed: 1.5 * 1000 //1.5 secs
                johnnyboyJ 1 Reply Last reply Reply Quote -1
                • johnnyboyJ
