    custom CSS clock module
    2 Posts 2 Posters 2.8k Views 2 Watching
      PointPubMedia
      Hey guys…
      Would like to do some custom CSS for the clock module, but just for the time.
      Currently HH and MM are the same size and SS is smaller! I would like to have the MM bigger than the HH!
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @PointPubMedia
        @PointPubMedia the hour and the minute are in the same div which makes it not possible to do it just in css, but
        there is a config option which adds a wrapper around the minutes, which is perfect for this task.
        the selector would be probably something like this:
        .clock div.time.bright.large.light span.bold {
          //set the font size here
        therefore you also have to add clockBold: true to the config
        if you dont like the bold effect you can overwrite it as well where you change the font size
