    No calendar or News feed?!?!?
    11 Posts 3 Posters 9.1k Views 2 Watching
    • T
      TheSwissGuy
      What happens when you call the urls from your calendar und news feed out of the config.js file directly in a browser? Do you see any content?
      • E
        ellercom
        They work fine. I have checked to make sure they were correctly formatted and everything.
        • T
          TheSwissGuy
          were you using the browser on your raspi or one on another computer? because both modules connecting to the internet are not working, this could indicate a problem with the internet connection or proxy
          • E
            ellercom
            Connecting to pi in another location entirely on a different internet connection. Browsers on both ends show the same.
            • T
              TheSwissGuy
              what urls are you using? the javascript script code says that when no news items are found, the Loading… is shown.
              • E
                ellercom
                Tried with both the default and a local feed. both had content in their xml when i checked manually. and the private google calendar link that i am using is processing ical correctly when i checked also when testing i was getting responses from the weather api and it was throwing a non valid api error so i disabled those modules to help clean up console activity
                • KirAsh4K
                  KirAsh4 Moderator
                  Did you make any changes to your config.js file (like most of us do)? If so, can you try running the default config.js that comes with MM? Rename your current config.js to something else, and rename the config.js.sample to config.js. Reload the mirror (not just refresh your browser, reload the whole node process on the rpi.)
                  With the default config, you should get an error on the weather modules, but the others should work. Please report back.
                  • E
                    ellercom
                    It does it even with the default config. That is when i first noticed it and thought well maybe those feeds are down so i changed them and still the same. got the error with weather like i was supposed to. I have done a reinstall of everything 3 different times now all the way from reinstalling os up.
                    • T
                      TheSwissGuy
                      And did you check the /home/pi/.pm2/logs log-files?
                      • KirAsh4K
                        KirAsh4 Moderator
                        Typing in 'pm2 logs' will display those specific logs in a nicely formatted display.
                        @ellercom, when you tied the default config, did you actually restart the MM process completely? You said you’re running it as a serveronly, so have you killed the process and restarted it? Does the default config also jst display ‘Loading…’?
