    Installation Error - Electron installer issue
    9 Posts 4 Posters 5.8k Views 4 Watching
    • K Offline
      kristofvdo
      Dear community,
      I’m trying to use the automatic installer on a new rasp pi 3, update jessie raspbian version ( no other packages installed ) but I’m getting the same error over and over again.
      The installation always fails at the point of post install of Electron ( see screenshot below )
      Cloning MagicMirror Done!
      module.js:442
          throw err;
      Error: Cannot find module '/root/MagicMirror/node_modules/electron-prebuilt/install.js'
          at Function.Module._resolveFilename (module.js:440:15)
          at Function.Module._load (module.js:388:25)
          at Function.Module.runMain (module.js:575:10)
          at startup (node.js:160:18)
          at node.js:456:3
      At the end, the installation stops with the following error:
      npm ERR! electron-prebuilt@1.2.1 postinstall: `node install.js`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the electron-prebuilt@1.2.1 postinstall script 'node install.js'.
      npm ERR! If you do, this is most likely a problem with the electron-prebuilt package,
      npm ERR! not with npm itself.
      npm ERR!     node install.js
      npm ERR!     npm bugs electron-prebuilt
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!     npm owner ls electron-prebuilt
      Anyone some thoughts they want to share?
      Edit from admin: Please use Markdown on code snippets!
        Corvis1984
        Same error on my side … I hoped to find a solution here but it looks like no one answered …
          amanzimdwini
          I have the same error - running it on a headless Pi3 (ie I Putty in from elsewhere and monitor the output from elsewhere too).
          I have been told that I should not run MM from the CLI, but rather that "The application needs to be started while the GUI-environment is running.’
          Can you please confirm if you are running ON THE PI directly or if you SSH’ed in?
            Corvis1984 @amanzimdwini
            @amanzimdwini
            I’m running directly on the PI !
              Bangee Module Developer
              Hey there!
              You should not install MagicMirror as Root in the /root directory.
              check out this:
              https://forum.magicmirror.builders/topic/259/installing-mm2/10
              I think it is the same issue.
              @Bangee said in Installing MM2:
              as I c, you’ve installed your MagicMirror in the /root directory.
              I’m not sure if this is working so far.
              Try to install everything as pi and not as root in the /home/pi directory and let us know what happend.
              try whoami -> pi
              update your distribution with sudo apt-get update && sudo apt-get upgrade
              then cd /home/pi or only cd
              and install again: curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash
                Corvis1984 @Bangee
                @Bangee
                Thanks for your answer, I’m going to try that right now !
                  how was it? :-)
                    amanzimdwini @Corvis1984
                    @Corvis1984
                    I found this one
                    https://forum.magicmirror.builders/topic/236/complete-setup-tutorial/2
                    and it worked like a charm… (and it it so detailed even I could not mess it up)
                    On top of that, it is lean and made my WiFi FINALLY work too. Now all I need is the toaster attachment to my Pi
                    Best of luck!
                      Corvis1984 @Bangee
                      @Bangee
                      Perfect ! I installed MM2 as PI user and it works now !
                      Thanks for your help
