    MMM-PIR-Sensor with RelayPin and execute script
    9 Posts 3 Posters 5.1k Views 3 Watching
      Blackmirror @nogE
      @nogE
      The MMM-PIR-Sensor module have not work at me.
      So i make a new datei this the name PIR.py in my home - ordner.
      And add python PIR.py in the rc.local
      After this was switch the PIR on the GPIO-Pin 13 the relay-pin 37. Add pin 32 i have a button to open the relay manual.
      • nogEN Offline
        nogE
        when execute the python script (python /home/pi/scripts/light.py), i got following error:
        File “/home/pi/scripts/light.py”, line 22
        read = GPIO.input(PIR_GPIO)
        • nogEN Offline
          nogE
          i got an error when i run python script. now the whole error message:
          IndentationError: expected an indented block
          thx
          • yawnsY Offline
            yawns Moderator @nogE
            @nogE
            Python is a bit tricky. Unlike other languages python needs proper indentation. Make sure you don’t mix up tabs and whitespaces. Best practice is to use 4 whitespaces instead of one tab.
              Blackmirror
              Yes, the error code says, you have not enought whitespaces before the lines.
