Compliments are not shown on Mirror
6 Posts 3 Posters 2.6k Views 2 Watching
    dboa
    Te Module is working, if I try to acess the server from my desktop windows, the compliments appear, but on the Mirror, it does not show:
    [EDIT]
    forgot to say, I’m using a Raspberry Pi Zero, with manual this installation: https://forum.magicmirror.builders/topic/1183/how-i-got-my-magic-mirror-working-on-a-raspberry-pi-0-zero
    [/EDIT]
    Thank you all in advance.
    B 1 Reply Last reply May 2, 2017, 6:16 PM Reply Quote 0
      broberg Project Sponsor @dboa
      @dboa the time is different on the mirror, do you have put the compliments in the “anytime” section or the afternoon/evening section?
      D 1 Reply Last reply May 2, 2017, 6:32 PM Reply Quote 0
        dboa @broberg
        @broberg I didn’t change anything from the original configuration, so it shoud say “Hey there sexy!” like on chrome. Also I just fixed the time, and the Compliments still don’t show
        S 1 Reply Last reply May 3, 2017, 8:36 AM Reply Quote 0
          strawberry 3.141 Project Sponsor Module Developer @dboa
          @dboa The compliments module makes use of an arrow function which is not supported within midori browser. So this might be the reason it doesn’t show up.
          https://forum.magicmirror.builders/topic/2031/compliments-not-displaying
          D 1 Reply Last reply May 3, 2017, 11:39 AM Reply Quote 1
            dboa @strawberry 3.141
            @strawberry-3.141 yes, that was the problem. I made the changes suggested in the topic, and it worked.
            Thank you so much.
            The Changes was:
            in the compliments.js file (found in /MagicMirror/modules/default/compliments folder), change:
            if (this.config.remoteFile != null) {
            	this.complimentFile((response) => {
            		this.config.compliments = JSON.parse(response);
            to:
                                function(response){
            Thank you all for your help.
            S 1 Reply Last reply May 3, 2017, 12:08 PM Reply Quote 0
              @dboa thats not right as I posted in the other thread as well, as soon as you want to use a remotefile it will fail. I posted the correct code in the other thread.
              Keep in mind when you want to update the MagicMirror next time this can cause a conflict
