    Problem of running MMM-Podcast and MMM-Button
    13 Posts 2 Posters 8.1k Views 2 Watching
    • A
      alex84
      Re: MMM-Button with MMM-Podcast
      Hello guys
      sorry for my english.
      i do not able to get this Module work. The only result is that my Screen turns black after starting MM.
      My configuration data is exactly who its write in the readme.txt
      Please help.
      Best regards
      Alex
      • H
        hirsnmirsn
        i have the same problem.
        my config.js looks like
               			module: 'MMM-Button',
        				//https://github.com/PtrBld/MMM-Button
        				//https://developer.microsoft.com/en-us/windows/iot/samples/pushbutton
        				//pin GIPO 5 und Ground
        				buttonPIN: '5'
              			module: 'MMM-Podcast',
               			position: 'middle_center',
                  			feedurl: 'http://www.tagesschau.de/export/video-podcast/webm/tagesschau-in-100-sekunden/'
        My button.js looks like
        /* global Module */
        /* Magic Mirror
         * Module: MMM-Button
         * MIT Licensed.
        Module.register('MMM-Button',{
        	requiresVersion: "2.1.0",
        	defaults: {
        		buttonPIN: 5,
        		//time in miliseconds before another button click is recognized
        		clickDelay: 500,
        	// Override socket notification handler.
        		if (notification === "BUTTON_PRESSED"){
        			this.sendNotification(notification, payload)
        	start: function() {
        		this.sendSocketNotification('BUTTON_CONFIG', this.config);
        		Log.info('Starting module: ' + this.name);
        Can anybody help us?
        • A
          alex84
          in the config.js there is a missing , behind buttonPIN: ‘5’
          H 1 Reply Last reply
          • H
            hirsnmirsn @alex84
            @alex84 if i had the , behind the buttonPIN:5 ther is always the Black screen
            • A
              alex84
              there is missing a comma
              • H
                hirsnmirsn @alex84
                @alex84 yes
                			//https://developer.microsoft.com/de-de/windows/iot/win10/samples/PushButton.htm
                			buttonPIN: '5',
                but i have always the Black screen.
                • A
                  alex84
                  Change into the MMM-Button folder and execute the following commands
                  sudo npm install --save-dev electron-rebuild
                  the
                  ./node_modules/.bin/electron-rebuild
                  • H
                    hirsnmirsn @alex84
                    @alex84 Thank You,
                    Now i have no mor Black Screen, but the Button dont work.
                    I have a Pyton Script, this works.
                    #Tagesschau.py
                    import RPi.GPIO as GPIO
                    import os
                    import sys
                    from subprocess import Popen
                    GPIO.setmode(GPIO.BCM)
                    GPIO.setup(5, GPIO.IN, pull_up_down=GPIO.PUD_UP)
                    movie1 = (“http://media.tagesschau.de/video/100s/2017/0504/TV-100s-1840.webm.h264.mp4”)
                    last_state1 = True
                    last_state2 = True
                    input_state1 = True
                    input_state2 = True
                    quit_video = True
                    player = False
                    while True:
                    #Read states of inputs
                    input_state1 = GPIO.input(5)
                    #If GPIO(5) is shorted to Ground
                    if input_state1 != last_state1:
                        if (player and not input_state1):
                            os.system('killall omxplayer')
                            omxc = Popen(['omxplayer', movie1])
                            player = True
                        elif not input_state1:
                            player = True
                    #If omxplayer is running and GIOP(5) are not shorted to Ground
                    elif (player and input_state1 and input_state2):
                        player = False
                    #Set last_input states
                    last_state1 = input_state1
                    Has anybody a working config and button config that he can post?
                    • A
                      alex84
                      I will you later Post my config of the button and my config as well as the config of the podcast. I’m on the road. :)
                      • H
                        hirsnmirsn @alex84
                        @alex84 Thank You :ok_hand_tone3:
                        • A
                          alex84
                          Hello hirsnmirsn
                          sorry for the late reply
                          This is in my Config.js
                          module: “MMM-Podcast”
                          module: “MMM-Button”,
                          and last but not least the MMM-Button.js
                          /* global Module */
                          /* Magic Mirror
                          • Module: MMM-Button
                          • MIT Licensed.
                          Module.register(‘MMM-Button’,{
                          requiresVersion: “2.1.0”,
                          defaults: {
                          buttonPIN: 5,
                          clickDelay: 500,
                          if (notification === “BUTTON_PRESSED”){
                          start: function() {
                          this.sendSocketNotification(‘BUTTON_CONFIG’, this.config);
                          Log.info('Starting module: ’ + this.name);
                          Make a reboot after Change your config.js
                          The only difference I can see in the files is that you tried to load another Solution (so it stands in your Config.js)
                          Feedurl: ‘http://www.tagesschau.de/export/video-podcast/webm/tagesschau-in-100-sekunden/’
                          I have tried it and with me everything runs without problems.
                          • H
                            hirsnmirsn @alex84
                            @alex84 Great Great Great!!!
                            IT WORK`s
                            Thank you
                            • A
                              alex84
                              I’m glad it works. have fun with it. I am glad that I could help
