    Problem of running MMM-Podcast and MMM-Button
    13 Posts 2 Posters 7.3k Views 2 Watching
    • H Offline
      hirsnmirsn
      i have the same problem.
      my config.js looks like
             			module: 'MMM-Button',
      				//https://github.com/PtrBld/MMM-Button
      				//https://developer.microsoft.com/en-us/windows/iot/samples/pushbutton
      				//pin GIPO 5 und Ground
      				buttonPIN: '5'
            			module: 'MMM-Podcast',
             			position: 'middle_center',
                			feedurl: 'http://www.tagesschau.de/export/video-podcast/webm/tagesschau-in-100-sekunden/'
      My button.js looks like
      /* global Module */
      /* Magic Mirror
       * Module: MMM-Button
       * MIT Licensed.
      Module.register('MMM-Button',{
      	requiresVersion: "2.1.0",
      	defaults: {
      		buttonPIN: 5,
      		//time in miliseconds before another button click is recognized
      		clickDelay: 500,
      	// Override socket notification handler.
      		if (notification === "BUTTON_PRESSED"){
      			this.sendNotification(notification, payload)
      	start: function() {
      		this.sendSocketNotification('BUTTON_CONFIG', this.config);
      		Log.info('Starting module: ' + this.name);
      Can anybody help us?
        alex84
        in the config.js there is a missing , behind buttonPIN: ‘5’
        • H Offline
          hirsnmirsn @alex84
          @alex84 if i had the , behind the buttonPIN:5 ther is always the Black screen
            alex84
            there is missing a comma
            • H Offline
              hirsnmirsn @alex84
              @alex84 yes
              			//https://developer.microsoft.com/de-de/windows/iot/win10/samples/PushButton.htm
              			buttonPIN: '5',
              but i have always the Black screen.
                alex84
                Change into the MMM-Button folder and execute the following commands
                sudo npm install --save-dev electron-rebuild
                the
                ./node_modules/.bin/electron-rebuild
                • H Offline
                  hirsnmirsn @alex84
                  @alex84 Thank You,
                  Now i have no mor Black Screen, but the Button dont work.
                  I have a Pyton Script, this works.
                  #Tagesschau.py
                  import RPi.GPIO as GPIO
                  import os
                  import sys
                  from subprocess import Popen
                  GPIO.setmode(GPIO.BCM)
                  GPIO.setup(5, GPIO.IN, pull_up_down=GPIO.PUD_UP)
                  movie1 = (“http://media.tagesschau.de/video/100s/2017/0504/TV-100s-1840.webm.h264.mp4”)
                  last_state1 = True
                  last_state2 = True
                  input_state1 = True
                  input_state2 = True
                  quit_video = True
                  player = False
                  while True:
                  #Read states of inputs
                  input_state1 = GPIO.input(5)
                  #If GPIO(5) is shorted to Ground
                  if input_state1 != last_state1:
                      if (player and not input_state1):
                          os.system('killall omxplayer')
                          omxc = Popen(['omxplayer', movie1])
                          player = True
                      elif not input_state1:
                          player = True
                  #If omxplayer is running and GIOP(5) are not shorted to Ground
                  elif (player and input_state1 and input_state2):
                      player = False
                  #Set last_input states
                  last_state1 = input_state1
                  Has anybody a working config and button config that he can post?
                    alex84
                    I will you later Post my config of the button and my config as well as the config of the podcast. I’m on the road. :)
                    • H Offline
                      hirsnmirsn @alex84
                      @alex84 Thank You :ok_hand_tone3:
                        alex84
                        Hello hirsnmirsn
                        sorry for the late reply
                        This is in my Config.js
                        module: “MMM-Podcast”
                        module: “MMM-Button”,
                        and last but not least the MMM-Button.js
                        /* global Module */
                        /* Magic Mirror
                        • Module: MMM-Button
                        • MIT Licensed.
                        Module.register(‘MMM-Button’,{
                        requiresVersion: “2.1.0”,
                        defaults: {
                        buttonPIN: 5,
                        clickDelay: 500,
                        if (notification === “BUTTON_PRESSED”){
                        start: function() {
                        this.sendSocketNotification(‘BUTTON_CONFIG’, this.config);
                        Log.info('Starting module: ’ + this.name);
                        Make a reboot after Change your config.js
                        The only difference I can see in the files is that you tried to load another Solution (so it stands in your Config.js)
                        Feedurl: ‘http://www.tagesschau.de/export/video-podcast/webm/tagesschau-in-100-sekunden/’
                        I have tried it and with me everything runs without problems.
