    Error Running Magic Mirror on Google Compute
    8 Posts 3 Posters 3.5k Views 3 Watching
      d3r
      Apologies for bumping an old topic but I have the same issue here. I flashed a new sd card this weekend and set up MM2 again. My MM2 works fine in normal mode(electron) but if I get this error when running only the server.
      WARNING! Could not load config file. Starting with default configuration. Error found: TypeError: Object # has no method 'accessSync'
      @onetwankyfive Were you able to get around this problem?
      • bheplerB Offline
        bhepler Module Developer @d3r
        @d3r This whitelist configuration is a bit dependent upon your network. If you have a router that assigns a different IP address, then this won’t work. For example, my Netgear Nighthawk router assigns IP addresses in the 10.0.0.X range, which are not covered by this whitelist. You’ll need to add values that represent your specific network. Otherwise, you can use [ ] to allow everyone to see your mirror interface.
        In windows, open up a command prompt by clicking on the Start Button and then typing cmd in the search bar. Click on the first result and you’ll get a command prompt. Enter ipconfig and it will respond with your IP address. Take that IP address and add it to your whitelist value in your config.js. If you want to authorize every machine on your network, replace the final value in that ip address with 0 and add “/24”. In my case, it’s 10.0.0.0/24. In most other networks, it will be 192.168.0.0/24. That should allow any device on your local network the ability to view the Mirror by browsing to its IP address.
        If you’re using Ubuntu or some other flavor of UNIX, ctrl+alt+t will get you a command prompt. The command in UNIX is ifconfig, not ipconfig. Don’t ask, because I don’t know why.
          d3r
          @bhepler Hey, thanks for your reply. I don’t see how changing the whitelist would do anything since the whitelist is located in the config and the config can’t be loaded in server only. I could be mistaken. I think my issue is a bit different. I should have expanded more. I’m on a pi3 and I’m running the code on the same pi.
          This is when I run node server only:
          :~/MagicMirror $ node serveronly
          Starting MagicMirror: v2.1.1
          Loading config ...
          ***WARNING! Could not load config file. Starting with default configuration. Error found: TypeError: Object # has no method 'accessSync'***
          Loading module helpers ...
          No helper found for module: updatenotification.
          No helper found for module: helloworld.
          All module helpers loaded.
          Starting server op port 8080 ...
          Server started ...
          Ready to go! Please point your browser to: http://localhost:8080
          and when I run npm start it does find the config which I find very strange.
          ~/MagicMirror $ npm start
          > magicmirror@2.1.1 start /home/drpi1/MagicMirror
          > sh run-start.sh
          Loading config ...
          No helper found for module: calendar_monthly.
          Module helper loaded: MMM-Wunderlist-Enhanced
          Module helper loaded: MMM-GarminActivities
          No helper found for module: MMM-doomsDay.
          Module helper loaded: MMM-WunderGround
          Module helper loaded: MMM-Strava
          Module helper loaded: MMM-Remote-Control
          No helper found for module: MMM-iFrameReload.
          No helper found for module: MMM-iFrame.
          Module helper loaded: MMM-Readfile
          No helper found for module: MMM-Carousel.
          Server started ...
          Connecting socket for: MMM-Wunderlist-Enhanced
          Connecting socket for: MMM-GarminActivities
          Starting node helper for: MMM-GarminActivities
          Starting module: newsfeed
          Connecting socket for: MMM-WunderGround
          MMM-WunderGround helper started ...
          Connecting socket for: MMM-Strava
          Starting module: MMM-Strava
          Connecting socket for: MMM-Remote-Control
          Starting node helper for: MMM-Remote-Control
          Connecting socket for: MMM-Readfile
          Staring module helper: MMM-Readfile
          Launching application.
          • bheplerB Offline
            @d3r That’s really curious. Because I do not have that problem with node serveronly.
            node serveronly
            Loading config ...
            No helper found for module: MMM-Globe.
            Server started ...
            It looks like you are running two different mirrors on that box. The list of modules loaded in each case is different. I think you’re logged in as different users, so the ~ folder is going to point to different spots.
            What do you get in return when you run ls -lh /home/?
              d3r @bhepler
              @bhepler said in Error Running Magic Mirror on Google Compute:
              I used to run node serveronly fine too. Then last week my sd card starting showing signs that it would die soon. So, I flashed raspbian on a new sd card and started fresh.
              ~ $ ls -lh /home/
              total 4.0K
              drwxr-xr-x 32 drpi1 drpi1 4.0K May 22 14:59 drpi1
              I have the default pi user deleted for security reasons. That’s the only thing I did different on this card.
              I think the list is different because it fails to load the config in node serveronly so the modules that are supposed to run do not.
              • bheplerB Offline
                @d3r Well, there goes that theory.
                At this point, all I can think of is a permissions problem. What does ls -lh ~/MagicMirror/config get you?
                  d3r @bhepler
                  @bhepler
                  :~ $ ls -lh ~/MagicMirror/config
                  total 24K
                  -rw-r--r-- 1 drpi1 drpi1 7.7K May 21 18:00 configglobetest.js
                  -rw-r--r-- 1 drpi1 drpi1 8.3K May 22 16:42 config.js
                  -rw-r--r-- 1 drpi1 drpi1 1.6K May 21 02:28 config.js.sample
                  I
