    MMM-AlexaPi
    9 Posts 4 Posters 5.2k Views 5 Watching
    • michael24hM Offline
      michael24h
      Microphone Icon not showing up
      I Installed MMM-AlexaPi in to modules, paste this in to config.js. But mic icon not showing
              module: 'MMM-AlexaPi',
              position: 'lower_third',
                  // If no config is set, defualt values are used
        mochman Module Developer
        How did you set up your AlexaPi program? Did you use the default raspberrypi platform? If so, you may need to change it in your config file.
        sudo nano /etc/opt/AlexaPi/config.yaml
        Find the area called Platform: and change
        platform:
          # Name of your platform, e.g. raspberrypi, orangepi, desktop
        device: "raspberrypi"
        to:
        platform:
        device: "magicmirror"
        You may also want to scroll down further on the config file and see if your magicmirror settings are correct.
        Then don’t forget to restart the AlexaPi program.
          michael24h
          I got this already
          platform:
            michael24h
            I’m only missing mic. icon. Alexa works fine
              michael24h
              This is anything else what Should be installed in order to show up AleaxaPi microphone icon ?
                borrigan @michael24h
                @michael24h did you ever get the mic to show up? Same problem here.
                Thanks!
                michael24hM 1 Reply Last reply Reply Quote 0
                  michael24h @borrigan
                  @borrigan
                  yes mate, mic. icon show up after installing one of add ons
                    bminer1 @mochman
                    @mochman When i run
                    i get a blank page. Any idea?
                      michael24h
                      @bminer1 said in MMM-AlexaPi:
                      /etc/opt/AlexaPi
                      This should work
                      pi@Clock: cd /etc/opt/AlexaPi
                      pi@Clock:/etc/opt/AlexaPi ls
                      config.yaml
                      nano config.yaml
