Solved Analog + Digital Clock module
@MichMich, read the post above yours … default is gray, not red. A config option will let the user set it to whatever color they want.
Ok, I checked in a PR with the new addition. Current changed/added options in addition the ones already present are:
displayType: 'digital', // options are: 'digital', 'analog', or 'both' analogSize: '200px', // This defines how large you want the analog clock to be analogFace: 'simple', // options are: 'simple', 'none', or 'face-###' where ### is a value between // 001 to 012, inclusive. The 'simple' options displays a simple border, 'none' is no border, // and the 'face-###' ones are SVG images that can be used as the face for the clock analogPlacement: 'bottom', // options are: 'top', 'right', 'bottom', 'left' This option is applicable only // when the displayType is set to 'both' and defined where you want the clock in relation // to the digital one secondsColor: '#888888'. // this defines what color the seconds hand will be. I like mine red ... like wine.
You can see the displays in a prior post.
I forgot to mention this: the clock faces are SVG files, so if you want to put a large analog clock in the middle of your mirror, you can, it will scale beautifully. This is a 600 pixels wide clock using the same SVG file as the smaller one in a previous post.
Great work, is this published somewhere already?
How do i get it? -
It’s checked into the develop branch. You can grab that and test it out.
Sorry, im quite new here, develop branch? Cannot find it. :(
I’m on the road at the moment so I can’t give you a detailed answer, but you can clone the develop branch instead of the master one:
git clone - b develop http://github.com/MichMich/MagicMirror
Warning: it will overwrite any changes you may have made to local files, just be aware of that.
It’s in the master branch now … :)
Thanks alot mate… :bow:
@Kevin, as a side note, if there’s a particular clock face that you like me to create for you, let me know. If you have an example, that will greatly help.
