    Analog + Digital Clock module
    38 Posts 5 Posters 51.5k Views 5 Watching
    • MichMichM Offline
      MichMich
      Very Nice Work By the way! :)
      • K Offline
        Kevin
        Very nice work, you’re the best, thanks a million for the great work.
        I think it covers my need right now.
        • K Offline
          KirAsh4 Moderator @MichMich
          @MichMich, read the post above yours … default is gray, not red. A config option will let the user set it to whatever color they want.
          • K Offline
            KirAsh4 Moderator
            Ok, I checked in a PR with the new addition. Current changed/added options in addition the ones already present are:
            displayType: 'digital',  // options are: 'digital', 'analog', or 'both'
            analogSize: '200px',     // This defines how large you want the analog clock to be
            analogFace: 'simple',    // options are: 'simple', 'none', or 'face-###' where ### is a value between
                                     // 001 to 012, inclusive. The 'simple' options displays a simple border, 'none' is no border,
                                     // and the 'face-###' ones are SVG images that can be used as the face for the clock
            analogPlacement: 'bottom', // options are: 'top', 'right', 'bottom', 'left' This option is applicable only
                                       // when the displayType is set to 'both' and defined where you want the clock in relation
                                       // to the digital one
            secondsColor: '#888888'. // this defines what color the seconds hand will be. I like mine red ... like wine.
            You can see the displays in a prior post.
            • K Offline
              KirAsh4 Moderator
              I forgot to mention this: the clock faces are SVG files, so if you want to put a large analog clock in the middle of your mirror, you can, it will scale beautifully. This is a 600 pixels wide clock using the same SVG file as the smaller one in a previous post.
              • K Offline
                Kevin
                Great work, is this published somewhere already?
                How do i get it?
                • K Offline
                  KirAsh4 Moderator
                  It’s checked into the develop branch. You can grab that and test it out.
                  • K Offline
                    Kevin @KirAsh4
                    Sorry, im quite new here, develop branch? Cannot find it. :(
                    • K Offline
                      KirAsh4 Moderator
                      I’m on the road at the moment so I can’t give you a detailed answer, but you can clone the develop branch instead of the master one:
                      git clone - b develop http://github.com/MichMich/MagicMirror
                      Warning: it will overwrite any changes you may have made to local files, just be aware of that.
                      • MichMichM Offline
                        MichMich
                        It’s in the master branch now … :)
                        • K Offline
                          Kevin
                          Thanks alot mate… :bow:
                          • K Offline
                            KirAsh4 Moderator
                            @Kevin, as a side note, if there’s a particular clock face that you like me to create for you, let me know. If you have an example, that will greatly help.
                              pugsly
                              Works great, just one question. I want to put the analog clock in the top_center and don’t want to show the date because I have the digital clock in the top_right position. How do I turn off the date from showing on a 2nd clock module?
                              • K Offline
                                KirAsh4 Moderator
                                At the moment, it’s hard coded in. I’d have to add a config option so it can be turned off when used as a separate module.
                                • K Offline
                                  KirAsh4 Moderator
                                  Ok, I have it in my dev branch, but I won’t push it up just yet. I’ll wait a bit to see if there are other things that people will request or fixes. But if you must get rid of it now, you can manually edit the 'clock.js' file and delete line 173:
                                  169:    } else if (this.config.displayType === 'analog') {
                                  170:        // Display only an analog clock
                                  171:        dateWrapper.style.textAlign = "center";
                                  172:        dateWrapper.style.paddingBottom = "15px";
                                  173:        wrapper.appendChild(dateWrapper);             <===== that line
                                  174:        wrapper.appendChild(clockCircle);
                                  175:    } else {
                                  It will only affect the analog clock when used as a separate module as a single clock.
                                  • K Offline
                                    KirAsh4 Moderator
                                    I should point out that this is just a temporary thing, so you can get rid of it. The updated code will give you a config option to disable it, show it above, or below the clock.
                                    • K Offline
                                      KirAsh4 Moderator
                                      @pugsly, I forgot to mention this: new code has been added to the 'develop' branch that allows you to turn off the date display when using the module in analog mode only. Options are 'top' (default) to have it displayed at the top of the clock, 'bottom' to show it on the bottom, or 'false' to completely turn it off.
                                      • T Offline
                                        trividar
                                        someone know why this happend to me after updating MM:
                                        alt text
                                        everything looks fine just the analag clock.
                                        • N Offline
                                          nagaculun @trividar
                                          @trividar said in Analog + Digital Clock module:
                                          alt text
                                          Happened to me too. It was fine yesterday.
                                          • N Offline
                                            nobita @nagaculun
                                            @nagaculun you can adjust resize analogSize: “200px”, to smaller ex 150px
                                            N T 2 Replies Last reply Reply Quote 0
