    MMM-ModuleToggle
    7 Posts 3 Posters 4.8k Views 2 Watching
    • T
      trekky
      Description:
      MMM-ModuleToggle can show or hide specific modules by sending a notification to the module. You can also define to toggle between show and hide and hide module on startup.
      It can be easily combined with MMM-Buttons to hide or show modules with the press of a button.
      Download:
      https://github.com/Trekky12/MMM-ModuleToggle
        pepemujica @trekky
        @trekky So… how do you send the notification?
        • T
          trekky @pepemujica
          @pepemujica I described it in the readme. With the MMM-Buttons module you can for example send the following notification to hide the calendar and clock module:
          notification: "MODULE_TOGGLE",
          payload: {hide: ["calendar", "clock"], show: [], toggle:[]}
            pepemujica @trekky
            @trekky Thanks
            • SnilleS
              Snille Module Developer
              Great idea! :)
              If i have multiple instances of a module, for example MMM-WunderGround (for different locations) or as in my case I have 6 MMM-MotionEye modules. :)
              Can I specify what “instans” of that module I want to toggle?
              • T
                trekky @Snille
                @Snille I am using .withClass(classnames) to identify the modules. (see).
                Since I am not using more than one instance of a module I don’t know if the classname differs in individual instances or if you can define the classname manually. Can you check if they have different classes?
                • SnilleS
                  I think the class is the same but the “id” is different. I’m using the ID in my MMM-Modulebar. But I’ll have to test it when I have some time. :)
