    ENOMEM errors coming from UpdateNotification and MMM-PIR-Sensor modules
    6 Posts 2 Posters 3.2k Views 2 Watching
      malicious_banjo
      My mirror has crashed twice in the past 24 hours due to ENOMEM errors, the stack trace from the error log is as follows:
      { Error: spawn ENOMEM
          at exports._errnoException (util.js:1022:11)
          at ChildProcess.spawn (internal/child_process.js:313:11)
          at Object.exports.spawn (child_process.js:399:9)
          at Git._schedule (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1249:42)
          at Git._run (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:1231:12)
          at Git.fetch (/home/pi/MagicMirror/node_modules/simple-git/src/git.js:317:19)
          at /home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:64:11
          at Array.forEach (native)
          at Class.preformFetch (/home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:63:14)
          at Timeout._onTimeout (/home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:83:9) code: 'ENOMEM', errno: 'ENOMEM', syscall: 'spawn' }
          at exports.spawn (child_process.js:399:9)
          at Object.exports.execFile (child_process.js:160:15)
          at Object.module.(anonymous function) [as execFile] (ELECTRON_ASAR.js:200:20)
          at exports.exec (child_process.js:120:18)
          at childProcess.(anonymous function) (ELECTRON_ASAR.js:685:22)
          at Class.deactivateMonitor (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_helper.js:37:7)
          at Timeout._onTimeout (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_helper.js:74:18)
          at ontimeout (timers.js:365:14) code: 'ENOMEM', errno: 'ENOMEM', syscall: 'spawn' }
      I’ve had the mirror running for about a week, this is the first time I’m coming across this. Does anyone know what I can do to resolve this?
      • cowboysdudeC Offline
        @malicious_banjo said in ENOMEM errors coming from UpdateNotification and MMM-PIR-Sensor modules:
        ENOMEM errors
        What modules are you running? It’s an out of memory error…
          malicious_banjo @cowboysdude
          @cowboysdude Oh, my bad. Those two are both the modules that failed both times, assumed they were the root cause.
          Modules:
          • UpdateNotification
          • default Clock
          • default Calendar
          • default Compliments
          • default CurrentWeather
          • default Weatherforecast
          • default NewsFeed
          • MMM-Scrobbler
          • MMM-My-Commute
          • MMM-pihole-stats
          • phone notifications
            Comment out all of these:
            MMM-Scrobbler
            MMM-My-Commute
            MMM-pihole-stats
            phone notifications
            like this:
                        disabled: true,
                        module: 'MMM-NPMWeather',
                        position: 'bottom_bar',
            				read: "F",
            				maxWidth: "50%"
            just add disabled: true, to the top of each one like the example then try rerunning the mirror…
            If it runs okay then one at a time change the true to false… and rerun…
            That’s troubleshooting to see if any of the modules are causing this issue.
              @cowboysdude I’m expecting the error to come from the pihole module, it didn’t start happening until I added that yesterday.
              If/when I diagnose that it’s the source, how would you recommend I fix it?
                cowboysdude Module Developer @malicious_banjo
                pihole module
                I would suggest uninstalling the pihole module… pihole uninstall [I believe I read somewhere]
