MMM-awesome-alexa black screen, installation error
7 Posts 3 Posters 3.1k Views 3 Watching
    mc_landin
    I am trying to get the MMM-awesome-alexa black screen module to work.
    However, my MM only gives a black screen as well as the following installation errors:
    100 error code ELIFECYCLE
    101 error mmm-awesome-alexa@1.0.0 postinstall: npm run build
    101 error Exit status 1
    102 error Failed at the mmm-awesome-alexa@1.0.0 postinstall script ‘npm run build’.
    102 error Make sure you have the latest version of node.js and npm installed.
    102 error If you do, this is most likely a problem with the mmm-awesome-alexa package,
    102 error not with npm itself.
    102 error Tell the author that this fails on your system:
    102 error npm run build
    Anyone knows how to fix this?
    • L Offline
      letsirk
      I’m having the same issue, if you find a fix please let me know.
        mydiva
        @mc_landin @letsirk in the MMM-awesome-alexa directory, run npm run electron-rebuild
        check this side:
        gitter
        Does it works to you guys? I got it to work but it did not recognize my voice… please write your problems at gitter…
        L 1 Reply Last reply Jul 7, 2017, 9:17 PM Reply Quote 0
        • L Offline
          letsirk @mydiva
          @mydiva Thanks that worked for me
            mc_landin
            @mydiva said in MMM-awesome-alexa black screen, installation error:
            gitter
            Doesn’t do the trick for me. What else may fix this?
              mydiva
              @mc_landin read the gitter forum…there are a few solution for problems and common mistakes.
                mc_landin
