    MMM-awesome-alexa black screen, installation error
    7 Posts 3 Posters 4.1k Views 3 Watching
      mc_landin
      I am trying to get the MMM-awesome-alexa black screen module to work.
      However, my MM only gives a black screen as well as the following installation errors:
      100 error code ELIFECYCLE
      101 error mmm-awesome-alexa@1.0.0 postinstall: npm run build
      101 error Exit status 1
      102 error Failed at the mmm-awesome-alexa@1.0.0 postinstall script ‘npm run build’.
      102 error Make sure you have the latest version of node.js and npm installed.
      102 error If you do, this is most likely a problem with the mmm-awesome-alexa package,
      102 error not with npm itself.
      102 error Tell the author that this fails on your system:
      102 error npm run build
      Anyone knows how to fix this?
      • L
        letsirk
        I’m having the same issue, if you find a fix please let me know.
          mydiva
          @mc_landin @letsirk in the MMM-awesome-alexa directory, run npm run electron-rebuild
          check this side:
          gitter
          Does it works to you guys? I got it to work but it did not recognize my voice… please write your problems at gitter…
          L 1 Reply Last reply
          • L
            letsirk @mydiva
            @mydiva Thanks that worked for me
              mc_landin
              @mydiva said in MMM-awesome-alexa black screen, installation error:
              gitter
              Doesn’t do the trick for me. What else may fix this?
                mydiva
                @mc_landin read the gitter forum…there are a few solution for problems and common mistakes.
                  mc_landin
