    MMM-Instagram - Pull and animate photos from Instagram feed
    87 Posts 26 Posters 123.0k Views 27 Watching
    • K Offline
      kapsolas Module Developer @zeular
      @zeular I suppose that this could be implemented. The module could be updated to make multiple requests to various sources.
      Given my current availability, this would not be something I can do in the near future.
      zeularZ 1 Reply Last reply Reply Quote 0
      • zeularZ Offline
        zeular @kapsolas
        @kapsolas I understand, but if you had time over, I would be grateful.
        Thank’s anyway, for taking your time and reply.
        • K Offline
          @zeular You are welcome!
          And to be clear, when you say pull from different API, you mean different services? Like Flickr, Instagram, etc?
          • zeularZ Offline
            zeular @kapsolas
            @kapsolas No, I meant two different instagram accounts …
            • G Offline
              Garrett
              @kapsolas Forgive me if i’m wrong, (New Here) when you mean pulling images from your own feed, that means the images are loading from your own account correct? Anyway to pull from others users accounts? I know it states that in your Readme yet i’ve found no instructions on how that works. Basically I want it it load the “home feed” where other users posts you follow show up in. Any light in this area would be much appreciated! Thanks.
              K 1 Reply Last reply Reply Quote 1
              • K Offline
                kapsolas Module Developer @Garrett
                @Garrett Not sure if this is actually possible, but may be.
                I would need to review the instragram API.
                Currently, i was just interested in viewing my own photos when I wrote the module. it was more to meet my needs and then I shared it.
                When I have some time, i’ll try to implement some of the requests folks have had.
                zeularZ rudibaraniR 2 Replies Last reply Reply Quote 1
                • zeularZ Offline
                  zeular @kapsolas
                  @kapsolas In my case, I have two APIs from me and my wife’s account that I want to appear, I’ve tried to “just” to add two APIs, but it wasen’t that easy…
                  I first thought Instagram “sandbox” could import other accounts flow but it does not seem so. I have added my wifes account to my “sandbox” but there is no difference.
                  • rudibaraniR Offline
                    rudibarani Project Sponsor @kapsolas
                    Hi @kapsolas,
                    I think I need some help with the settings for
                    min_timestamp: 0,
                    Is there a way to set show only images from today and show nothing if there is no image uploaded today?
                    Thanks for your help
                    • K Offline
                      kapsolas Module Developer @rudibarani
                      @rudibarani Hi - There currently is no intelligence on the images selected. It just processes the list that is returned by the API and starts to randomly display them.
                      What you are asking for would need to be coded.
                      rudibaraniR 1 Reply Last reply Reply Quote 0
                        @kapsolas Thanks for the quick reply. Another question on the side: It seems that only images are are loaded that where on Instagram before I restarted my MM. Is that intended behaviour or am I doing something wrong?
                        			module: 'MMM-Instagram',
                        			position: 'middle_center',
                        			disabled: false,
                        				access_token: '####.####',
                        				count: 200,
                        				min_timestamp: 0,
                        				animationSpeed: 2500,
                        				updateInterval: 30000
                        I waited an hour but non of my new images showed up. Only old ones. Even create a new account with only three images before booting my MM - and it keeps cycling those three and ignores later uploads…
                        Any idea?
                        • Y Offline
                          Yurick
                          Read my post 4 months ago. I changed the code and it works fine for me. As I am a copy-paste coder, I can’t post it here for not to be damned. :) But if we ask a author to fix it using my clues it would be nice to have a working module.
                            rudibarani Project Sponsor @Yurick
                            Thanks @Yurick for finding the solution to the problem. Would be great to see this implemented so everyone could benefit from @kapsolas module.
                            • K Offline
                              The module was not loading new images. I was thinking to fix that and I have a solution i am testing.
                              Sounds like @Yurick has a solution for this too. If he pm’s it i can test it and incorporate into the code
                              • Y Offline
                                Yurick
                                Here is my MMM-Instagram.js
                                /* global Module */
                                /* Magic Mirror
                                 * Module: MMM-Instagram
                                 * By Jim Kapsalis https://github.com/kapsolas
                                 * MIT Licensed.
                                Module.register('MMM-Instagram', {
                                    defaults: {
                                        format: 'json',
                                        lang: 'en-us',
                                        animationSpeed: 1000,
                                        updateInterval: 60000, // 10 minutes
                                        access_token: '',
                                        count: 200,
                                        min_timestamp: 0,
                                        loadingText: 'Loading...'
                                    // Define required scripts
                                    getScripts: function() {
                                        return ["moment.js"];
                                    // Define required translations
                                    getTranslations: function() {
                                        return false;
                                    // Define start sequence
                                    start: function() {
                                	var self = this;
                                        Log.info('Starting module: ' + this.name);
                                        this.data.classes = 'bright medium';
                                        this.loaded = false;
                                        this.images = {};
                                        this.activeItem = 0;
                                        this.url = 'https://api.instagram.com/v1/users/self/media/recent' + this.getParams();
                                	var insturl = this.url;
                                //        Log.info('instaurl = ' + this.url);
                                	setInterval(function() {
                                //				Log.info('NewUrl = ' + this.url);
                                			        self.sendSocketNotification("INSTAGRAM_GET", insturl);
                                				    }, 40000); //perform every 1000 milliseconds.
                                    getStyles: function() {
                                        return ['instagram.css', 'font-awesome.css'];
                                    // Override the dom generator
                                    getDom: function() {
                                        var imageDisplay = document.createElement('div'); //support for config.changeColor
                                        if (!this.loaded) {
                                            wrapper.innerHTML = this.config.loadingText;
                                            return wrapper;
                                        // set the first item in the list...
                                        if (this.activeItem >= this.images.photo.length) {
                                        var tempimage = this.images.photo[this.activeItem];
                                        // image
                                        var imageLink = document.createElement('div');
                                        //imageLink.innerHTML = "<img src='https://www.google.com/images/branding/googlelogo/1x/googlelogo_color_272x92dp.png'>";
                                        imageLink.id = "MMM-Instagram-image";
                                        imageLink.innerHTML = "<img src='" + tempimage.photolink + "'>";
                                        imageDisplay.appendChild(imageLink);
                                        wrapper.appendChild(imageDisplay);
                                        return wrapper;
                                    /* scheduleUpdateInterval()
                                     * Schedule visual update.
                                    scheduleUpdateInterval: function() {
                                        var self = this;
                                        Log.info("Scheduled update interval set up...");
                                        self.updateDom(self.config.animationSpeed);
                                            Log.info("incrementing the activeItem and refreshing");
                                            self.activeItem++;
                                        }, this.config.updateInterval);
                                     * getParams()
                                     * returns the query string required for the request to flickr to get the
                                     * photo stream of the user requested
                                    getParams: function() {
                                        var params = '?';
                                        params += 'count=' + this.config.count;
                                        params += '&min_timestamp=' + this.config.min_timestamp;
                                        params += '&access_token=' + this.config.access_token;
                                        return params;
                                    // override socketNotificationReceived
                                        //Log.info('socketNotificationReceived: ' + notification);
                                        if (notification === 'INSTAGRAM_IMAGE_LIST')
                                            //Log.info('received INSTAGRAM_IMAGE_LIST');
                                            this.images = payload;
                                            //Log.info("count: " +  this.images.photo.length);
                                            // we want to update the dom the first time and then schedule next updates
                                            if (!this.loaded) {
                                            this.updateDom(1000);
                                                this.scheduleUpdateInterval();
                                            this.loaded = true;
                                Spoiler Text
                                  microkost
                                    microkost @microkost
                                    Is this module still working? Because after clonning and providing access_token according to manual is still stucked on Loading… warning.
                                    Output from starting MagicMirror:
                                    Connecting socket for: MMM-Instagram
                                    Starting node_helper for module [MMM-Instagram]
                                    OK, some debug… I finally used multi account fork from O5ten and used his API key from README 1160247792.b119586.49fa97770ee34deb92e621069c760cee then it started to show pictures, so finall problem is on my access_token. Good to know for debuging, should help someone else…
                                    How to test that access token is OK?
                                    Put to web browser:
                                    https://api.instagram.com/v1/users/self/media/recent?access_token=1160247792.b119586.49fa97770ee34deb92e621069c760cee
                                    did you see some data as result?
                                    "data": [{"id": "1698285770916717663...
                                    So now test your key
                                    https://api.instagram.com/v1/users/self/media/recent?access_token=[TOKEN_HERE]
                                    If there is result, everything is OK, if you get
                                    data	[]
                                    then is time to investigate! Do you have content on your wall? Because your’s last 20 posts are only accessible in sandbox https://www.instagram.com/developer/sandbox/ (!!!)
                                    For rest and another use cases read carefully https://www.instagram.com/developer/ guide.
                                    My problem was empty my wall… Sorry for spam, but maybe it helps someone not familiar with that with debuging.
                                    • N Offline
                                      nobita @kapsolas
                                      @kapsolas
                                      I have 3 questions
                                      1. What happen after install this module, Loading…status on monitor (not show photo)
                                      2. How to get API KEY
                                      3. in config, ask access_token so I have to put access_token or API KEY
                                        Thanks for all your kind
                                        benderstwin
                                        This works great, but is it possible to make it actually reload the pictures from instagram without reloading MM?
                                          AlexanderSalter
                                          Hi all, had the same problem, Instagram was acquired by Facebook who have updated the way the API works.
                                          I spent a couple of days writing and testing a new module for Instagram that was based off the original.
                                          It requires a Facebook developer account and app, but I have explained it as best i can in readme
                                          Intro_Post
                                          MMM-Instagram2020
                                            chassain 0 @AlexanderSalter
                                            @AlexanderSalter
                                            It works fine. Thanks Alexander.
                                            • 4 / 5
