    CORS using node_helper.js for Uber and Lyft APIs
    10 Posts 4 Posters 4.4k Views 3 Watching
    • cowboysdudeC Offline
      As an example ONLY!
         getStuff: function(url) {
        request({
              url: "https://www.whereever.com/stuff.json",
              method: 'GET',
              headers: {
                  'User-Agent': 'MagicMirror/1.0 '
        }, (error, response, body) => {
              if (!error && response.statusCode == 200) {
         blah..blah....blah.......
      kalK 1 Reply Last reply Reply Quote 0
      • kalK Offline
        kal @Anhalter42
        @Anhalter42 I’m looking at the JavaScript console. The IP of my laptop is whitelisted, so I go to https://IP.of.Raspberry.Pi:8080 in Chrome and then go to View>Developer>JavaScript Console.
        Is there another way I can get statements to print to that console ?
        • kalK Offline
          kal @cowboysdude
          @cowboysdude isn’t that what I am doing? Can you explain how your solution differs from mine?
            When you request a webpage, your browser sends a number of headers to the server hosting the site that you’re visiting.
            These headers occur during a negotiation process that helps the browser and the hosting server determine the best way to provide the requested information. The user-agent header identifies the application requesting the information from the server, typically a browser. This identification string is called the user-agent string and contains tokens that provide specific details about the program making the request.
            • kalK Offline
              kal @cowboysdude
              @cowboysdude I don’t think the user-agent string is required when making an HTTP request. According to the Uber API docs it doesn’t look like I need one.
                Anhalter42 @kal
                @kal well then… I know its not helping, but it should work as you described. Not seeing anything in js console is a serious problem when developing. Did you try other browsers? If nothing appears in any browser AND on raspberry itself (with npm start dev), then something is seriously wrong…
                • kalK Offline
                  kal
                  I was able to fix this. See below for the module code
                  /* global Module */
                  /* Magic Mirror
                   * Module: Uber
                   * Shows the time and surge pricing for UberX
                   * By Kyle Kelly
                   * based on MagicMirror work by Michael Teeuw http://michaelteeuw.nl
                   * and by derickson https://github.com/derickson/MMderickson/tree/master/uber
                   * MIT Licensed.
                  Module.register("MMM-uber",{
                  	// Default module config.
                  	defaults: {
                  		lat: null,
                  		lng: null,
                  		ride_type: "uberX",
                  		uberServerToken: null,
                  		updateInterval: 5 * 60 * 1000, // every 5 minutes
                  		animationSpeed: 1000,
                  	// Define required scripts.
                  	getScripts: function() {
                  		return ["moment.js", "https://code.jquery.com/jquery-2.2.3.min.js"];
                  	// Define required styles.
                  	getStyles: function() {
                  		return ["MMM-uber.css"];
                  	start: function() {
                  		// Set locale.
                  		moment.locale(config.language);
                  		// variables that will be loaded from service
                  		this.uberTime = null;
                  		this.uberSurge = null;
                  		this.loaded = false;
                  		Log.log("Sending CONFIG to node_helper.js in " + this.name);
                  		Log.log("Payload: " + this.config)
                  		this.sendSocketNotification('CONFIG', this.config);
                  	// unload the results from uber services
                  	processUber: function(FLAG, result) {
                  		var self = this;
                  		Log.log("ProcessUber");
                  		// go through the time data to find the uberX product
                  		if (FLAG === "TIME"){
                  			Log.log("Time:");
                  			Log.log(result);
                  			for (var i = 0, count = result.times.length; i < count ; i++) {
                  				var rtime = result.times[i];
                  				if(rtime.display_name === this.config.ride_type){
                  					// convert estimated seconds to minutes
                  					this.uberTime = rtime.estimate / 60;
                  					break;
                  		// go through the price data to find the uberX product
                  		else if (FLAG === "PRICE"){
                  			Log.log("Price:");
                  			Log.log(result);
                  			for( var i=0, count = result.prices.length; i< count; i++) {
                  				var rprice = result.prices[i];
                  				if(rprice.display_name === this.config.ride_type){
                  					// grab the surge pricing
                  					this.uberSurge = rprice.surge_multiplier;
                  					break;
                  	// Override dom generator.
                  	getDom: function() {
                  		var uber = document.createElement("div");
                  		uber.className = "uberButton";
                  		var uberIcon = document.createElement("img");
                  		uberIcon.className = "badge";
                  		uberIcon.src = "modules/MMM-uber/UBER_API_Badges_1x_22px.png";
                  		var uberText = document.createElement("span");
                  		if(this.loaded) {
                  			var myText = this.config.ride_type + " in "+ this.uberTime +" min ";
                  			Log.log("ubersurge: " + this.uberSurge);
                  			// only show the surge pricing if it is above 1.0
                  			if(typeof this.uberSurge !== "undefined" && this.uberSurge > 1.0){
                  				myText += " - " + this.uberSurge + "X surge pricing";
                  			uberText.innerHTML = myText;
                  		} else {
                  			// Loading message
                  			uberText.innerHTML = "Checking Uber status ...";
                  		uber.appendChild(uberIcon);
                  		uber.appendChild(uberText);
                  		wrapper.appendChild(uber);
                  		return wrapper;
                  		Log.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
                  		if (notification === "TIME") {
                  			this.processUber("TIME", JSON.parse(payload));
                  			this.updateDom(this.config.animationSpeed)
                  		else if (notification === "PRICE") {
                  			this.processUber("PRICE", JSON.parse(payload));
                  			this.loaded = true;
                  			this.updateDom(this.config.animationSpeed);
                  and the node_helper.js code
                  'use strict';
                  /* Magic Mirror
                   * Module: MMM-uber
                   * By Kyle Kelly
                   * MIT Licensed.
                  const NodeHelper = require('node_helper');
                  var request = require('request');
                  var moment = require('moment');
                  	start: function() {
                  		var self = this;
                  		console.log("Starting node helper for: " + this.name);
                  		this.config = null;
                  	getData: function() {
                  		var self = this;
                  		this.sendSocketNotification("Test", 2);
                  		this.sendSocketNotification("LATITUDE", this.config.lat);
                  		this.sendSocketNotification("LONGITUDE", this.config.lng);
                  		request({
                  			url: "https://api.uber.com/v1/estimates/time?start_latitude=" + this.config.lat + "&start_longitude=" + this.config.lng,
                  			method: 'GET',
                  			headers: {
                  		        'Authorization': 'Token ' + this.config.uberServerToken,
                  		        'Accept-Language': 'en_US',
                  		        'Content-Type': 'application/json'
                  		}, function (error, response, body) {
                  				self.sendSocketNotification("TIME", body);
                  			else {
                  				self.sendSocketNotification("ERROR", "In TIME request with status code: " + response.statusCode);
                  		request({
                  			url: "https://api.uber.com/v1/estimates/price?start_latitude=" + this.config.lat + "&start_longitude=" + this.config.lng + "&end_latitude=" + this.config.lat + "&end_longitude=" + this.config.lng,
                  			method: 'GET',
                  			headers: {
                  				self.sendSocketNotification("PRICE", body);
                  			else {
                  				self.sendSocketNotification("ERROR", "In PRICE request with status code: " + response.statusCode);
                  		setTimeout(function() { self.getData(); }, this.config.updateInterval);
                  		//var self = this;
                  		this.sendSocketNotification("Test", 0);
                  		if (notification === 'CONFIG') {
                  			this.sendSocketNotification("Test", 1);
                  			this.config = payload;
                  			this.getData();
