    missing 'Access-Control-Allow-Origin'
    10 Posts 6 Posters 6.9k Views 5 Watching
      Bangee Module Developer
      I’ll try to grab some informations from a JSON Data feed.
      But I’ve got always this error:
      Quellübergreifende (Cross-Origin) Anfrage blockiert: Die Gleiche-Quelle-Regel verbietet das Lesen der externen Ressource auf http://beny.ch/ironman/2015. (Grund: CORS-Kopfzeile 'Access-Control-Allow-Origin' fehlt).
      ironman: Could not load data.
      console.error(message);
      Datalink:
      here is the code to grab the content:
      		var ironmanRequest = new XMLHttpRequest();
      		ironmanRequest.open("GET", url, true);
      		ironmanRequest.onreadystatechange = function() {
      			if (this.readyState === 4) {
      				if (this.status === 200) {
      					self.processIronman(JSON.parse(this.response));
      				} else if (this.status === 401) {
      					self.updateDom(self.config.animationSpeed);
      					Log.error(self.name + ": Error forbidden");
      					retry = false;
      				} else {
      					Log.error(self.name + ": Could not load data.");
      				if (retry) {
      					self.scheduleUpdate((self.loaded) ? -1 : self.config.retryDelay);
      		ironmanRequest.send();
      How can I fix that?
      Thanks for helping me :-)
      • K Offline
        KirAsh4 Moderator
        This comes up quite often, not just here on the MM² forums, but out in the wild too:
        http://lmgtfy.com/?q=Access-Control-Allow-Origin
        Basically the answer is: you can’t do that … cross-domain … security … find proper API … all of the above …
          RedNax Module Developer @KirAsh4
          @KirAsh4 Well, not strictly true ;) https://forum.magicmirror.builders/topic/157/mmm-opentherm
          But yes, you’ll need to fix the source!
          • P Offline
            paviro
            Just use a node_helper.js to get around the access-allow-origin policy.
            – The Doctor
              After googleing 1000 different websites I’ve used the nood_helper.js solution.
              And to load the nood_helper.js I had to restart electron. pm2 restart mm
              that coast me another hour to find out why it was no loading :-):gun: :hammer:
              • K Offline
                KrawallKurt
                I am facing the same problem. Could you please give an example, how you used node_helper.js to circumvent the access-allow-origin policy?
                Thanks!
                • Y Offline
                  yawns Moderator
                  Like here for example:
                  https://github.com/yawnsde/MMM-RNV
                  You use request instead.
                  • K Offline
                    KrawallKurt
                    Thank you!
                    And why does it have to be in node_helper, not in the main script? Sorry, if this question sounds stupid, I’m new to developing modules.
                    Also, is there a reason for declaring var self = this; and using self.func instead of this.func? I have seen this quite a bit and couldn’t understand why people do this…
                    • Y Offline
                      yawns Moderator @KrawallKurt
                      @KrawallKurt
                      Please note I am not an experienced javascript developer either. When using addon modules/libraries like request you use the node_helper.js to load this library. I am not sure if it is not possible at all to do so in the main module file or if it is just complicated. Maybe @strawberry-3-141 can clarify :)
                      self = this was used in other modules and I added it to my module as well, because I did not want to possibly break something by leaving it out. There is a lot of discussion on the web why this is used and if this still should be used.
                      • K Offline
                        KrawallKurt
                        Concerning the self=this question, I found a neat article giving som explanations: https://alistapart.com/article/getoutbindingsituations
                        The other question: Could it be, that node_helper is executed on the server and the main script is executed on the client?
