    MMM-OpenTherm
    3 Posts 2 Posters 4.0k Views 2 Watching
    • R
      RedNax Module Developer
      Although i suspect not a lot of people will use this, i’ll share it anyway:
      https://github.com/RedNax67/MMM-OpenTherm
      For this to work you’ll need:
      An OpenTherm controlled heating/cooling device An OpenTherm gateway http://otgw.tclcode.com/ The OpenTherm Monitor application running somewhere http://otgw.tclcode.com/otmonitor.html
      NOTE: The otmonitor version hosted on the website doesn’t have the access-allow-origin-header so the browser running MM will probably reject the json response. Luckily the author also supplies the source and instructions on how to build/compile your own version.
      I’ve compiled a (RpI) version of the otmonitor program with this header included. Anyone in need of if, please let me know.
      The OpenTherm module displays:
      • Current roomtemperature
      • Room setpoint temperature
      • Outside temperature
      • Central heating pressure
      • Heating on/of
      • Hot water on/off
      • Alerts (Low pressure)
      • R
        Unfortunately can’t edit my FP…
        Here’s a screenshot of teh module:
        • P
          paviro
          Why not use a node_helper.js to get around the access-allow-origin policy?
          – The Doctor
