    missing 'Access-Control-Allow-Origin'
    10 Posts 6 Posters 6.6k Views 5 Watching
    • BangeeB Offline
      Bangee Module Developer
      After googleing 1000 different websites I’ve used the nood_helper.js solution.
      And to load the nood_helper.js I had to restart electron. pm2 restart mm
      that coast me another hour to find out why it was no loading :-):gun: :hammer:
      • K Offline
        KrawallKurt
        I am facing the same problem. Could you please give an example, how you used node_helper.js to circumvent the access-allow-origin policy?
        Thanks!
        • yawnsY Offline
          yawns Moderator
          Like here for example:
          https://github.com/yawnsde/MMM-RNV
          You use request instead.
          • K Offline
            KrawallKurt
            Thank you!
            And why does it have to be in node_helper, not in the main script? Sorry, if this question sounds stupid, I’m new to developing modules.
            Also, is there a reason for declaring var self = this; and using self.func instead of this.func? I have seen this quite a bit and couldn’t understand why people do this…
            • yawnsY Offline
              yawns Moderator @KrawallKurt
              @KrawallKurt
              Please note I am not an experienced javascript developer either. When using addon modules/libraries like request you use the node_helper.js to load this library. I am not sure if it is not possible at all to do so in the main module file or if it is just complicated. Maybe @strawberry-3-141 can clarify :)
              self = this was used in other modules and I added it to my module as well, because I did not want to possibly break something by leaving it out. There is a lot of discussion on the web why this is used and if this still should be used.
              • K Offline
                KrawallKurt
                Concerning the self=this question, I found a neat article giving som explanations: https://alistapart.com/article/getoutbindingsituations
                The other question: Could it be, that node_helper is executed on the server and the main script is executed on the client?
