    So then, what languages to learn?
    6 Posts 5 Posters 6.4k Views 5 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @NathTheDude
      @NathTheDude you will need js to give your module some logic, some basic html for the layout and also a bit css for styling.
      But you can also write your main logic in nearly every language you want, a couple of people used python for example. Though you would still need a wrapper in js to integrate it to MagicMirror.
      • cowboysdudeC Offline
        cowboysdude Module Developer @NathTheDude
        @NathTheDude said in So then, what languages to learn?:
        So, I want to start playing with the modules and customising them for my needs. It looks like the best language to learn is JavaScript and also CSS.
        I agree! It’s the easiest way to learn PLUS you can always ask and look in other modules for bits and pieces to see how things work. I mean a sendSocketNotification is a sendSocketNotification… things of that nature.
        Again, if you have questions please ask! :) I had to learn it too. It’s not too bad actually once you get the basics…
        • N Offline
          NathTheDude
          Thanks @cowboysdude and @strawberry-3-141, will start looking at those.
            j.e.f.f Project Sponsor Module Developer @NathTheDude
            @NathTheDude If you’re already familiar with programming, even as a novice, JavaScript won’t be that hard to learn. Here’s a great place to start: https://www.codecademy.com/learn/learn-javascript
            And as @cowboysdude mentions, definitely look at other modules to see how things work specifically in MagicMirror.
            Don’t overlook the importance of how you structure your HTML markup. Resist the temptation to lay things out using table elements (table). Try to use div (typically for outer containers) and span (typically for elements within a larger container) elements instead. This will give you far more flexibility in your CSS when positioning elements. Take a look at my scoreboard module for an example of how the same markup can be laid out many different ways by specifying a particular CSS class to the outer container. Also, add CSS classes to all the significant parts of your markup. That way you can target any element using your CSS, and you’ll also make other people happy when they want to customize your module with their own CSS. A couple of great places to learn CSS: http://www.css-101.org/ (beginner) and https://css-tricks.com/ (advanced).
              McSorley
              From my attempts at learning, I think JavaScript and Node.JS are different. Even though node is created with JS it would be worthwhile learning Node.js to get an understanding of how it all runs.
