Error after update..
5 Posts 2 Posters 2.2k Views 2 Watching
    campos
    Hello. Yesterday installed the script. It worked immediately. Then I played something and tried - and then deleted. Today I wanted to reinstall it, but now get the following error
    pi@raspberrypi-Kueche:~ $ npm start
    npm ERR! Linux 4.9.28-v7+
    npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
    npm ERR! node v6.11.0
    npm ERR! npm  v3.10.10
    npm ERR! code ENOENT
    npm ERR! errno -2
    npm ERR! syscall open
    npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
    npm ERR! enoent This is most likely not a problem with npm itself
    npm ERR! enoent and is related to npm not being able to find a file.
    npm ERR! enoent
    npm ERR!     /home/pi/npm-debug.log
    Can someone help me or give a tip - would be super. greetings
    S 1 Reply Last reply Jul 2, 2017, 10:38 AM Reply Quote 0
      strawberry 3.141 Project Sponsor Module Developer @campos
      @campos you are in the wrong directory. do cd MagicMirror first
        campos
        Yes. But the same …pi@raspberrypi-Kueche:~ $ cd MagicMirror
        pi@raspberrypi-Kueche:~/MagicMirror $ npm start
        magicmirror@2.1.2 start /home/pi/MagicMirror
        sh run-start.sh
        /home/pi/MagicMirror/node_modules/electron/index.js:9
        throw new Error(‘Electron failed to install correctly, please delete node_modules/electron and try installing again’)
        Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
        at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:9:9)
        at Module._compile (module.js:570:32)
        at Object.Module._extensions…js (module.js:579:10)
        at Module.load (module.js:487:32)
        at tryModuleLoad (module.js:446:12)
        at Function.Module._load (module.js:438:3)
        at Module.require (module.js:497:17)
        at require (internal/module.js:20:19)
        at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
        npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “start”
        npm ERR! code ELIFECYCLE
        npm ERR! magicmirror@2.1.2 start: sh run-start.sh
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the magicmirror@2.1.2 start script ‘sh run-start.sh’.
        npm ERR! If you do, this is most likely a problem with the magicmirror package,
        npm ERR! not with npm itself.
        npm ERR! sh run-start.sh
        npm ERR! npm bugs magicmirror
        npm ERR! Or if that isn’t available, you can get their info via:
        npm ERR! npm owner ls magicmirror
        npm ERR! /home/pi/MagicMirror/npm-debug.log
        S 1 Reply Last reply Jul 2, 2017, 10:58 AM Reply Quote 0
          @campos
            campos
            Ah. I got it after a long time back and forth. Once again deleted and the folder copied again. Many thanks for your help.
