Solved Analog + Digital Clock module
I’m on the road at the moment so I can’t give you a detailed answer, but you can clone the develop branch instead of the master one:
git clone - b develop http://github.com/MichMich/MagicMirror
Warning: it will overwrite any changes you may have made to local files, just be aware of that.
It’s in the master branch now … :)
Thanks alot mate… :bow:
@Kevin, as a side note, if there’s a particular clock face that you like me to create for you, let me know. If you have an example, that will greatly help.
Works great, just one question. I want to put the analog clock in the top_center and don’t want to show the date because I have the digital clock in the top_right position. How do I turn off the date from showing on a 2nd clock module?
At the moment, it’s hard coded in. I’d have to add a config option so it can be turned off when used as a separate module.
Ok, I have it in my dev branch, but I won’t push it up just yet. I’ll wait a bit to see if there are other things that people will request or fixes. But if you must get rid of it now, you can manually edit the
'clock.js'
file and delete line 173:169: } else if (this.config.displayType === 'analog') { 170: // Display only an analog clock 171: dateWrapper.style.textAlign = "center"; 172: dateWrapper.style.paddingBottom = "15px"; 173: wrapper.appendChild(dateWrapper); <===== that line 174: wrapper.appendChild(clockCircle); 175: } else {
It will only affect the analog clock when used as a separate module as a single clock.
I should point out that this is just a temporary thing, so you can get rid of it. The updated code will give you a config option to disable it, show it above, or below the clock.
@pugsly, I forgot to mention this: new code has been added to the
'develop'
branch that allows you to turn off the date display when using the module in analog mode only. Options are'top'
(default) to have it displayed at the top of the clock,'bottom'
to show it on the bottom, or'false'
to completely turn it off. -
someone know why this happend to me after updating MM:
everything looks fine just the analag clock.
