    MMM-Chart - View your graphs on your Mirror
    21 Posts 8 Posters 21.9k Views 10 Watching
    • SnilleS Offline
      Snille Module Developer
      @d3r Hi! Thank you. Not directly, but if you build a script (maybe in node or in PHP) that parse the file and present the data in the form of JSON, it is possible.
      If you cant find it, make it and share it!
      Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
      • SnilleS Offline
        Hi all! I finally tried out the Chart module on a RPi3 (Jessie Lite install) with the latest MM2. But I can’t get the graphs to show. Is there anyone out there using my module who have it working?
        The charts work fine in Chrome or Firefox on another machine… That’s how I developed the module. :)
        • L Offline
          logen563
          Hello!
          I’m using dht22 modul wich is working fine, and tough will give a try with this module. I used this how-to ( http://www.instructables.com/id/Raspberry-PI-and-DHT22-temperature-and-humidity-lo/ ) to log the temps, and this php script to generate the json: ( http://www.kodingmadesimple.com/2015/01/convert-mysql-to-json-using-php.html )
          php
              //open connection to mysql db
              $connection = mysqli_connect("localhost","logger","password","temperatures") or die("Error " . mysqli_error($connection));
            //fetch table rows from mysql db
              $sql = "select * from temperaturedata";
              $result = mysqli_query($connection, $sql) or die("Error in Selecting " . mysqli_error($connection));
           //create an array
              $emparray = array();
              while($row =mysqli_fetch_assoc($result))
                  $emparray[] = $row['dateandtime'];
                  $emparray[] = $row['temperature'];
                  $emparray[] = $row['humidity'];
               echo json_encode($emparray);
          //close the db connection
              mysqli_close($connection);
          This give me this result:
          [“2017-07-06 11:37:59”,“26.3”,“46.9”,“2017-07-06 11:45:02”,“26.3”,“46.1”,“2017-07-06 11:50:01”,“26.4”,“45.7”,… and so on ]
          I set the correct url in the config, but I cant get it to work :( Maybe the result is not right?
          • SnilleS Offline
            and the whole “set” also needs to be inside [ ] as well. :)
            Here is some of my config… This is one of my graphs.
            	module: 'MMM-Chart',
            	position: 'top_center',
            	header: 'Temp & Fukt Ute senaste 24 timmarna',
            		url: "http://10.0.0.20/housedata/housedata.php?id=9,10&max=24&sort=desc",
            		graphStyle: "line",
            		xaxisLabelTicks: true,
            		updateInterval: 600000,
            		graphFill0: true,
            		graphLabel0: "Temp ute C",
            		graphLineColor0: "rgba(200, 200, 200, 1)",
            		graphTickColor0: "rgba(200, 200, 200, 1)",
            		graphFillColor0: "rgba(200, 200, 200, 0.2)",
            		graphFill1: true,
            		graphLabel1: "Fukt ute %",
            		graphLineColor1: "rgba(100, 100, 155, 1)",
            		graphTickColor1: "rgba(100, 100, 155, 1)",
            		graphFillColor1: "rgba(100, 100, 155, 0.2)",
            		xaxisTimeUnit: "hour",
            		xaxisTimeFormatLabels: "HH",
            And the JSON looks like this:
            [["2017-07-07 08:56:00",16.9,85],["2017-07-07 06:58:00",13.4,91.3],["2017-07-07 05:54:00",13.3,90.4],["2017-07-07 05:02:00",13.4,89.2],["2017-07-07 03:58:00",13.6,88.2],["2017-07-07 02:55:00",13.6,90],["2017-07-07 01:50:00",13.5,91.9],["2017-07-07 00:57:00",13.6,92.6],["2017-07-06 23:54:00",13.6,90],["2017-07-06 20:55:00",20.1,67.9],["2017-07-06 19:50:00",27.1,52.3],["2017-07-06 18:57:00",25.5,55.1],["2017-07-06 17:54:00",22.4,58.1],["2017-07-06 17:02:00",22.6,66.3],["2017-07-06 15:59:00",22.1,64.4],["2017-07-06 14:56:00",22,65.7],["2017-07-06 13:49:00",21.1,66],["2017-07-06 12:57:00",19.8,66.9],["2017-07-06 11:54:00",18.7,67.1],["2017-07-06 11:01:00",17.6,75.8],["2017-07-06 09:59:00",16.5,79.7],["2017-07-06 07:50:00",12,95.5],["2017-07-06 06:58:00",10.6,98.2],["2017-07-06 05:54:00",9.4,97.7]]
            I think the missing fist (and last) “[” “]” may be the problem. :)
            • L Offline
              logen563 @Snille
              @Snille :) thanks! How do I add them? Can you send me the php script you are using? It will be a big help for me ! Thx
              • SnilleS Offline
                Hi, this is a part of my php pickup/conversion script…
                I hope this can help you. :)
                // Get all the data from the database.
                foreach ($ids as $i => $idnum) {
                	//Fetches the data from MYSQL via PDO.
                	$values[] = getvalues($dbservername, $dbname, $dbusername, $dbpassword, $deftable, $defsensoridcolumn, $max, $ids[$i], $sort);
                // Initialize the array.
                $outarray = array();
                $first = 0;
                foreach ($values as $key => $value) {
                	$position = 0;
                	foreach ($values[$key] as $i => $value) {
                		If ($first == 0) {
                			$outarray[$position][] = $values[$key][$i]["time"];
                		$outarray[$position][] = floatval($values[$key][$i]["value"]);
                		$position++;
                	$first++;
                // Make it JSON.
                $json = json_encode($outarray);
                // Print it.
                echo $json;
                • L Offline
                  logen563 @Snille
                  @Snille Thanks! Will try this ! I will let you know the results :)
                  • L Offline
                    logen563
                    Finally it’s working :) Thanks for the help. I use googlespread sheet, csv export, and php to convert it to json. If some somebody interested I can give some help.
                      schmo90
                      Hy it was quite hard to get the dht22 values showing up with your chart.
                      finally i got the php script working to fetch mysql data to your json format:
                      //your code here
                          $connection = mysqli_connect("localhost","logger","password","temperatures") or die("Err$
                              $result = mysqli_query($connection, $sql) or die("Error in Selecting " . mysqli_erro$
                              //create an array
                              $position=0;
                                      $emparray[$position][] = $row['dateandtime'];
                                      $emparray[$position][] = $row['temperature'];
                                      $emparray[$position][] = $row['humidity'];
                                      $position++;
                        schmo90
                        Hy i also have troubles with the real time chart.
                        it shows the chart only for 0,5s and then it will disapear?
                        do you ever had this issue?
                        and is it possible to ad more ticks on the x-axis?
                        if i display temp data from a day, it will only show two ticks
