Unsolved System temperature : fetching...
@sebastiensaucier That’s weird … do you see any weird messages in the terminal?
No just the normal text:
Just a thought, but could CPU load have anything to do with it?
It’s around 10% of usage. So I don’t think it can cause the problem.
@sebastiensaucier could you modify the node_helper
change:
self.sendSocketNotification('TEMPERATURE', stdout.replace('temp=','').replace('\'','\°'));
to:
var temperature = stdout.replace('temp=','').replace('\'','\°'); console.log('Temperature: ' + temperature); self.sendSocketNotification('TEMPERATURE', temperature);
And see if the temperature is logged?
Nothing in the console. Where can I see the logs?
Also, I tried to erease all and do all the readme again, but nothing changed.
You can see the logs inside your terminal session. If you use
pm2
executepm2 logs mm
to see the log! :)
