magic-mirror-voice
8 Posts 3 Posters 3.4k Views 3 Watching
    A Former User
    While I had no problems to get the sample app to work,
    I have problems with the module installation - It will not work.
    When I do the npm install in the magic-mirror-voice directory, I get
    magic-mirror-voice@1.0.0 No repository field
    at the end.
    What does it mean ? And could this be the reason that it does not work ?
    How can I do more tests ? Setting debug : true does not give me anything.
    Thanks.
    S ? 2 Replies Last reply Jul 25, 2017, 10:38 AM Reply Quote 0
      strawberry 3.141 Project Sponsor Module Developer @Guest
      @howi42 magic-mirror-voice@1.0.0 No repository field is just a warning and can be ignored by your side
        A Former User @Guest
          A Former User
          Thanks.
          I am probably missunderstanding the instructions, as I have the feeling that things are missing.
          When doing the sample app, a lot of actions had to be done at the end, through terminals.
          Is something similar to this not needed to get the module up and running ?
          Thanks.
            A Former User
            Is there a way to debug this module ?
            does not seem to do anything.
            On the screen is says :
            Loading…
            but that seems to stay there forever.
            Thanks.
            S 1 Reply Last reply Jul 27, 2017, 11:31 AM Reply Quote 0
              @howi42 after a quick look into the module, it seems that the module doen’t make use of it’s config option debug
                A Former User
                Here is an error message ( when starting as serveronly ):
                Whoops! There was an uncaught exception…
                { Error: Cannot find module ‘…/build/jvm_dll_path.json’
                at Function.Module._resolveFilename (module.js:469:15)
                at Function.Module._load (module.js:417:25)
                at Module.require (module.js:497:17)
                at require (internal/module.js:20:19)
                at Object. (/home/pi/MagicMirror/modules/magic-mirror-voice/node_modules/java/lib/nodeJavaBridge.js:3:21)
                at Module._compile (module.js:570:32)
                at Object.Module._extensions…js (module.js:579:10)
                at Module.load (module.js:487:32)
                at tryModuleLoad (module.js:446:12)
                at Function.Module._load (module.js:438:3)
                at Object. (/home/pi/MagicMirror/modules/magic-mirror-voice/node_modules/java/index.js:2:18)
                at Module.load (module.js:487:32) code: ‘MODULE_NOT_FOUND’ }
                Anything I can do ?
                  A Former User
                  Working my way through errors …
                  I am able to get it to load ( in serveronly mode ) :
                  After some time a message says :
                  Register Alexa Java Client by navigating to https://localhost:5555/provision/xxxxxxxxxxxxxxxxxxxxxxx
                  I have to do this manually to make the loading continue.
                  It then throws an error message, tells me that the client is registered with a token, finishes loading and when I say mirror mirror, I can talk to Alexa
                  and get an answer, but :
                  • the trigger works only once
                  • registering to get a token is fine, but not for each reboot/restart
                  • running not via serveronly will not work because of that
                  Here is probably something still wrong.
                  Any ideas ?
