Final Step of Installing MagicMirror (EXTREME NOOB)
4 Posts 2 Posters 1.5k Views 2 Watching
  • H Offline
    hall1458
    I followed the step-by-step instructions very closely (at least I thought), but I’m running into a problem at the very last step. I’m not familiar with working in the terminal, so I don’t really know what’s wrong even though I’m sure it’s a simple fix. The error code is below and the debug file is below that. Any help would be appreciated.
    //pi@raspberrypihall1458:~ $ cd MagicMirror/config
    pi@raspberrypihall1458:~/MagicMirror/config $ cp config.js.sample config.js
    pi@raspberrypihall1458:~/MagicMirror/config $ cd $HOME/MagicMirror
    pi@raspberrypihall1458:~/MagicMirror $ npm start
    > magicmirror@2.1.2 start /home/pi/MagicMirror
    > sh run-start.sh
    run-start.sh: 4: run-start.sh: electron: not found
    npm ERR! Linux 4.9.39-v7+
    npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
    npm ERR! node v6.11.1
    npm ERR! npm  v3.10.10
    npm ERR! file sh
    npm ERR! code ELIFECYCLE
    npm ERR! errno ENOENT
    npm ERR! syscall spawn
    npm ERR! magicmirror@2.1.2 start: `sh run-start.sh`
    npm ERR! spawn ENOENT
    npm ERR!
    npm ERR! Failed at the magicmirror@2.1.2 start script 'sh run-start.sh'.
    npm ERR! If you do, this is most likely a problem with the magicmirror package,
    npm ERR! not with npm itself.
    npm ERR!     sh run-start.sh
    npm ERR!     npm bugs magicmirror
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR!     npm owner ls magicmirror
    npm ERR!     /home/pi/MagicMirror/npm-debug.log
    ******* DEBUG FILE ********
    1 verbose cli [ '/usr/bin/nodejs', '/usr/bin/npm', 'start' ]
    2 info using npm@3.10.10
    3 info using node@v6.11.1
    5 info lifecycle magicmirror@2.1.2~prestart: magicmirror@2.1.2
    6 silly lifecycle magicmirror@2.1.2~prestart: no script for prestart, continuing
    7 info lifecycle magicmirror@2.1.2~start: magicmirror@2.1.2
    8 verbose lifecycle magicmirror@2.1.2~start: unsafe-perm in lifecycle true
    9 verbose lifecycle magicmirror@2.1.2~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
    10 verbose lifecycle magicmirror@2.1.2~start: CWD: /home/pi/MagicMirror
    11 silly lifecycle magicmirror@2.1.2~start: Args: [ '-c', 'sh run-start.sh' ]
    12 info lifecycle magicmirror@2.1.2~start: Failed to exec start script
    13 verbose stack Error: magicmirror@2.1.2 start: `sh run-start.sh`
    13 verbose stack spawn ENOENT
    13 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:33:16)
    13 verbose stack     at emitTwo (events.js:106:13)
    13 verbose stack     at ChildProcess.emit (events.js:191:7)
    13 verbose stack     at maybeClose (internal/child_process.js:891:16)
    13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
    14 verbose pkgid magicmirror@2.1.2
    15 verbose cwd /home/pi/MagicMirror
    16 error Linux 4.9.39-v7+
    17 error argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
    18 error node v6.11.1
    19 error npm  v3.10.10
    20 error file sh
    21 error code ELIFECYCLE
    22 error errno ENOENT
    23 error syscall spawn
    24 error magicmirror@2.1.2 start: `sh run-start.sh`
    24 error spawn ENOENT
    25 error Failed at the magicmirror@2.1.2 start script 'sh run-start.sh'.
    25 error Make sure you have the latest version of node.js and npm installed.
    25 error If you do, this is most likely a problem with the magicmirror package,
    25 error not with npm itself.
    25 error Tell the author that this fails on your system:
    25 error     sh run-start.sh
    25 error You can get information on how to open an issue for this project with:
    25 error     npm bugs magicmirror
    25 error Or if that isn't available, you can get their info via:
    25 error     npm owner ls magicmirror
    25 error There is likely additional logging output above.
    26 verbose exit [ 1, true ]
    Thanks!
    S 1 Reply Last reply Jul 25, 2017, 10:34 AM Reply Quote 0
      strawberry 3.141 Project Sponsor Module Developer @hall1458
      @hall1458 did you install the dependencies with npm install?
      • H Offline
        hall1458
        No I don’t think so, and that must be my issue. I don’t see this in the complete setup instructions though. Where would I install the dependencies? Again, I’m very new to this so I’m probably missing it. Thanks for the help.
        S 1 Reply Last reply Jul 25, 2017, 4:07 PM Reply Quote 0
          @hall1458 cd ~/MagicMirror then npm install
