    Telegram Bot
    5 Posts 5 Posters 5.0k Views 4 Watching
      clubbi
      Hey.
      After I experimented with the Google Hangoutsbot for a while, I am now at the Telegrambot. Currently my telegrambot sends me a simple message if the CPU temperature is too high. For this I ‘quickndirty’ inserted a few lines of code into the forked MMM-SystemStats module:
      	var url="https://api.telegram.org/bot[BOT-TOKEN]/sendMessage?chat_id=[CHAT-ID]&text=CPU%20zu%20warm%20";
      	var method = "POST";
      	var postData = "Some data";
      	var async = true;
      	var request = new XMLHttpRequest();
      	request.onload = function () {
      	var status = request.status; // HTTP response status, e.g., 200 for "200 OK"
      	var data = request.responseText; // Returned data, e.g., an HTML document.
      	request.open(method, url, async);
      	request.setRequestHeader("Content-Type", "application/json;charset=UTF-8");
      	request.send(postData);
      It would be great if, for example, also MMM-Syslog, MMM-PIR or MMM-NetworkScanner sends messages, as good as centrally via a Telegram module.
      For example https://github.com/enricostara/telegram.link or https://github.com/yagop/node-telegram-bot-api.
      Thank you.
      R cowboysdudeC 2 Replies Last reply
        clubbi
        I’ve updated the MMM-SystemStats module on github.
        Now the request is sent by nodehelper.js.
        request({ url:  'https://api.telegram.org/bot' + this.config.botToken + '/sendMessage?chat_id=' + this.config.chatID + '&text=' + encodeURI(payload.message), method: 'POST' }, function(error, response, body) {
        console.log("TG with response " + response.statusCode);
        It is not a separate module, but it works.
          ryck Module Developer @clubbi
          @clubbi maybe you could implement this in a separate module, implementing sendNotification / notificationReceived ?
          C 1 Reply Last reply
          • cowboysdudeC
            cowboysdude Module Developer @clubbi
            @clubbi said in Telegram Bot:
            Telegrambot.
            Why don’t you just use something like this
            https://www.npmjs.com/package/telegram-bot-api
              clubbi @ryck
              @ryck
              Currently, I do not have much time, but I’ll keep it in mind.
              @cowboysdude
              ah, ok. thanks.
