    Home made 60" touch Magic Mirror
    41 Posts 13 Posters 72.5k Views 16 Watching
      scooter @MMScreen
      Hi Martin 70/30 mirror view from http://www.mirrorsandglass.co.uk
      I used 7mm ply as that was what i had,no you must build your own frame ,i will try to post a pic of mine.
      regards
        MMScreen @scooter
        @scooter Thank you Jim. I’ve ordered my IR now but not sure about how to build a frame. Did you purcase the frame material from a website online that you could share? Thanks again in advance, very much appreciated for all of your help.
          MMScreen
          Hi Scooter, I hope you’re well.
          I haveing a hard time trying to find the material to build a frame. I would like to build a frame like this one as shown here: https://www.photobooths.co.uk/product/white-silver-magic-mirror-frame/ however can’t find the material anywhere online! It is a very wide frame, approx. 90mm width (very much wider than normal photo frames).
          Any idea where I can get a length of this material to make into a frame?
          Any help massively appreciated!!
          Thanks,
          Martin.
            mirroronthewall
            Looks great scooter!
            Did you use the Pilkington 6mm MirroView mirror or 6mm Two-Way Mirror?
            Also is it possible to mount the camera behind the mirror?
            Cheers!
            • H Offline
              Hoosierdad
              @scooter is there anyway you can take pictures / close ups of the LED strip and frame. I just ordered my glass and IR frame curious how you put yours together.
              also how do you secure the glass and IR fram in the back of the picture frame. thanks
              • K Offline
                krisalexroberts @scooter
                @scooter did you write the software yourself?
                  cyberphox
                  Seems Scooter is MIA
                  • Scatha20S Offline
                    Scatha20
                    Any updates ? I want to build my own Magic Mirror Photobooth, but It hard to find accurate info. Any help?
                      cyberphox @Scatha20
                      @scatha20 Got mine up and running…
                      Scatha20S 1 Reply Last reply Reply Quote 0
                      • Scatha20S Offline
                        Scatha20 @cyberphox
                        @cyberphox that awersome!!! I am loving it!
                        My i ask you about the front? I ordered 60’’ mirror view 70/25 , i have 49’’ smart tv at home. But my biggest concern is the front. IR screen needs to go on the top of the mirror? Its only a frame? a foil? or a glass put inside IR frame place on the top of the mirror?
                        I am really confused.
                        • 2 / 5
