    How I got my Magic Mirror working on a Raspberry Pi 0 (zero)
    raspberry pipi0zeropizeropi1
    204 Posts 47 Posters 666.6k Views 47 Watching
      dantodd
      have you tried just using “npm start” in ssh? That works for me.
        RV @dantodd
        @dantodd you mean every time i start my rasp on i need to type npm start?
        D B 2 Replies Last reply Reply Quote 0
        • H
          Hawking
          @RV said in How I got my Magic Mirror working on a Raspberry Pi 0 (zero):
          no, that is definitely not necessary.
          I don’t know the reason for the error message (is there actually a space between localhost: and 8080?). What happens if you run
          node serveronly &
          manually?
            dantodd @RV
            Automating the process is fairly simple but let’s get you up and running first. You should also check your permissions in the config.js file. Make sure that your whitelist is properly configured.
              braik @RV
              @RV Hi, I don’t know if it can help, but I have noticed that the “~” shortcut to go tho the /home/pi folder does not work on the scripts.
              So when you do the same commands manually everything seems to be OK, but when you run the scripts then you get a bug.
              The solution, in my case, was to replace all the folder shortcuts (as ~ for home folder) with the complete explicit path inside the scripts.
              Good luck
              Braik
                RV @braik
                @braik as i said before i am not that experienced with Python, Linux or what so ever. I think you are right on this one. When i typed cd /home/pi/ i didn’t get a response or anything.
                I hope you can show me how to replace the folder, like you have told me before.
                • H
                  Hawking @RV
                  This sounds strange. Did you type it in the unit terminal? cd is the comand to change directory. Maybe you have already been in the /home/pi/ directory (than the change would have no effect). Could you type pwd (print working directory)
                  and give the result before and after the cd /home/pi/ command and give the results?
                    12wsx
                    Hello. I installed image of SebTota everything work, but i had to update and after put: "git pull"my MM don,t get up.
                    error
                    1 verbose cli [ '/usr/local/bin/node', '/usr/local/bin/npm', 'start' ]
                    2 info using npm@2.14.7
                    3 info using node@v4.2.1
                    5 info prestart magicmirror@2.1.2
                    6 info start magicmirror@2.1.2
                    7 verbose unsafe-perm in lifecycle true
                    8 info magicmirror@2.1.2 Failed to exec start script
                    9 verbose stack Error: magicmirror@2.1.2 start: `sh run-start.sh`
                    9 verbose stack spawn ENOENT
                    9 verbose stack     at ChildProcess. (/usr/local/lib/node_modules/npm/lib/utils/spawn.js:17:16)
                    9 verbose stack     at emitTwo (events.js:87:13)
                    9 verbose stack     at ChildProcess.emit (events.js:172:7)
                    9 verbose stack     at maybeClose (internal/child_process.js:818:16)
                    9 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:211:5)
                    10 verbose pkgid magicmirror@2.1.2
                    11 verbose cwd /home/pi/MagicMirror
                    12 error Linux 4.4.34+
                    13 error argv "/usr/local/bin/node" "/usr/local/bin/npm" "start"
                    14 error node v4.2.1
                    15 error npm  v2.14.7
                    16 error file sh
                    17 error code ELIFECYCLE
                    18 error errno ENOENT
                    19 error syscall spawn
                    20 error magicmirror@2.1.2 start: `sh run-start.sh`
                    20 error spawn ENOENT
                    21 error Failed at the magicmirror@2.1.2 start script 'sh run-start.sh'.
                    21 error This is most likely a problem with the magicmirror package,
                    21 error not with npm itself.
                    21 error Tell the author that this fails on your system:
                    21 error     sh run-start.sh
                    21 error You can get their info via:
                    21 error     npm owner ls magicmirror
                    21 error There is likely additional logging output above.
                    22 verbose exit [ 1, true ]
                    ```how can i resolved this problem?
                      12wsx
                      Today after reinstall and try to update cd /MagicMirror git pull my MagicMirror won’t start up
                      full log update
                      Starting MagicMirror: v2.1.0
                      Loading config ...
                      Loading module helpers ...
                      All module helpers loaded.
                      Starting server op port 8080 ...
                      Server started ...
                      Starting module: newsfeed
                      Ready to go! Please point your browser to: http://localhost:8080
                      { [Error: listen EADDRINUSE :::8080]
                        code: 'EADDRINUSE',
                        errno: 'EADDRINUSE',
                        syscall: 'listen',
                        address: '::',
                        port: 8080 }
                      MagicMirror will not quit, but it might be a good idea to check why this happene        d. Maybe no internet connection?
                      If you think this really is an issue, please open an issue on GitHub: https://gi        thub.com/MichMich/MagicMirror/issues
                      (EE)
                      Fatal server error:
                      (EE) Server is already active for display 0
                              If this server is no longer running, remove /tmp/.X0-lock
                              and start again.
                      (EE)
                      (EE)
                      Please consult the The X.Org Foundation support
                               at http://wiki.x.org
                       for help.
                      (EE)
                      XIO:  fatal IO error 11 (Resource temporarily unavailable) on X server ":0"
                            after 7 requests (7 known processed) with 0 events remaining.
                      root@raspberrypi:/home/pi/MagicMirror# git pull
                      Updating 8010e62..8a101f9
                      Fast-forward
                       .eslintignore                                                 |     4 +-
                       .github/PULL_REQUEST_TEMPLATE.md                              |     7 +
                       .gitignore                                                    |    13 +-
                       .travis.yml                                                   |    11 +-
                       CHANGELOG.md                                                  |   114 +-
                       Gruntfile.js                                                  |    48 +-
                       LICENSE.md                                                    |     2 +-
                       README.md                                                     |    56 +-
                       config/config.js.sample                                       |    62 +-
                       css/main.css                                                  |    12 +
                       index.html                                                    |     8 +-
                       installers/mm.sh                                              |     2 +
                       installers/pm2_MagicMirror.json                               |     7 +
                       installers/postinstall/postinstall.sh                         |     2 +
                       installers/raspberry.sh                                       |    36 +-
                       js/app.js                                                     |   103 +-
                       js/defaults.js                                                |     7 +-
                       js/deprecated.js                                              |    14 +
                       js/electron.js                                                |     8 +-
                       js/loader.js                                                  |    16 +-
                       js/main.js                                                    |    56 +-
                       js/module.js                                                  |    69 +-
                       js/server.js                                                  |    32 +-
                       js/socketclient.js                                            |     1 -
                       js/translator.js                                              |    27 +-
                       js/utils.js                                                   |    19 +
                       modules/README.md                                             |   142 +-
                       modules/default/alert/README.md                               |   149 +-
                       modules/default/alert/alert.js                                |     3 +-
                       modules/default/alert/translations/hu.json                    |     4 +
                       modules/default/alert/translations/nl.json                    |     4 +
                       modules/default/alert/translations/ru.json                    |     4 +
                       modules/default/calendar/README.md                            |   236 +--
                       modules/default/calendar/calendar.css                         |     2 +
                       modules/default/calendar/calendar.js                          |   224 ++-
                       modules/default/calendar/calendarfetcher.js                   |    34 +-
                       modules/default/calendar/debug.js                             |    14 +-
                       modules/default/calendar/node_helper.js                       |     7 +-
                       modules/default/calendar/vendor/ical.js/ical.js               |    12 +-
                       modules/default/calendar/vendor/ical.js/node-ical.js          |    13 +-
                       modules/default/clock/README.md                               |   124 +-
                       modules/default/clock/clock.js                                |    79 +-
                       modules/default/clock/clock_styles.css                        |     2 +-
                       modules/default/compliments/README.md                         |   121 +-
                       modules/default/compliments/compliments.js                    |    36 +-
                       modules/default/currentweather/README.md                      |   248 +--
                       modules/default/currentweather/currentweather.css             |     3 +-
                       modules/default/currentweather/currentweather.js              |    64 +-
                       modules/default/helloworld/README.md                          |    29 +-
                       modules/default/newsfeed/README.md                            |   189 +-
                       modules/default/newsfeed/fetcher.js                           |     7 +-
                       modules/default/newsfeed/newsfeed.js                          |   113 +-
                       modules/default/newsfeed/node_helper.js                       |    11 +-
                       modules/default/updatenotification/README.md                  |    25 +-
                       modules/default/weatherforecast/README.md                     |   223 +--
                       modules/default/weatherforecast/weatherforecast.css           |     8 +
                       modules/default/weatherforecast/weatherforecast.js            |    28 +-
                       modules/node_modules/node_helper/index.js                     |    20 +-
                       package.json                                                  |    40 +-
                       run-start.sh                                                  |     4 +
                       splashscreen/MagicMirror.script                               |    17 +-
                       splashscreen/splash.png                                       |   Bin 19820 -> 37062 bytes
                       splashscreen/splash_halt.png                                  |   Bin 0 -> 22304 bytes
                       tests/configs/check_config.js                                 |    66 +
                       tests/configs/data/calendar_test.ics                          |   190 ++
                       tests/configs/data/feed_test_rodrigoramirez.xml               |   410 +++++
                       tests/configs/empty_ipWhiteList.js                            |    25 +
                       tests/configs/env.js                                          |    25 +
                       tests/configs/modules/calendar/auth-default.js                |    41 +
                       tests/configs/modules/calendar/basic-auth.js                  |    42 +
                       tests/configs/modules/calendar/default.js                     |    37 +
                       tests/configs/modules/calendar/fail-basic-auth.js             |    44 +
                       tests/configs/modules/calendar/old-basic-auth.js              |    39 +
                       tests/configs/modules/clock/clock_12hr.js                     |    29 +
                       tests/configs/modules/clock/clock_24hr.js                     |    29 +
                       tests/configs/modules/clock/clock_displaySeconds_false.js     |    32 +
                       tests/configs/modules/clock/clock_showPeriodUpper.js          |    32 +
                       tests/configs/modules/clock/clock_showWeek.js                 |    32 +
                       tests/configs/modules/clock/es/clock_12hr.js                  |    29 +
                       tests/configs/modules/clock/es/clock_24hr.js                  |    29 +
                       tests/configs/modules/clock/es/clock_showPeriodUpper.js       |    32 +
                       tests/configs/modules/compliments/compliments_anytime.js      |    38 +
                       tests/configs/modules/compliments/compliments_only_anytime.js |    35 +
                       tests/configs/modules/compliments/compliments_parts_day.js    |    42 +
                       tests/configs/modules/helloworld/helloworld.js                |    32 +
                       tests/configs/modules/newsfeed/default.js                     |    38 +
                       tests/configs/modules/positions.js                            |    43 +
                       tests/configs/noIpWhiteList.js                                |    25 +
                       tests/configs/port_8090.js                                    |    25 +
                       tests/configs/without_modules.js                              |    23 +
                       tests/e2e/dev_console.js                                      |    51 +
                       tests/e2e/env_spec.js                                         |    47 +
                       tests/e2e/global-setup.js                                     |    34 +
                       tests/e2e/ipWhistlist_spec.js                                 |    46 +
                       tests/e2e/modules/calendar_spec.js                            |    81 +
                       tests/e2e/modules/clock_es_spec.js                            |    81 +
                       tests/e2e/modules/clock_spec.js                               |   134 ++
                       tests/e2e/modules/compliments_spec.js                         |    95 +
                       tests/e2e/modules/helloworld_spec.js                          |    24 +
                       tests/e2e/modules/newsfeed_spec.js                            |    28 +
                       tests/e2e/modules_position_spec.js                            |    42 +
                       tests/e2e/port_config.js                                      |    51 +
                       tests/e2e/vendor_spec.js                                      |    36 +
                       tests/e2e/without_modules.js                                  |    53 +
                       tests/servers/basic-auth.js                                   |    30 +
                       tests/unit/functions/calendar_spec.js                         |    36 +
                       tests/unit/functions/cmp_versions_spec.js                     |    20 +
                       tests/unit/global_vars/defaults_modules_spec.js               |    66 +
                       tests/unit/global_vars/root_path_spec.js                      |    71 +
                       tests/unit/translations/same_keys.js                          |   115 ++
                       translations/af.json                                          |    30 +
                       translations/da.json                                          |     6 +-
                       translations/de.json                                          |     6 +-
                       translations/en.json                                          |     6 +-
                       translations/es.json                                          |     6 +-
                       translations/et.json                                          |    30 +
                       translations/fi.json                                          |    11 +-
                       translations/fr.json                                          |     3 -
                       translations/fy.json                                          |     3 -
                       translations/gr.json                                          |     3 -
                       translations/hu.json                                          |    30 +
                       translations/id.json                                          |    30 +
                       translations/is.json                                          |    30 +
                       translations/it.json                                          |     3 -
                       translations/ja.json                                          |     5 +-
                       translations/kr.json                                          |    30 +
                       translations/nb.json                                          |    12 +-
                       translations/nl.json                                          |     4 -
                       translations/nn.json                                          |    10 +-
                       translations/pl.json                                          |    13 +-
                       translations/pt.json                                          |    11 +-
                       translations/pt_br.json                                       |     3 -
                       translations/ro.json                                          |    32 +
                       translations/ru.json                                          |    32 +
                       translations/sv.json                                          |    16 +-
                       translations/tr.json                                          |     3 -
                       translations/translations.js                                  |    10 +
                       translations/zh_cn.json                                       |    10 +-
                       translations/zh_tw.json                                       |     3 -
                       vendor/font-awesome-4.5.0/HELP-US-OUT.txt                     |     7 -
                       vendor/font-awesome-4.5.0/css/font-awesome.css                |  2086 ----------------------
                       vendor/font-awesome-4.5.0/css/font-awesome.min.css            |     4 -
                       vendor/font-awesome-4.5.0/fonts/FontAwesome.otf               |   Bin 109688 -> 0 bytes
                       vendor/font-awesome-4.5.0/fonts/fontawesome-webfont.eot       |   Bin 70807 -> 0 bytes
                       vendor/font-awesome-4.5.0/fonts/fontawesome-webfont.svg       |   655 -------
                       vendor/font-awesome-4.5.0/fonts/fontawesome-webfont.ttf       |   Bin 142072 -> 0 bytes
                       vendor/font-awesome-4.5.0/fonts/fontawesome-webfont.woff      |   Bin 83588 -> 0 bytes
                       vendor/font-awesome-4.5.0/fonts/fontawesome-webfont.woff2     |   Bin 66624 -> 0 bytes
                       vendor/font-awesome-4.5.0/less/animated.less                  |    34 -
                       vendor/font-awesome-4.5.0/less/bordered-pulled.less           |    25 -
                       vendor/font-awesome-4.5.0/less/core.less                      |    12 -
                       vendor/font-awesome-4.5.0/less/fixed-width.less               |     6 -
                       vendor/font-awesome-4.5.0/less/font-awesome.less              |    17 -
                       vendor/font-awesome-4.5.0/less/icons.less                     |   697 --------
                       vendor/font-awesome-4.5.0/less/larger.less                    |    13 -
                       vendor/font-awesome-4.5.0/less/list.less                      |    19 -
                       vendor/font-awesome-4.5.0/less/mixins.less                    |    26 -
                       vendor/font-awesome-4.5.0/less/path.less                      |    15 -
                       vendor/font-awesome-4.5.0/less/rotated-flipped.less           |    20 -
                       vendor/font-awesome-4.5.0/less/stacked.less                   |    20 -
                       vendor/font-awesome-4.5.0/less/variables.less                 |   708 --------
                       vendor/font-awesome-4.5.0/scss/_animated.scss                 |    34 -
                       vendor/font-awesome-4.5.0/scss/_bordered-pulled.scss          |    25 -
                       vendor/font-awesome-4.5.0/scss/_core.scss                     |    12 -
                       vendor/font-awesome-4.5.0/scss/_fixed-width.scss              |     6 -
                       vendor/font-awesome-4.5.0/scss/_icons.scss                    |   697 --------
                       vendor/font-awesome-4.5.0/scss/_larger.scss                   |    13 -
                       vendor/font-awesome-4.5.0/scss/_list.scss                     |    19 -
                       vendor/font-awesome-4.5.0/scss/_mixins.scss                   |    26 -
                       vendor/font-awesome-4.5.0/scss/_path.scss                     |    15 -
                       vendor/font-awesome-4.5.0/scss/_rotated-flipped.scss          |    20 -
                       vendor/font-awesome-4.5.0/scss/_stacked.scss                  |    20 -
                       vendor/font-awesome-4.5.0/scss/_variables.scss                |   708 --------
                       vendor/font-awesome-4.5.0/scss/font-awesome.scss              |    17 -
                       vendor/moment/moment-timezone.js                              |  1197 -------------
                       vendor/moment/moment-with-locales.js                          | 12061 -----------------------------------------------------------------------------------------------------------------------------
                       vendor/moment/moment-with-locales.min.js                      |    75 -
                       vendor/package.json                                           |    18 +
                       vendor/vendor.js                                              |    12 +-
                       vendor/weather-icons/css/weather-icons-wind.css               |  5331 -------------------------------------------------------
                       vendor/weather-icons/css/weather-icons-wind.min.css           |     1 -
                       vendor/weather-icons/css/weather-icons.css                    |  1838 -------------------
                       vendor/weather-icons/css/weather-icons.min.css                |    41 -
                       vendor/weather-icons/font/weathericons-regular-webfont.eot    |   Bin 99774 -> 0 bytes
                       vendor/weather-icons/font/weathericons-regular-webfont.svg    |   257 ---
                       vendor/weather-icons/font/weathericons-regular-webfont.ttf    |   Bin 99564 -> 0 bytes
                       vendor/weather-icons/font/weathericons-regular-webfont.woff   |   Bin 56468 -> 0 bytes
                       vendor/weather-icons/font/weathericons-regular-webfont.woff2  |   Bin 44720 -> 0 bytes
                       188 files changed, 4474 insertions(+), 28304 deletions(-)
                       create mode 100755 installers/mm.sh
                       create mode 100644 installers/pm2_MagicMirror.json
                       create mode 100644 installers/postinstall/postinstall.sh
                       create mode 100644 js/deprecated.js
                       create mode 100644 js/utils.js
                       create mode 100644 modules/default/alert/translations/hu.json
                       create mode 100644 modules/default/alert/translations/nl.json
                       create mode 100644 modules/default/alert/translations/ru.json
                       create mode 100644 run-start.sh
                       create mode 100644 splashscreen/splash_halt.png
                       create mode 100644 tests/configs/check_config.js
                       create mode 100644 tests/configs/data/calendar_test.ics
                       create mode 100644 tests/configs/data/feed_test_rodrigoramirez.xml
                       create mode 100644 tests/configs/empty_ipWhiteList.js
                       create mode 100644 tests/configs/env.js
                       create mode 100644 tests/configs/modules/calendar/auth-default.js
                       create mode 100644 tests/configs/modules/calendar/basic-auth.js
                       create mode 100644 tests/configs/modules/calendar/default.js
                       create mode 100644 tests/configs/modules/calendar/fail-basic-auth.js
                       create mode 100644 tests/configs/modules/calendar/old-basic-auth.js
                       create mode 100644 tests/configs/modules/clock/clock_12hr.js
                       create mode 100644 tests/configs/modules/clock/clock_24hr.js
                       create mode 100644 tests/configs/modules/clock/clock_displaySeconds_false.js
                       create mode 100644 tests/configs/modules/clock/clock_showPeriodUpper.js
                       create mode 100644 tests/configs/modules/clock/clock_showWeek.js
                       create mode 100644 tests/configs/modules/clock/es/clock_12hr.js
                       create mode 100644 tests/configs/modules/clock/es/clock_24hr.js
                       create mode 100644 tests/configs/modules/clock/es/clock_showPeriodUpper.js
                       create mode 100644 tests/configs/modules/compliments/compliments_anytime.js
                       create mode 100644 tests/configs/modules/compliments/compliments_only_anytime.js
                       create mode 100644 tests/configs/modules/compliments/compliments_parts_day.js
                       create mode 100644 tests/configs/modules/helloworld/helloworld.js
                       create mode 100644 tests/configs/modules/newsfeed/default.js
                       create mode 100644 tests/configs/modules/positions.js
                       create mode 100644 tests/configs/noIpWhiteList.js
                       create mode 100644 tests/configs/port_8090.js
                       create mode 100644 tests/configs/without_modules.js
                       create mode 100644 tests/e2e/dev_console.js
                       create mode 100644 tests/e2e/env_spec.js
                       create mode 100644 tests/e2e/global-setup.js
                       create mode 100644 tests/e2e/ipWhistlist_spec.js
                       create mode 100644 tests/e2e/modules/calendar_spec.js
                       create mode 100644 tests/e2e/modules/clock_es_spec.js
                       create mode 100644 tests/e2e/modules/clock_spec.js
                       create mode 100644 tests/e2e/modules/compliments_spec.js
                       create mode 100644 tests/e2e/modules/helloworld_spec.js
                       create mode 100644 tests/e2e/modules/newsfeed_spec.js
                       create mode 100644 tests/e2e/modules_position_spec.js
                       create mode 100644 tests/e2e/port_config.js
                       create mode 100644 tests/e2e/vendor_spec.js
                       create mode 100644 tests/e2e/without_modules.js
                       create mode 100644 tests/servers/basic-auth.js
                       create mode 100644 tests/unit/functions/calendar_spec.js
                       create mode 100644 tests/unit/functions/cmp_versions_spec.js
                       create mode 100644 tests/unit/global_vars/defaults_modules_spec.js
                       create mode 100644 tests/unit/global_vars/root_path_spec.js
                       create mode 100644 tests/unit/translations/same_keys.js
                       create mode 100644 translations/af.json
                       create mode 100644 translations/et.json
                       create mode 100644 translations/hu.json
                       create mode 100644 translations/id.json
                       create mode 100644 translations/is.json
                       create mode 100644 translations/kr.json
                       create mode 100644 translations/ro.json
                       create mode 100644 translations/ru.json
                       delete mode 100644 vendor/font-awesome-4.5.0/HELP-US-OUT.txt
                       delete mode 100644 vendor/font-awesome-4.5.0/css/font-awesome.css
                       delete mode 100644 vendor/font-awesome-4.5.0/css/font-awesome.min.css
                       delete mode 100644 vendor/font-awesome-4.5.0/fonts/FontAwesome.otf
                       delete mode 100644 vendor/font-awesome-4.5.0/fonts/fontawesome-webfont.eot
                       delete mode 100644 vendor/font-awesome-4.5.0/fonts/fontawesome-webfont.svg
                       delete mode 100644 vendor/font-awesome-4.5.0/fonts/fontawesome-webfont.ttf
                       delete mode 100644 vendor/font-awesome-4.5.0/fonts/fontawesome-webfont.woff
                       delete mode 100644 vendor/font-awesome-4.5.0/fonts/fontawesome-webfont.woff2
                       delete mode 100644 vendor/font-awesome-4.5.0/less/animated.less
                       delete mode 100644 vendor/font-awesome-4.5.0/less/bordered-pulled.less
                       delete mode 100644 vendor/font-awesome-4.5.0/less/core.less
                       delete mode 100644 vendor/font-awesome-4.5.0/less/fixed-width.less
                       delete mode 100644 vendor/font-awesome-4.5.0/less/font-awesome.less
                       delete mode 100644 vendor/font-awesome-4.5.0/less/icons.less
                       delete mode 100644 vendor/font-awesome-4.5.0/less/larger.less
                       delete mode 100644 vendor/font-awesome-4.5.0/less/list.less
                       delete mode 100644 vendor/font-awesome-4.5.0/less/mixins.less
                       delete mode 100644 vendor/font-awesome-4.5.0/less/path.less
                       delete mode 100644 vendor/font-awesome-4.5.0/less/rotated-flipped.less
                       delete mode 100644 vendor/font-awesome-4.5.0/less/stacked.less
                       delete mode 100644 vendor/font-awesome-4.5.0/less/variables.less
                       delete mode 100644 vendor/font-awesome-4.5.0/scss/_animated.scss
                       delete mode 100644 vendor/font-awesome-4.5.0/scss/_bordered-pulled.scss
                       delete mode 100644 vendor/font-awesome-4.5.0/scss/_core.scss
                       delete mode 100644 vendor/font-awesome-4.5.0/scss/_fixed-width.scss
                       delete mode 100644 vendor/font-awesome-4.5.0/scss/_icons.scss
                       delete mode 100644 vendor/font-awesome-4.5.0/scss/_larger.scss
                       delete mode 100644 vendor/font-awesome-4.5.0/scss/_list.scss
                       delete mode 100644 vendor/font-awesome-4.5.0/scss/_mixins.scss
                       delete mode 100644 vendor/font-awesome-4.5.0/scss/_path.scss
                       delete mode 100644 vendor/font-awesome-4.5.0/scss/_rotated-flipped.scss
                       delete mode 100644 vendor/font-awesome-4.5.0/scss/_stacked.scss
                       delete mode 100644 vendor/font-awesome-4.5.0/scss/_variables.scss
                       delete mode 100644 vendor/font-awesome-4.5.0/scss/font-awesome.scss
                       delete mode 100644 vendor/moment/moment-timezone.js
                       delete mode 100644 vendor/moment/moment-with-locales.js
                       delete mode 100644 vendor/moment/moment-with-locales.min.js
                       create mode 100644 vendor/package.json
                       delete mode 100644 vendor/weather-icons/css/weather-icons-wind.css
                       delete mode 100644 vendor/weather-icons/css/weather-icons-wind.min.css
                       delete mode 100644 vendor/weather-icons/css/weather-icons.css
                       delete mode 100644 vendor/weather-icons/css/weather-icons.min.css
                       delete mode 100755 vendor/weather-icons/font/weathericons-regular-webfont.eot
                       delete mode 100755 vendor/weather-icons/font/weathericons-regular-webfont.svg
                       delete mode 100755 vendor/weather-icons/font/weathericons-regular-webfont.ttf
                       delete mode 100755 vendor/weather-icons/font/weathericons-regular-webfont.woff
                       delete mode 100755 vendor/weather-icons/font/weathericons-regular-webfont.woff2
                      The programs included with the Debian GNU/Linux system are free software;
                      the exact distribution terms for each program are described in the
                      individual files in /usr/share/doc/*/copyright.
                      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                      permitted by applicable law.
                      Last login: Mon Aug  7 18:27:13 2017
                      SSH is enabled and the default password for the 'pi' user has not been changed.
                      This is a security risk - please login as the 'pi' user and type 'passwd' to set a new password.
                      module.js:339
                          throw err;
                      Error: Cannot find module 'colors/safe'
                          at Function.Module._resolveFilename (module.js:337:15)
                          at Function.Module._load (module.js:287:25)
                          at Module.require (module.js:366:17)
                          at require (module.js:385:17)
                          at Object. (/home/pi/MagicMirror/js/utils.js:9:14)
                          at Module._compile (module.js:435:26)
                          at Object.Module._extensions..js (module.js:442:10)
                          at Module.load (module.js:356:32)
                          at Function.Module._load (module.js:311:12)
                      (EE)
                      Fatal server error:
                              and start again.
                      (EE)
                      (EE)
                       for help.
                      (EE)
                      pi@raspberrypi:~ $
                      best regards
                      Dan
                        mmaino12 @12wsx
                        @12wsx That error log means that you already have a server running on port 8080. You need to kill the existing server and then restart your new mirror server with “npm start”.
                          delusional112
                          Hi guys,
                          Used the image from @SebTota. MM2 is starting and running. But i can’t get my pi zero W to connect to my wifi. I edited the WPA_supplicant file. Can’t get it to work. Also i tried with a command found on google to scan for networks. But it responds Wlan0 can’t scan.
                          Thanks in advance for the help.
                          • H
                            Hawking @delusional112
                            @delusional112
                            I didn’t use the image but used my own installation. Therefore In can’t tell for sure. However,where ist the wpa_supplicant.conf you are referring to located? Did you use/create one directly on /boot? This should automatically be copied to the “normal” location and then automatically get deleted.
                            My wpa_suplicant.conf file looked like
                            ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
                            update_config=1
                            network={
                            ssid="NAMEOFNETWORK"
                            psk="WPA2KEY"
                            (of course you have put your network name and key in, but keep the quotation marks).
                            Which editor did you use (not that there is a problem with the line end or something similar)?
                            Once it worked, I replaced the clear text psk by a passphrase by using wpa_passphrase.
                              SebTota
                              Man I put the mirror in the closet for a little, came back to finally finish the frame and put it on the wall, updated it and more trouble. Oh gosh.
                                SebTota @Mitchfarino
                                @Mitchfarino Thanks for sharing my link!
                                  SebTota
                                  Did anyone get this working on the Pi Zero or Pi Zero W after the new update?
                                  • H
                                    Hawking @SebTota
                                    @SebTota
                                    Which updates are you referring to? I’m still using Raspbian Jessie Light (I didn’t use the image provided in this thread but my own installation and didn’t update so Stretch yet), which is up to date (according to sudo apt-get update && sudo apt-get upgrade) and the latest version of MagicMirror (according to cd ~/MagicMirror && sudo git pull) and don’t see any (new) issues on my Pi Zero W.
                                    What are your problems?
                                      SebTota @Hawking
                                      @Hawking I get an error saying that modules/color is missing or something like that. I’ve been working on it for 3 days but can’t get it to work.
                                      • H
                                        Hawking @SebTota
                                        @SebTota
                                        • Do you also get this error if you use a very minimal config file like
                                        var config = {
                                                port: 8080,
                                                language: "en",
                                                timeFormat: 24,
                                                units: "metric",
        module: "clock",
        position: "top_left"
                                        If this works, you can step by step add the modules you want and see which one causes the problem.
                                        • The exact error message would be helpful for an analysis.
                                          SebTota @Hawking
                                          @Hawking
                                          module.js:339
                                          throw err;
                                          Error: Cannot find module ‘express’
                                          at Object. (/home/pi/MagicMirror/js/server.js:8:15)
                                          at Object.Module._extensions…js (module.js:442:10)
                                          and then the browser loads and says it cannot find http://localhost:8080
                                            SebTota @SebTota
                                            @SebTota I went to my old image from before the update and thats still working fine, but when I updated it, it again had the error come up. The only difference is last time I did the update it said Error: Cannot find module ‘colors’
                                            • 10
                                            • 11
                                            • 5 / 11
