    How I got my Magic Mirror working on a Raspberry Pi 0 (zero)
    raspberry pipi0zeropizeropi1
    204 Posts 47 Posters 659.0k Views 47 Watching
      ArkantosArk
      @SebTota
      I tried to follow your guide (which is really well explained) but for some reason I´m having a few errors at the last step…Could you share your “Magic Mirror” only image with me please?
        braik @Mar
        @Mar
        Hi there,
        I had the same problem and the I have realized that node serveronly was not launched.
        The problem is that the command :
        cd ~/MagicMirror was not working, so I have changed it for
        cd /home/pi/MagicMirror
        and that’s it.
        Hope this can help
          bmarofsky
          OK, so i am trying this again on a Pi Zero W
          I got stuck on Step 4
          so I ran:
          sudo apt-get remove nodered
          sudo apt-get remove nodejs nodejs-legacy
          sudo apt-get remove npm   # if you installed npm
          wget http://node-arm.herokuapp.com/node_archive_armhf.deb
          sudo dpkg -i node_archive_armhf.deb
          sudo apt-get install -y build-essential python-dev npm
          then again on Step 5 i got a ton of these:
          pi@raspberrypi:~/MagicMirror $ sudo npm install
          npm WARN engine feedme@1.0.0: wanted: {"node":">=0.12"} (current: {"node":"0.10.29","npm":"1.4.21"})
          npm WARN engine grunt-eslint@19.0.0: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
          npm WARN engine request@2.81.0: wanted: {"node":">= 4"} (current: {"node":"0.10.29","npm":"1.4.21"})
          npm WARN engine eslint@3.17.1: wanted: {"node":">=4"} (current: {"node":"0.10.29","npm":"1.4.21"})
          Are the updated steps or an Image that can be downloaded?
          • H Offline
            Hawking @bmarofsky
            @bmarofsky
            I’m also trying to install Magic Mirror on a Pi Zero W.
            I think one reason for the problems might be that as far as I can tell
            sudo wget http://node-arm.herokuapp.com/node_latest_armhf.deb
            sudo dpkg -i node_latest_armhf.deb
            got me node v4.2.1 which is quite outdated (the regular installer of MM2 updates nodes if the version of node is below 5.1.0).
            I therefore tried to install a more recent version of node following the commands here
            https://github.com/sdesalas/node-pi-zero
            However, the compilation of Magic Mirror worked neither with node 7.7.1 nor with node 6.9.1.
            Before I go into details, did anybody got Magic Mirror working on Raspberry Pi Zero W?
            Which node version (and npm version) did you use and how you he install it? Which browser did you use (I read that Midori has some problems)?
              Mitchfarino Module Developer @ArkantosArk
              @ArkantosArk
              This is @SebTota 's link https://mega.nz/#!XlIU3QjI!QSdvAE3yXp1oMsdRGNte6lt4SncgvfozSDU7xhxtbbM
              • H Offline
                Hawking
                I could fix my issue with the blank screen by simply doing
                cd ~/MagicMirror/vendor
                npm install
                Then it seem to work (even with the node v 4.2.1). Nevertheless I will try to update to a more recent version of node, just to avoid other problems that are likely to exist in this old node version.
                • L Offline
                  longod
                  Hi! I have followed this guide step by step and so precisely, however I am still getting an error when I type in DISPLAY=:0 npm start through SSH. This is the output:
                  pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start
                  > magicmirror@2.1.1 start /home/pi/MagicMirror
                  > sh run-start.sh
                  /home/pi/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libXss.so.1: cannot open shared object file: No such file or directory
                  npm ERR! Linux 4.4.50+
                  npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "start"
                  npm ERR! node v4.2.1
                  npm ERR! npm  v2.14.7
                  npm ERR! file sh
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno ENOENT
                  npm ERR! syscall spawn
                  npm ERR! magicmirror@2.1.1 start: `sh run-start.sh`
                  npm ERR! spawn ENOENT
                  npm ERR!
                  npm ERR! Failed at the magicmirror@2.1.1 start script 'sh run-start.sh'.
                  npm ERR! This is most likely a problem with the magicmirror package,
                  npm ERR! not with npm itself.
                  npm ERR!     sh run-start.sh
                  npm ERR! You can get their info via:
                  npm ERR!     npm owner ls magicmirror
                  npm ERR!     /home/pi/MagicMirror/npm-debug.log
                  Any help on what to do to solve this would be greatly appreciated!
                  • H Offline
                    Hawking @longod
                    @longod
                    I didn’t try your way of starting the MagicMirror. However, is there a reason that you don’t use the commands in the guide to start the MagicMirror (using the start.sh and startMidori scripts)? There is no DISPLAY=:0 npm start mentioned in this thread.
                      RV @randombullet
                      @randombullet i followed those steps but i got a error it says that he cannot connect with localhost: 8080 webpage?
                        dantodd
                        have you tried just using “npm start” in ssh? That works for me.
                          RV @dantodd
                          @dantodd you mean every time i start my rasp on i need to type npm start?
                          D B 2 Replies Last reply Reply Quote 0
                          • H Offline
                            Hawking
                            @RV said in How I got my Magic Mirror working on a Raspberry Pi 0 (zero):
                            no, that is definitely not necessary.
                            I don’t know the reason for the error message (is there actually a space between localhost: and 8080?). What happens if you run
                            node serveronly &
                            manually?
                              dantodd @RV
                              Automating the process is fairly simple but let’s get you up and running first. You should also check your permissions in the config.js file. Make sure that your whitelist is properly configured.
                                braik @RV
                                @RV Hi, I don’t know if it can help, but I have noticed that the “~” shortcut to go tho the /home/pi folder does not work on the scripts.
                                So when you do the same commands manually everything seems to be OK, but when you run the scripts then you get a bug.
                                The solution, in my case, was to replace all the folder shortcuts (as ~ for home folder) with the complete explicit path inside the scripts.
                                Good luck
                                Braik
                                  RV @braik
                                  @braik as i said before i am not that experienced with Python, Linux or what so ever. I think you are right on this one. When i typed cd /home/pi/ i didn’t get a response or anything.
                                  I hope you can show me how to replace the folder, like you have told me before.
                                  • H Offline
                                    Hawking @RV
                                    This sounds strange. Did you type it in the unit terminal? cd is the comand to change directory. Maybe you have already been in the /home/pi/ directory (than the change would have no effect). Could you type pwd (print working directory)
                                    and give the result before and after the cd /home/pi/ command and give the results?
                                    • 1 Offline
                                      12wsx
                                      Hello. I installed image of SebTota everything work, but i had to update and after put: "git pull"my MM don,t get up.
                                      error
                                      1 verbose cli [ '/usr/local/bin/node', '/usr/local/bin/npm', 'start' ]
                                      2 info using npm@2.14.7
                                      3 info using node@v4.2.1
                                      5 info prestart magicmirror@2.1.2
                                      6 info start magicmirror@2.1.2
                                      7 verbose unsafe-perm in lifecycle true
                                      8 info magicmirror@2.1.2 Failed to exec start script
                                      9 verbose stack Error: magicmirror@2.1.2 start: `sh run-start.sh`
                                      9 verbose stack spawn ENOENT
                                      9 verbose stack     at ChildProcess. (/usr/local/lib/node_modules/npm/lib/utils/spawn.js:17:16)
                                      9 verbose stack     at emitTwo (events.js:87:13)
                                      9 verbose stack     at ChildProcess.emit (events.js:172:7)
                                      9 verbose stack     at maybeClose (internal/child_process.js:818:16)
                                      9 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:211:5)
                                      10 verbose pkgid magicmirror@2.1.2
                                      11 verbose cwd /home/pi/MagicMirror
                                      12 error Linux 4.4.34+
                                      13 error argv "/usr/local/bin/node" "/usr/local/bin/npm" "start"
                                      14 error node v4.2.1
                                      15 error npm  v2.14.7
                                      16 error file sh
                                      17 error code ELIFECYCLE
                                      18 error errno ENOENT
                                      19 error syscall spawn
                                      20 error magicmirror@2.1.2 start: `sh run-start.sh`
                                      20 error spawn ENOENT
                                      21 error Failed at the magicmirror@2.1.2 start script 'sh run-start.sh'.
                                      21 error This is most likely a problem with the magicmirror package,
                                      21 error not with npm itself.
                                      21 error Tell the author that this fails on your system:
                                      21 error     sh run-start.sh
                                      21 error You can get their info via:
                                      21 error     npm owner ls magicmirror
                                      21 error There is likely additional logging output above.
                                      22 verbose exit [ 1, true ]
                                      ```how can i resolved this problem?
                                      • 1 Offline
                                        12wsx
                                        Today after reinstall and try to update cd /MagicMirror git pull my MagicMirror won’t start up
                                        full log update
                                        Starting MagicMirror: v2.1.0
                                        Loading config ...
                                        Loading module helpers ...
                                        All module helpers loaded.
                                        Starting server op port 8080 ...
                                        Server started ...
                                        Starting module: newsfeed
                                        Ready to go! Please point your browser to: http://localhost:8080
                                        { [Error: listen EADDRINUSE :::8080]
                                          code: 'EADDRINUSE',
                                          errno: 'EADDRINUSE',
                                          syscall: 'listen',
                                          address: '::',
                                          port: 8080 }
                                        MagicMirror will not quit, but it might be a good idea to check why this happene        d. Maybe no internet connection?
                                        If you think this really is an issue, please open an issue on GitHub: https://gi        thub.com/MichMich/MagicMirror/issues
                                        (EE)
                                        Fatal server error:
                                        (EE) Server is already active for display 0
                                                If this server is no longer running, remove /tmp/.X0-lock
                                                and start again.
                                        (EE)
                                        (EE)
                                        Please consult the The X.Org Foundation support
                                                 at http://wiki.x.org
                                         for help.
                                        (EE)
                                        XIO:  fatal IO error 11 (Resource temporarily unavailable) on X server ":0"
                                              after 7 requests (7 known processed) with 0 events remaining.
                                        root@raspberrypi:/home/pi/MagicMirror# git pull
                                        Updating 8010e62..8a101f9
                                        Fast-forward
                                         .eslintignore                                                 |     4 +-
                                         .github/PULL_REQUEST_TEMPLATE.md                              |     7 +
                                         .gitignore                                                    |    13 +-
                                         .travis.yml                                                   |    11 +-
                                         CHANGELOG.md                                                  |   114 +-
                                         Gruntfile.js                                                  |    48 +-
                                         LICENSE.md                                                    |     2 +-
                                         README.md                                                     |    56 +-
                                         config/config.js.sample                                       |    62 +-
                                         css/main.css                                                  |    12 +
                                         index.html                                                    |     8 +-
                                         installers/mm.sh                                              |     2 +
                                         installers/pm2_MagicMirror.json                               |     7 +
                                         installers/postinstall/postinstall.sh                         |     2 +
                                         installers/raspberry.sh                                       |    36 +-
                                         js/app.js                                                     |   103 +-
                                         js/defaults.js                                                |     7 +-
                                         js/deprecated.js                                              |    14 +
                                         js/electron.js                                                |     8 +-
                                         js/loader.js                                                  |    16 +-
                                         js/main.js                                                    |    56 +-
                                         js/module.js                                                  |    69 +-
                                         js/server.js                                                  |    32 +-
                                         js/socketclient.js                                            |     1 -
                                         js/translator.js                                              |    27 +-
                                         js/utils.js                                                   |    19 +
                                         modules/README.md                                             |   142 +-
                                         modules/default/alert/README.md                               |   149 +-
                                         modules/default/alert/alert.js                                |     3 +-
                                         modules/default/alert/translations/hu.json                    |     4 +
                                         modules/default/alert/translations/nl.json                    |     4 +
                                         modules/default/alert/translations/ru.json                    |     4 +
                                         modules/default/calendar/README.md                            |   236 +--
                                         modules/default/calendar/calendar.css                         |     2 +
                                         modules/default/calendar/calendar.js                          |   224 ++-
                                         modules/default/calendar/calendarfetcher.js                   |    34 +-
                                         modules/default/calendar/debug.js                             |    14 +-
                                         modules/default/calendar/node_helper.js                       |     7 +-
                                         modules/default/calendar/vendor/ical.js/ical.js               |    12 +-
                                         modules/default/calendar/vendor/ical.js/node-ical.js          |    13 +-
                                         modules/default/clock/README.md                               |   124 +-
                                         modules/default/clock/clock.js                                |    79 +-
                                         modules/default/clock/clock_styles.css                        |     2 +-
                                         modules/default/compliments/README.md                         |   121 +-
                                         modules/default/compliments/compliments.js                    |    36 +-
                                         modules/default/currentweather/README.md                      |   248 +--
                                         modules/default/currentweather/currentweather.css             |     3 +-
                                         modules/default/currentweather/currentweather.js              |    64 +-
                                         modules/default/helloworld/README.md                          |    29 +-
                                         modules/default/newsfeed/README.md                            |   189 +-
                                         modules/default/newsfeed/fetcher.js                           |     7 +-
                                         modules/default/newsfeed/newsfeed.js                          |   113 +-
                                         modules/default/newsfeed/node_helper.js                       |    11 +-
                                         modules/default/updatenotification/README.md                  |    25 +-
                                         modules/default/weatherforecast/README.md                     |   223 +--
                                         modules/default/weatherforecast/weatherforecast.css           |     8 +
                                         modules/default/weatherforecast/weatherforecast.js            |    28 +-
                                         modules/node_modules/node_helper/index.js                     |    20 +-
                                         package.json                                                  |    40 +-
                                         run-start.sh                                                  |     4 +
                                         splashscreen/MagicMirror.script                               |    17 +-
                                         splashscreen/splash.png                                       |   Bin 19820 -> 37062 bytes
                                         splashscreen/splash_halt.png                                  |   Bin 0 -> 22304 bytes
                                         tests/configs/check_config.js                                 |    66 +
                                         tests/configs/data/calendar_test.ics                          |   190 ++
                                         tests/configs/data/feed_test_rodrigoramirez.xml               |   410 +++++
                                         tests/configs/empty_ipWhiteList.js                            |    25 +
                                         tests/configs/env.js                                          |    25 +
                                         tests/configs/modules/calendar/auth-default.js                |    41 +
                                         tests/configs/modules/calendar/basic-auth.js                  |    42 +
                                         tests/configs/modules/calendar/default.js                     |    37 +
                                         tests/configs/modules/calendar/fail-basic-auth.js             |    44 +
                                         tests/configs/modules/calendar/old-basic-auth.js              |    39 +
                                         tests/configs/modules/clock/clock_12hr.js                     |    29 +
                                         tests/configs/modules/clock/clock_24hr.js                     |    29 +
                                         tests/configs/modules/clock/clock_displaySeconds_false.js     |    32 +
                                         tests/configs/modules/clock/clock_showPeriodUpper.js          |    32 +
                                         tests/configs/modules/clock/clock_showWeek.js                 |    32 +
                                         tests/configs/modules/clock/es/clock_12hr.js                  |    29 +
                                         tests/configs/modules/clock/es/clock_24hr.js                  |    29 +
                                         tests/configs/modules/clock/es/clock_showPeriodUpper.js       |    32 +
                                         tests/configs/modules/compliments/compliments_anytime.js      |    38 +
                                         tests/configs/modules/compliments/compliments_only_anytime.js |    35 +
                                         tests/configs/modules/compliments/compliments_parts_day.js    |    42 +
                                         tests/configs/modules/helloworld/helloworld.js                |    32 +
                                         tests/configs/modules/newsfeed/default.js                     |    38 +
                                         tests/configs/modules/positions.js                            |    43 +
                                         tests/configs/noIpWhiteList.js                                |    25 +
                                         tests/configs/port_8090.js                                    |    25 +
                                         tests/configs/without_modules.js                              |    23 +
                                         tests/e2e/dev_console.js                                      |    51 +
                                         tests/e2e/env_spec.js                                         |    47 +
                                         tests/e2e/global-setup.js                                     |    34 +
                                         tests/e2e/ipWhistlist_spec.js                                 |    46 +
                                         tests/e2e/modules/calendar_spec.js                            |    81 +
                                         tests/e2e/modules/clock_es_spec.js                            |    81 +
                                         tests/e2e/modules/clock_spec.js                               |   134 ++
                                         tests/e2e/modules/compliments_spec.js                         |    95 +
                                         tests/e2e/modules/helloworld_spec.js                          |    24 +
                                         tests/e2e/modules/newsfeed_spec.js                            |    28 +
                                         tests/e2e/modules_position_spec.js                            |    42 +
                                         tests/e2e/port_config.js                                      |    51 +
                                         tests/e2e/vendor_spec.js                                      |    36 +
                                         tests/e2e/without_modules.js                                  |    53 +
                                         tests/servers/basic-auth.js                                   |    30 +
                                         tests/unit/functions/calendar_spec.js                         |    36 +
                                         tests/unit/functions/cmp_versions_spec.js                     |    20 +
                                         tests/unit/global_vars/defaults_modules_spec.js               |    66 +
                                         tests/unit/global_vars/root_path_spec.js                      |    71 +
                                         tests/unit/translations/same_keys.js                          |   115 ++
                                         translations/af.json                                          |    30 +
                                         translations/da.json                                          |     6 +-
                                         translations/de.json                                          |     6 +-
                                         translations/en.json                                          |     6 +-
                                         translations/es.json                                          |     6 +-
                                         translations/et.json                                          |    30 +
                                         translations/fi.json                                          |    11 +-
                                         translations/fr.json                                          |     3 -
                                         translations/fy.json                                          |     3 -
                                         translations/gr.json                                          |     3 -
                                         translations/hu.json                                          |    30 +
                                         translations/id.json                                          |    30 +
                                         translations/is.json                                          |    30 +
                                         translations/it.json                                          |     3 -
                                         translations/ja.json                                          |     5 +-
                                         translations/kr.json                                          |    30 +
                                         translations/nb.json                                          |    12 +-
                                         translations/nl.json                                          |     4 -
                                         translations/nn.json                                          |    10 +-
                                         translations/pl.json                                          |    13 +-
                                         translations/pt.json                                          |    11 +-
                                         translations/pt_br.json                                       |     3 -
                                         translations/ro.json                                          |    32 +
                                         translations/ru.json                                          |    32 +
                                         translations/sv.json                                          |    16 +-
                                         translations/tr.json                                          |     3 -
                                         translations/translations.js                                  |    10 +
                                         translations/zh_cn.json                                       |    10 +-
                                         translations/zh_tw.json                                       |     3 -
                                         vendor/font-awesome-4.5.0/HELP-US-OUT.txt                     |     7 -
                                         vendor/font-awesome-4.5.0/css/font-awesome.css                |  2086 ----------------------
                                         vendor/font-awesome-4.5.0/css/font-awesome.min.css            |     4 -
                                         vendor/font-awesome-4.5.0/fonts/FontAwesome.otf               |   Bin 109688 -> 0 bytes
                                         vendor/font-awesome-4.5.0/fonts/fontawesome-webfont.eot       |   Bin 70807 -> 0 bytes
                                         vendor/font-awesome-4.5.0/fonts/fontawesome-webfont.svg       |   655 -------
                                         vendor/font-awesome-4.5.0/fonts/fontawesome-webfont.ttf       |   Bin 142072 -> 0 bytes
                                         vendor/font-awesome-4.5.0/fonts/fontawesome-webfont.woff      |   Bin 83588 -> 0 bytes
                                         vendor/font-awesome-4.5.0/fonts/fontawesome-webfont.woff2     |   Bin 66624 -> 0 bytes
                                         vendor/font-awesome-4.5.0/less/animated.less                  |    34 -
                                         vendor/font-awesome-4.5.0/less/bordered-pulled.less           |    25 -
                                         vendor/font-awesome-4.5.0/less/core.less                      |    12 -
                                         vendor/font-awesome-4.5.0/less/fixed-width.less               |     6 -
                                         vendor/font-awesome-4.5.0/less/font-awesome.less              |    17 -
                                         vendor/font-awesome-4.5.0/less/icons.less                     |   697 --------
                                         vendor/font-awesome-4.5.0/less/larger.less                    |    13 -
                                         vendor/font-awesome-4.5.0/less/list.less                      |    19 -
                                         vendor/font-awesome-4.5.0/less/mixins.less                    |    26 -
                                         vendor/font-awesome-4.5.0/less/path.less                      |    15 -
                                         vendor/font-awesome-4.5.0/less/rotated-flipped.less           |    20 -
                                         vendor/font-awesome-4.5.0/less/stacked.less                   |    20 -
                                         vendor/font-awesome-4.5.0/less/variables.less                 |   708 --------
                                         vendor/font-awesome-4.5.0/scss/_animated.scss                 |    34 -
                                         vendor/font-awesome-4.5.0/scss/_bordered-pulled.scss          |    25 -
                                         vendor/font-awesome-4.5.0/scss/_core.scss                     |    12 -
                                         vendor/font-awesome-4.5.0/scss/_fixed-width.scss              |     6 -
                                         vendor/font-awesome-4.5.0/scss/_icons.scss                    |   697 --------
                                         vendor/font-awesome-4.5.0/scss/_larger.scss                   |    13 -
                                         vendor/font-awesome-4.5.0/scss/_list.scss                     |    19 -
                                         vendor/font-awesome-4.5.0/scss/_mixins.scss                   |    26 -
                                         vendor/font-awesome-4.5.0/scss/_path.scss                     |    15 -
                                         vendor/font-awesome-4.5.0/scss/_rotated-flipped.scss          |    20 -
                                         vendor/font-awesome-4.5.0/scss/_stacked.scss                  |    20 -
                                         vendor/font-awesome-4.5.0/scss/_variables.scss                |   708 --------
                                         vendor/font-awesome-4.5.0/scss/font-awesome.scss              |    17 -
                                         vendor/moment/moment-timezone.js                              |  1197 -------------
                                         vendor/moment/moment-with-locales.js                          | 12061 -----------------------------------------------------------------------------------------------------------------------------
                                         vendor/moment/moment-with-locales.min.js                      |    75 -
                                         vendor/package.json                                           |    18 +
                                         vendor/vendor.js                                              |    12 +-
                                         vendor/weather-icons/css/weather-icons-wind.css               |  5331 -------------------------------------------------------
                                         vendor/weather-icons/css/weather-icons-wind.min.css           |     1 -
                                         vendor/weather-icons/css/weather-icons.css                    |  1838 -------------------
                                         vendor/weather-icons/css/weather-icons.min.css                |    41 -
                                         vendor/weather-icons/font/weathericons-regular-webfont.eot    |   Bin 99774 -> 0 bytes
                                         vendor/weather-icons/font/weathericons-regular-webfont.svg    |   257 ---
                                         vendor/weather-icons/font/weathericons-regular-webfont.ttf    |   Bin 99564 -> 0 bytes
                                         vendor/weather-icons/font/weathericons-regular-webfont.woff   |   Bin 56468 -> 0 bytes
                                         vendor/weather-icons/font/weathericons-regular-webfont.woff2  |   Bin 44720 -> 0 bytes
                                         188 files changed, 4474 insertions(+), 28304 deletions(-)
                                         create mode 100755 installers/mm.sh
                                         create mode 100644 installers/pm2_MagicMirror.json
                                         create mode 100644 installers/postinstall/postinstall.sh
                                         create mode 100644 js/deprecated.js
                                         create mode 100644 js/utils.js
                                         create mode 100644 modules/default/alert/translations/hu.json
                                         create mode 100644 modules/default/alert/translations/nl.json
                                         create mode 100644 modules/default/alert/translations/ru.json
                                         create mode 100644 run-start.sh
                                         create mode 100644 splashscreen/splash_halt.png
                                         create mode 100644 tests/configs/check_config.js
                                         create mode 100644 tests/configs/data/calendar_test.ics
                                         create mode 100644 tests/configs/data/feed_test_rodrigoramirez.xml
                                         create mode 100644 tests/configs/empty_ipWhiteList.js
                                         create mode 100644 tests/configs/env.js
                                         create mode 100644 tests/configs/modules/calendar/auth-default.js
                                         create mode 100644 tests/configs/modules/calendar/basic-auth.js
                                         create mode 100644 tests/configs/modules/calendar/default.js
                                         create mode 100644 tests/configs/modules/calendar/fail-basic-auth.js
                                         create mode 100644 tests/configs/modules/calendar/old-basic-auth.js
                                         create mode 100644 tests/configs/modules/clock/clock_12hr.js
                                         create mode 100644 tests/configs/modules/clock/clock_24hr.js
                                         create mode 100644 tests/configs/modules/clock/clock_displaySeconds_false.js
                                         create mode 100644 tests/configs/modules/clock/clock_showPeriodUpper.js
                                         create mode 100644 tests/configs/modules/clock/clock_showWeek.js
                                         create mode 100644 tests/configs/modules/clock/es/clock_12hr.js
                                         create mode 100644 tests/configs/modules/clock/es/clock_24hr.js
                                         create mode 100644 tests/configs/modules/clock/es/clock_showPeriodUpper.js
                                         create mode 100644 tests/configs/modules/compliments/compliments_anytime.js
                                         create mode 100644 tests/configs/modules/compliments/compliments_only_anytime.js
                                         create mode 100644 tests/configs/modules/compliments/compliments_parts_day.js
                                         create mode 100644 tests/configs/modules/helloworld/helloworld.js
                                         create mode 100644 tests/configs/modules/newsfeed/default.js
                                         create mode 100644 tests/configs/modules/positions.js
                                         create mode 100644 tests/configs/noIpWhiteList.js
                                         create mode 100644 tests/configs/port_8090.js
                                         create mode 100644 tests/configs/without_modules.js
                                         create mode 100644 tests/e2e/dev_console.js
                                         create mode 100644 tests/e2e/env_spec.js
                                         create mode 100644 tests/e2e/global-setup.js
                                         create mode 100644 tests/e2e/ipWhistlist_spec.js
                                         create mode 100644 tests/e2e/modules/calendar_spec.js
                                         create mode 100644 tests/e2e/modules/clock_es_spec.js
                                         create mode 100644 tests/e2e/modules/clock_spec.js
                                         create mode 100644 tests/e2e/modules/compliments_spec.js
                                         create mode 100644 tests/e2e/modules/helloworld_spec.js
                                         create mode 100644 tests/e2e/modules/newsfeed_spec.js
                                         create mode 100644 tests/e2e/modules_position_spec.js
                                         create mode 100644 tests/e2e/port_config.js
                                         create mode 100644 tests/e2e/vendor_spec.js
                                         create mode 100644 tests/e2e/without_modules.js
                                         create mode 100644 tests/servers/basic-auth.js
                                         create mode 100644 tests/unit/functions/calendar_spec.js
                                         create mode 100644 tests/unit/functions/cmp_versions_spec.js
                                         create mode 100644 tests/unit/global_vars/defaults_modules_spec.js
                                         create mode 100644 tests/unit/global_vars/root_path_spec.js
                                         create mode 100644 tests/unit/translations/same_keys.js
                                         create mode 100644 translations/af.json
                                         create mode 100644 translations/et.json
                                         create mode 100644 translations/hu.json
                                         create mode 100644 translations/id.json
                                         create mode 100644 translations/is.json
                                         create mode 100644 translations/kr.json
                                         create mode 100644 translations/ro.json
                                         create mode 100644 translations/ru.json
                                         delete mode 100644 vendor/font-awesome-4.5.0/HELP-US-OUT.txt
                                         delete mode 100644 vendor/font-awesome-4.5.0/css/font-awesome.css
                                         delete mode 100644 vendor/font-awesome-4.5.0/css/font-awesome.min.css
                                         delete mode 100644 vendor/font-awesome-4.5.0/fonts/FontAwesome.otf
                                         delete mode 100644 vendor/font-awesome-4.5.0/fonts/fontawesome-webfont.eot
                                         delete mode 100644 vendor/font-awesome-4.5.0/fonts/fontawesome-webfont.svg
                                         delete mode 100644 vendor/font-awesome-4.5.0/fonts/fontawesome-webfont.ttf
                                         delete mode 100644 vendor/font-awesome-4.5.0/fonts/fontawesome-webfont.woff
                                         delete mode 100644 vendor/font-awesome-4.5.0/fonts/fontawesome-webfont.woff2
                                         delete mode 100644 vendor/font-awesome-4.5.0/less/animated.less
                                         delete mode 100644 vendor/font-awesome-4.5.0/less/bordered-pulled.less
                                         delete mode 100644 vendor/font-awesome-4.5.0/less/core.less
                                         delete mode 100644 vendor/font-awesome-4.5.0/less/fixed-width.less
                                         delete mode 100644 vendor/font-awesome-4.5.0/less/font-awesome.less
                                         delete mode 100644 vendor/font-awesome-4.5.0/less/icons.less
                                         delete mode 100644 vendor/font-awesome-4.5.0/less/larger.less
                                         delete mode 100644 vendor/font-awesome-4.5.0/less/list.less
                                         delete mode 100644 vendor/font-awesome-4.5.0/less/mixins.less
                                         delete mode 100644 vendor/font-awesome-4.5.0/less/path.less
                                         delete mode 100644 vendor/font-awesome-4.5.0/less/rotated-flipped.less
                                         delete mode 100644 vendor/font-awesome-4.5.0/less/stacked.less
                                         delete mode 100644 vendor/font-awesome-4.5.0/less/variables.less
                                         delete mode 100644 vendor/font-awesome-4.5.0/scss/_animated.scss
                                         delete mode 100644 vendor/font-awesome-4.5.0/scss/_bordered-pulled.scss
                                         delete mode 100644 vendor/font-awesome-4.5.0/scss/_core.scss
                                         delete mode 100644 vendor/font-awesome-4.5.0/scss/_fixed-width.scss
                                         delete mode 100644 vendor/font-awesome-4.5.0/scss/_icons.scss
                                         delete mode 100644 vendor/font-awesome-4.5.0/scss/_larger.scss
                                         delete mode 100644 vendor/font-awesome-4.5.0/scss/_list.scss
                                         delete mode 100644 vendor/font-awesome-4.5.0/scss/_mixins.scss
                                         delete mode 100644 vendor/font-awesome-4.5.0/scss/_path.scss
                                         delete mode 100644 vendor/font-awesome-4.5.0/scss/_rotated-flipped.scss
                                         delete mode 100644 vendor/font-awesome-4.5.0/scss/_stacked.scss
                                         delete mode 100644 vendor/font-awesome-4.5.0/scss/_variables.scss
                                         delete mode 100644 vendor/font-awesome-4.5.0/scss/font-awesome.scss
                                         delete mode 100644 vendor/moment/moment-timezone.js
                                         delete mode 100644 vendor/moment/moment-with-locales.js
                                         delete mode 100644 vendor/moment/moment-with-locales.min.js
                                         create mode 100644 vendor/package.json
                                         delete mode 100644 vendor/weather-icons/css/weather-icons-wind.css
                                         delete mode 100644 vendor/weather-icons/css/weather-icons-wind.min.css
                                         delete mode 100644 vendor/weather-icons/css/weather-icons.css
                                         delete mode 100644 vendor/weather-icons/css/weather-icons.min.css
                                         delete mode 100755 vendor/weather-icons/font/weathericons-regular-webfont.eot
                                         delete mode 100755 vendor/weather-icons/font/weathericons-regular-webfont.svg
                                         delete mode 100755 vendor/weather-icons/font/weathericons-regular-webfont.ttf
                                         delete mode 100755 vendor/weather-icons/font/weathericons-regular-webfont.woff
                                         delete mode 100755 vendor/weather-icons/font/weathericons-regular-webfont.woff2
                                        The programs included with the Debian GNU/Linux system are free software;
                                        the exact distribution terms for each program are described in the
                                        individual files in /usr/share/doc/*/copyright.
                                        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                        permitted by applicable law.
                                        Last login: Mon Aug  7 18:27:13 2017
                                        SSH is enabled and the default password for the 'pi' user has not been changed.
                                        This is a security risk - please login as the 'pi' user and type 'passwd' to set a new password.
                                        module.js:339
                                            throw err;
                                        Error: Cannot find module 'colors/safe'
                                            at Function.Module._resolveFilename (module.js:337:15)
                                            at Function.Module._load (module.js:287:25)
                                            at Module.require (module.js:366:17)
                                            at require (module.js:385:17)
                                            at Object. (/home/pi/MagicMirror/js/utils.js:9:14)
                                            at Module._compile (module.js:435:26)
                                            at Object.Module._extensions..js (module.js:442:10)
                                            at Module.load (module.js:356:32)
                                            at Function.Module._load (module.js:311:12)
                                        (EE)
                                        Fatal server error:
                                                and start again.
                                        (EE)
                                        (EE)
                                         for help.
                                        (EE)
                                        pi@raspberrypi:~ $
                                        best regards
                                        Dan
                                          mmaino12 @12wsx
                                          @12wsx That error log means that you already have a server running on port 8080. You need to kill the existing server and then restart your new mirror server with “npm start”.
                                            delusional112
                                            Hi guys,
                                            Used the image from @SebTota. MM2 is starting and running. But i can’t get my pi zero W to connect to my wifi. I edited the WPA_supplicant file. Can’t get it to work. Also i tried with a command found on google to scan for networks. But it responds Wlan0 can’t scan.
                                            Thanks in advance for the help.
                                            • 10
                                            • 11
                                            • 5 / 11
