Problem after installing MM on Pi Zero W
@Mykle1 said in Problem after installing MM on Pi Zero W:
Are you running npm start from your MagicMirror directory?
pi@magicmirror~/MagicMirror
no I didn’t , now there are no errors. Thanks.
But now the screen is black again.
npm start
works, … hmm …is the configsample.js maybe not working with the Pi Zero ?Is there a way to test the MM with an other method ? ( I’m using Midori, like in the tutorial)
@abergy if there is a module using es6 features it could be a reason for the black screen. can you check the developer console in midori for errors?
Can I check the errorlog over the commandline somehow?
If I google the “Black screen” problem with the Pi zero W, there are a lot of questions but now solutions.
Someone said ist maybe because of the ARM6 Arch. on the Pi Zero!?Should I buy a Raspi3 to save my nerves ^^?
@abergy said in Problem after installing MM on Pi Zero W:
There is certainly less trouble with a Pi3. Installation is more direct and you don’t need any work-arounds. Your nerves are another matter. :^)
@abergy actually you can’t as the logs are related to your browser (midori)
I had the same issue. Tried Chromium instead Midori, where it works fine.
