    Problem with MMM-ResRobot, it wont start(?)
    31 Posts 7 Posters 24.1k Views 7 Watching
    • N
      Nybbe67 @atd08001
      @atd08001
      Thanks Andreas for fast respons. I will try it with your config.
      Niklas
      • N
        Nybbe67 @atd08001
        @atd08001 Thanks alot. Found the problem, I have written MMM_Resrobot, not MMM-Resrobot.
        Its working!!
        • E
          Eburkis
          does it work for you now ?
          N 1 Reply Last reply
          • N
            Nybbe67 @Eburkis
            @Eburkis
            Yes, its working, thanks
            Best regards
            Niklas
            • E
              Eburkis
              i cant get mine to work :/
              • N
                Nybbe67
                @Eburkis copy @atd08001’s config (above here) and replace your own, but use your own API key. Then it should work. My mistake was a typo, MMM_ResRobot, not MMM-ResRobot.
                E 1 Reply Last reply
                • E
                  Eburkis @Nybbe67
                  hmm i have not make the same typo as you did but something i still not working for me.
                  		module: "MMM-ResRobot",
                  		position: "left",
                  		header: "Avgångar",
                  			from: "2023",		// ResRobot Station ID (or a comma-separated string of IDs)
                  			to: "1138",			// ResRobot Station ID of destination (or a comma-separated string of IDs)
                  			skipMinutes: 0,		// Skip departures that happens within the next  minutes.
                  			maximumEntries: 6,	// Number of departures to show on screen
                  			truncateAfter: 2,	// A value > 0 will truncate direction name at first space after  characters. 0 = no truncation
                  			apikey: "KEY HERE "		// Your ResRobot apiKey
                  A 1 Reply Last reply
                  • A
                    atd08001 @Eburkis
                    @Eburkis Hi,
                    It looks like the Station ID is wrong. My “From station ID” for “Gubbängen” is 740021699.
                    You can create a API for “ResRobot - Reseplanerare” and then type in this URL in the browser: https://api.resrobot.se/v2/location.name?key=**YOURE API KEY**&input=SEARCH WORD
                    Replace the bold parts, whit API-key and search word for exampel T-centralen
                    You will get a XML response with all the possible results and the differnet ID (Stations ID)
                    And then make sure you use the service “ResRobot - Stolptidtabeller 2” in the config.
                    Good luck
                    Andreas
                    • E
                      Eburkis
                      if i use the api for “platsuppslag” then i get the answer that 2023 is Rudboda torg and when i look for gubbängen Tbana is 7956 so I wonder where you get your number from.
                      and i get access denied with your link so that dont work for me sry
                      • A
                        atd08001 @Eburkis
                        @Eburkis
                        You should use “ResRobot - Reseplanerare" and create a API for that service instead of “platsuppslag”.
                        i get ID: 740024784 and name “Lidingö Rudboda torg” when i search for Rudboda torg
                        BR
                        Andreas
                        • E
                          Eburkis
                          i will try. tnx for the help, have a nice evening
                          • E
                            Eburkis
                            @atd08001
                            now i want to completly give up… now with the new site id its still does not work. now it’s just black with no info at all.
                            what should i do ?
                            		position: "left",
                            		header: "Departures",
                            			from: "740024784",		// ResRobot Station ID (or a comma-separated string of IDs)
                            			to: "740046172",			// ResRobot Station ID of destination (or a comma-separated string of IDs)
                            			truncateAfter: 5,	// A value > 0 will truncate direction name at first space after  characters. 0 = no truncation
                            			apiKey: "key here"		// Your ResRobot apiKey
                            • N
                              Nybbe67 @Eburkis
                              @Eburkis I sent you my config via PM. If you use that with your AKIKey it should work. Otherwise there must be a error with your key.
                              Hm…could it be something with your router, could it block sites? I had a similar problems once and I had a familly filter active on my router.
                              • E
                                Eburkis
                                @Eburkis said in Problem with MMM-ResRobot, it wont start(?):
                                yeey somthing works now
                                now when the MM boots it says Fetching data for almost 3 sec then it goes black and now its just “departures” and under that its empty. so its almost that it is no departures at all
                                AlvingerA 1 Reply Last reply
                                • AlvingerA
                                  Alvinger @Eburkis
                                  @Eburkis et al
                                  I’ve just pushed a long-overdue update to MMM-ResRobot to github.
                                  This new version has a completely reworked updating logic which should result in less “frozen” updates and also less API calls to Trafiklab/ResRobot over time.
                                  Note that there is a breaking change to the configuration as I’ve changed the way routes are defined.
                                  Previous configuration:
                                  to: "to1,,to3"
                                  New configuration:
                                  routes: [
                                    {from: "from1", to: "to1"},
                                    {from: "from2", to: ""},
                                    {from: "from3", to: "to3"},
                                  Sorry for not pushing the update sooner but my mirror project has been delayed due to other things. Will try to update more frequently in the future. Please drop me a note if you encounter issues!
                                  • A
                                    ajomannen @Alvinger
                                    @Alvinger
                                    Hi there,
                                    I fail to get the new config format to work.
                                    I use the following block:
                                    		routes: [
                                    		skipMinutes: 0,
                                    		maximumEntries: 6,
                                    		truncateAfter: 5,
                                    		apiKey: "xxxxx"
                                    but MagicMirror2 fails to start with following message:
                                    WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
                                    (If I use the old config syntax for routes, the system starts up as before, but I get departures from some default location that seems like Stockholm C.)
                                    What could I have done wrong?
                                    • A
                                      ajomannen @ajomannen
                                      @ajomannen
                                      I got it to work by adding an extra level of curly brackets and a comma after the closing square bracket:
                                      		routes: [
                                      		skipMinutes: 0,
                                      		maximumEntries: 6,
                                      		truncateAfter: 5,
                                      		apiKey: "xxxx"
                                      Is the example config on https://github.com/Alvinger/MMM-ResRobot incorrect?
                                      • AlvingerA
                                        Alvinger @ajomannen
                                        @ajomannen sorry, the curly braces got lost in my copying. I have updated my previous post.
                                        • G
                                          Gailby
                                          I can not get it working either, says fetching for quite some time now. I get a “MMM-ResRobot : Error: got 400 response” on starting server… strange. Anyone recognize the same output?
        routes: [
        {from: "740021656", to: "740020749"},   // ResRobot Station IDs of starting and destination station(s). At least one route must be defined.
        {from: "740000765", to: "740000284"},   // "from" is required but "to" is optional (set "to" to empty string to indicate all destinations)
        apiKey: "1c01e8b8-92d0-4e05-86dc-a112d743ba5a"  // Your ResRobot apiKey
                                          • G
                                            Gailby
                                            Ok, seems it didn’t want to handle several departures like previous post but only one:
        routes: [
        {from: "740000765", to: "740000284"}    // "from" is required but "to" is optional (set "to" to empty string to indicate all destinations)
                                            Still get error response:
                                            node_helper for MMM-ResRobot received a socket notification: CONFIG - Payload: {“updateInterval”:300000,“animationSpeed”:2000,“fade”:true,“fadePoint”:0.25,“apiBase”:“https://api.resrobot.se/v2/departureBoard?format=json&passlist=0",“apiKey”:“1c01e8b8-92d0-4e05-86dc-a112d743ba5a”,“routes”:[{“from”:“740000765”,“to”:“740000284”}],“skipMinutes”:0,“maximumEntries”:6,“truncateAfter”:5,“iconTable”:{“B”:"fa fa-bus”,“S”:“fa fa-subway”,“J”:“fa fa-train”,“U”:“fa fa-subway”,“F”:“fa fa-ship”}}
                                            Fetching new departure data for module: MMM-ResRobot
                                            node_helper for MMM-ResRobot received a socket notification: CONFIG - Payload: {“updateInterval”:300000,“animationSpeed”:2000,“fade”:true,“fadePoint”:0.25,“apiBase”:“https://api.resrobot.se/v2/departureBoard?format=json&passlist=0",“apiKey”:“1c01e8b8-92d0-4e05-86dc-a112d743ba5a”,“routes”:[{“from”:“740021656”,“to”:“740020749”}],“skipMinutes”:0,“maximumEntries”:6,“truncateAfter”:5,“iconTable”:{“B”:"fa fa-bus”,“S”:“fa fa-subway”,“J”:“fa fa-train”,“U”:“fa fa-subway”,“F”:“fa fa-ship”}}
