    Problem with MMM-ResRobot, it wont start(?)
    31 Posts 7 Posters 24.1k Views 7 Watching
    • E
      Eburkis
      i cant get mine to work :/
      • N
        Nybbe67
        @Eburkis copy @atd08001’s config (above here) and replace your own, but use your own API key. Then it should work. My mistake was a typo, MMM_ResRobot, not MMM-ResRobot.
        E 1 Reply Last reply
        • E
          Eburkis @Nybbe67
          hmm i have not make the same typo as you did but something i still not working for me.
          		module: "MMM-ResRobot",
          		position: "left",
          		header: "Avgångar",
          			from: "2023",		// ResRobot Station ID (or a comma-separated string of IDs)
          			to: "1138",			// ResRobot Station ID of destination (or a comma-separated string of IDs)
          			skipMinutes: 0,		// Skip departures that happens within the next  minutes.
          			maximumEntries: 6,	// Number of departures to show on screen
          			truncateAfter: 2,	// A value > 0 will truncate direction name at first space after  characters. 0 = no truncation
          			apikey: "KEY HERE "		// Your ResRobot apiKey
          A 1 Reply Last reply
          • A
            atd08001 @Eburkis
            @Eburkis Hi,
            It looks like the Station ID is wrong. My “From station ID” for “Gubbängen” is 740021699.
            You can create a API for “ResRobot - Reseplanerare” and then type in this URL in the browser: https://api.resrobot.se/v2/location.name?key=**YOURE API KEY**&input=SEARCH WORD
            Replace the bold parts, whit API-key and search word for exampel T-centralen
            You will get a XML response with all the possible results and the differnet ID (Stations ID)
            And then make sure you use the service “ResRobot - Stolptidtabeller 2” in the config.
            Good luck
            Andreas
            • E
              Eburkis
              if i use the api for “platsuppslag” then i get the answer that 2023 is Rudboda torg and when i look for gubbängen Tbana is 7956 so I wonder where you get your number from.
              and i get access denied with your link so that dont work for me sry
              • A
                atd08001 @Eburkis
                @Eburkis
                You should use “ResRobot - Reseplanerare" and create a API for that service instead of “platsuppslag”.
                i get ID: 740024784 and name “Lidingö Rudboda torg” when i search for Rudboda torg
                BR
                Andreas
                • E
                  Eburkis
                  i will try. tnx for the help, have a nice evening
                  • E
                    Eburkis
                    @atd08001
                    now i want to completly give up… now with the new site id its still does not work. now it’s just black with no info at all.
                    what should i do ?
                    		position: "left",
                    		header: "Departures",
                    			from: "740024784",		// ResRobot Station ID (or a comma-separated string of IDs)
                    			to: "740046172",			// ResRobot Station ID of destination (or a comma-separated string of IDs)
                    			truncateAfter: 5,	// A value > 0 will truncate direction name at first space after  characters. 0 = no truncation
                    			apiKey: "key here"		// Your ResRobot apiKey
                    N 1 Reply Last reply
                    • N
                      Nybbe67 @Eburkis
                      @Eburkis I sent you my config via PM. If you use that with your AKIKey it should work. Otherwise there must be a error with your key.
                      Hm…could it be something with your router, could it block sites? I had a similar problems once and I had a familly filter active on my router.
                      • E
                        Eburkis
                        @Eburkis said in Problem with MMM-ResRobot, it wont start(?):
                        yeey somthing works now
                        now when the MM boots it says Fetching data for almost 3 sec then it goes black and now its just “departures” and under that its empty. so its almost that it is no departures at all
                        AlvingerA 1 Reply Last reply
                        • AlvingerA
                          Alvinger @Eburkis
                          @Eburkis et al
                          I’ve just pushed a long-overdue update to MMM-ResRobot to github.
                          This new version has a completely reworked updating logic which should result in less “frozen” updates and also less API calls to Trafiklab/ResRobot over time.
                          Note that there is a breaking change to the configuration as I’ve changed the way routes are defined.
                          Previous configuration:
                          to: "to1,,to3"
                          New configuration:
                          routes: [
                            {from: "from1", to: "to1"},
                            {from: "from2", to: ""},
                            {from: "from3", to: "to3"},
                          Sorry for not pushing the update sooner but my mirror project has been delayed due to other things. Will try to update more frequently in the future. Please drop me a note if you encounter issues!
                          • A
                            ajomannen @Alvinger
                            @Alvinger
                            Hi there,
                            I fail to get the new config format to work.
                            I use the following block:
                            		routes: [
                            		skipMinutes: 0,
                            		maximumEntries: 6,
                            		truncateAfter: 5,
                            		apiKey: "xxxxx"
                            but MagicMirror2 fails to start with following message:
                            WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
                            (If I use the old config syntax for routes, the system starts up as before, but I get departures from some default location that seems like Stockholm C.)
                            What could I have done wrong?
                            • A
                              ajomannen @ajomannen
                              @ajomannen
                              I got it to work by adding an extra level of curly brackets and a comma after the closing square bracket:
                              		routes: [
                              		skipMinutes: 0,
                              		maximumEntries: 6,
                              		truncateAfter: 5,
                              		apiKey: "xxxx"
                              Is the example config on https://github.com/Alvinger/MMM-ResRobot incorrect?
                              • AlvingerA
                                Alvinger @ajomannen
                                @ajomannen sorry, the curly braces got lost in my copying. I have updated my previous post.
                                • G
                                  Gailby
                                  I can not get it working either, says fetching for quite some time now. I get a “MMM-ResRobot : Error: got 400 response” on starting server… strange. Anyone recognize the same output?
                                                              routes: [
        {from: "740021656", to: "740020749"},   // ResRobot Station IDs of starting and destination station(s). At least one route must be defined.
        {from: "740000765", to: "740000284"},   // "from" is required but "to" is optional (set "to" to empty string to indicate all destinations)
        apiKey: "1c01e8b8-92d0-4e05-86dc-a112d743ba5a"  // Your ResRobot apiKey
                                  • G
                                    Gailby
                                    Ok, seems it didn’t want to handle several departures like previous post but only one:
        routes: [
        {from: "740000765", to: "740000284"}    // "from" is required but "to" is optional (set "to" to empty string to indicate all destinations)
                                    Still get error response:
                                    node_helper for MMM-ResRobot received a socket notification: CONFIG - Payload: {“updateInterval”:300000,“animationSpeed”:2000,“fade”:true,“fadePoint”:0.25,“apiBase”:“https://api.resrobot.se/v2/departureBoard?format=json&passlist=0",“apiKey”:“1c01e8b8-92d0-4e05-86dc-a112d743ba5a”,“routes”:[{“from”:“740000765”,“to”:“740000284”}],“skipMinutes”:0,“maximumEntries”:6,“truncateAfter”:5,“iconTable”:{“B”:"fa fa-bus”,“S”:“fa fa-subway”,“J”:“fa fa-train”,“U”:“fa fa-subway”,“F”:“fa fa-ship”}}
                                    Fetching new departure data for module: MMM-ResRobot
                                    node_helper for MMM-ResRobot received a socket notification: CONFIG - Payload: {“updateInterval”:300000,“animationSpeed”:2000,“fade”:true,“fadePoint”:0.25,“apiBase”:“https://api.resrobot.se/v2/departureBoard?format=json&passlist=0",“apiKey”:“1c01e8b8-92d0-4e05-86dc-a112d743ba5a”,“routes”:[{“from”:“740021656”,“to”:“740020749”}],“skipMinutes”:0,“maximumEntries”:6,“truncateAfter”:5,“iconTable”:{“B”:"fa fa-bus”,“S”:“fa fa-subway”,“J”:“fa fa-train”,“U”:“fa fa-subway”,“F”:“fa fa-ship”}}
                                    • AlvingerA
                                      Alvinger @Gailby
                                      @Gailby I copied your first config but used my API key and it worked with no issues at all.
                                      Verify that you are using the correct API key.
                                      The 400 status code is usually because you are using the wrong key.
                                      G 1 Reply Last reply
                                      • G
                                        Gailby @Alvinger
                                        @Alvinger Thanx a lot, that did it! I got confused about the english translation of “ResRobot - Pole Schedules 2” and used ResRobot - Reseplanerare. My Bad :/
                                        • AlvingerA
                                          Alvinger @Gailby
                                          @Gailby
                                          Great to hear! (Jag dokumenterade på engelska så alla kunde förstå men då blir ju svenskar lite förvirrade! :-)
                                          Maybe I should add the swedish name of the API key to the documentation as well.
                                          • A
                                            ayeball @Alvinger
                                            @Alvinger
                                            Re: [Problem with MMM-ResRobot]
                                            I have also problem with MMM-Resrobot . I use API-Key ResRobot - Stolptidtabeller 2. !
                                            I got it to work now but i get stockholm stations … And i have use “ejdergatan"740025622” to redbergsplatsen" 740025673" Göteborg .
                                            any idea? Kan svara på svenska också ;) Mvh
