    Problem with MMM-ResRobot, it wont start(?)
    31 Posts 7 Posters 18.9k Views 7 Watching
    • N Offline
      Nybbe67
      Re: MMM-ResRobot - Public transport information for Sweden
      Are there any problems now with MMM-ResRobot, I cant it to work at all?
      I have reinstalled it 2 times and configure it but the module don’t start at all, no errors, nothing on the screen.
      BR
      Niklas
        atd08001
        It works fine for me.
        //Andreas
        • N Offline
          Nybbe67 @atd08001
          @atd08001
          Can you post your ResRobot config, without your API key so I can test with yours?
            atd08001
            here is my ResRobot config.
            module: “MMM-ResRobot”,
            position: “left”,
            header: “Avgångar”,
            to: “740020749”,
            maximumEntries: 3,
            truncateAfter: 5,
            apiKey: “xxx-xx-xx-xx-xxxx”
            //Andreas
            N 2 Replies Last reply Reply Quote 0
            • N Offline
              Nybbe67 @atd08001
              @atd08001
              Thanks Andreas for fast respons. I will try it with your config.
              Niklas
              • N Offline
                Nybbe67 @atd08001
                @atd08001 Thanks alot. Found the problem, I have written MMM_Resrobot, not MMM-Resrobot.
                Its working!!
                • E Offline
                  Eburkis
                  does it work for you now ?
                  • N Offline
                    Nybbe67 @Eburkis
                    @Eburkis
                    Yes, its working, thanks
                    Best regards
                    Niklas
                    • E Offline
                      Eburkis
                      i cant get mine to work :/
                      • N Offline
                        Nybbe67
                        @Eburkis copy @atd08001’s config (above here) and replace your own, but use your own API key. Then it should work. My mistake was a typo, MMM_ResRobot, not MMM-ResRobot.
                        • 1 / 4
