    Garmin Connect Integration
    16 Posts 7 Posters 15.8k Views 10 Watching
      sameershah23
      Super cool. Would it be possible to create a step by step guide on how you accomplished this?
      I come from a non coding background, and hence I am not good with creating my own modules.
      Looks super cool !! Great work! :)
        d3r @scarri
        @scarri that’s pretty cool.
        I thought we had to pay to get access to the garmin api.
          scarri @d3r
          @d3r Here what you can and cannot do. Here the best URL than I found :
          http://charzam.com/20013/06/16/google-connect-api-rest
          I’m using into my module this :
          Public activities:
          http://connect.garmin.com/proxy/activitylist-service/activities/[USER GARMIN]?start=1&limit=10
            scarri @sameershah23
            @sameershah23
            Garmin iCal :
            go into the MagicMirror\config\config file and add this in the MODULES section:
            			module: 'calendar',
            			header: 'Garmin training',
            			position: 'top_left',
            			fetchInterval: 5000, // Update every 5 minutes.
            						symbol: 'heartbeat',
            						url: 'YOUR URL PROVIDE BY GARMIN CONNECT'
            then to get your iCal Garmin URL, go to Garmin Connect, go to Calender, on the upper right of the calender you should see a arrow buttom giving you 2 options : publish activities on you device or publish the calender. Choose “publish the calender” and copy this url into the url property of config section. And Done!
            Note from Moderator: Please use Markdown on code snippets for easier reading.
              scarri
              I just post my first node.js project “GarminActivities” here :
              https://github.com/scarri/MMM-GarminActivities
              It’s my first upload project to github. At this point, I don’t know yet how to do a git installation process…
              But the code is there.
              D 1 Reply Last reply Reply Quote 2
                d3r @scarri
                @scarri
                Hey, thanks for the module.
                I got the garmin training calendar to work but cannot get the activities history to work. Is the activities module config smilar to the training calendar one?
                What should I put as "userAccessToken and appAccessToken:?
                  scarri
                  Hi
                  First, i didn’t cleaned up my source code. At this point, userAccessToken and appAccessToken are useless.
                  But the way to get your activities history, make sure you have set the userGarmin variable, the one you use to log you in on garmin connect web site. And I think you have to set you activities “public” by PARAMETERS - “Privacy setting” section.
                  You can try with my garmin user : scarri77
                  All my activies are open to a public acces.
                  https://connect.garmin.com/proxy/activitylist-service/activities/scarri77?start=1&limit=10
                    d3r @scarri
                    Thank you.
                    I already had my garmin username in the config file but my garmin privacy settings were not public. It’s working now that I changed my garmin privacy to public.
                    • Z Offline
                      Zinkeler
                      @scarri said in Garmin Connect Integration:
                      Hi
                      Hey scarri,
                      I try to use it, but i don´t now what to write in “config.js”.
                      I tried:
                      module: ‘MMM-GarminActivities’,
                      header: ‘Fenix 3’,
                      position: ‘bottom_right’
                      but it don´t work.
                      In “MMM-GarminActivities.js” i added my userGarmin-ID.
                      If i send: “https://connect.garmin.com/proxy/activitylist-service/activities/[my userGarmin-ID]?start=1&limit=10” i get a correct Response.
                      Can you please send me your (anonymous) part of “config.js”?
                      Thanks Ralph
                        d3r
                        I think there might be an issue with the module. Mine doesn’t load anymore.
                        Maybe Garmin changed something on their side.
                          Pade2204
                          Any news of a Garmin Module? It would be kinda awesome :-)
                          • E Offline
                            enurgdk
                            Hello :)
                            Is there something news about the Module with Garmin Connect ?
                            I want it on my screen :)
                            That could be verry nice !
                            Hope someone can help !
                            :D
                            • E Offline
                              ericguimont
                              Yes, i could be verry nice!
