Hidden locked Weather shows up after some time
4 Posts 2 Posters 1.6k Views 1 Watching
  • T Offline
    trekky
    Hey,
    I developed a module MMM-ModuleToggle to hide other modules by sending a notification. The module is very basic it is using the MMM-Buttons module to trigger a Notification which hides or shows a module.
    The module is working for all other modules I am using except the currentweather and weatherforecast. These two system modules show up after some time when they are hidden.
    I already placed a lockString on the modules but the weather modules still show up. Is this the expected behaviour, a problem with the weather modules or did I miss something?
    Thank you for your help.
      Snille Module Developer
      Hi @trekky
      You are not the only one. The both the modules does not accept the hide.
      I have a topic on it here: https://forum.magicmirror.builders/topic/1312/solved-when-weather-updates-module-unhides
      But it seems not a lot of people have the problem. :)
      There is no solution as far as I know unfortunately.
      Best regards Erik
      If you cant find it, make it and share it!
      Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
      • T Offline
        trekky
        Hi @Snille,
        I couldn’t find your topic in my research otherwise I wouldn’t post the problem another time.
        It is good to know the problem is not in my module and I hope somebody has a solution for that.
        Best regards Tobias
        • T Offline
          trekky
          I found the issue in my module since the lockString was not set correct.
          It is working now correctly.
