    Hidden locked Weather shows up after some time
    4 Posts 2 Posters 1.7k Views 1 Watching
    • T Offline
      trekky
      Hey,
      I developed a module MMM-ModuleToggle to hide other modules by sending a notification. The module is very basic it is using the MMM-Buttons module to trigger a Notification which hides or shows a module.
      The module is working for all other modules I am using except the currentweather and weatherforecast. These two system modules show up after some time when they are hidden.
      I already placed a lockString on the modules but the weather modules still show up. Is this the expected behaviour, a problem with the weather modules or did I miss something?
      Thank you for your help.
      • SnilleS Offline
        Snille Module Developer
        Hi @trekky
        You are not the only one. The both the modules does not accept the hide.
        I have a topic on it here: https://forum.magicmirror.builders/topic/1312/solved-when-weather-updates-module-unhides
        But it seems not a lot of people have the problem. :)
        There is no solution as far as I know unfortunately.
        Best regards Erik
        If you cant find it, make it and share it!
        Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
        • T Offline
          trekky
          Hi @Snille,
          I couldn’t find your topic in my research otherwise I wouldn’t post the problem another time.
          It is good to know the problem is not in my module and I hope somebody has a solution for that.
          Best regards Tobias
          • T Offline
            trekky
            I found the issue in my module since the lockString was not set correct.
            It is working now correctly.
