    MMM-NokiaHealth (Withings)
    Scheduled Pinned Locked Moved Health
    26 Posts 7 Posters 17.6k Views 10 Watching
      rentaro
      Hmmmmm i see your predicament sir…
        petero-dk
        I am just airing one idea here:
        Using the https://github.com/node-pcap/node_pcap I should be able to setup a listener for Withings Scales (by either destination URL or MAC address) once a device is detected show the graph.
        Please feel free to share your thoughts on that? I do not know if this is too much for the MagicMirror to handle with pcap add-on. Perhaps this should be a separate plugin that can be reused for other device detections.
          rentaro
          had a look at the pcap add-on to be honest i think its going to be heavy for just a listener
          • zdenekZ Offline
            zdenek
            still doesn’t work for me. I’ve tried new Raspberry pi 3, clean install of NOOB, installed MM, updated everything. Installed just few modules (Simple logo and MMM-WunderGround) and Nokia. It connects to server, get the data, but just not to create the graph. as you can see, alt text, div is created, and in Dev console is no error and in seleted DIV are located data alt text
            Of course I ran npm install after installation of module Nokia.
            thanks for help, Zdeněk
              petero-dk
              I know, I know, I know, the use case is convoluted and it needs work work work.
              The graph will not display until a remote server flag is set. This was to avoid opening ports in the local network (which is not possible with me). The graph is supposed to only show when you have been on the scale (I am working on something that will make that user configurable, but time, ohhhh that missing time)
              For now, try manually from your phone or laptop or somewhere else calling:
              http://apps.ecomerc.com/nokiahealth/user.php?userid=[youruserid]&a=set
              That will set a server flag that the module will check in order to show the graph. The idea was you can use IFTTT to set the server flag and show the graph, this was the model because IFTTT has a trigger for Withings new measurement. This does not work because the IFTTT trigger has a delay of up to 15 minutes.
              zdenekZ 1 Reply Last reply Reply Quote 0
              • zdenekZ Offline
                zdenek @petero-dk
                @petero-dk thx, but now I’m confused even more. I did the trick with a=set and after start MM I can see the graph (there was somehting like “Values for…” but I’ve of course named ppl in the device) and small graph (need to resize, cause I can identify that the weight is between 50 and 100 kilos - this not enough to monitor the weight differences). Anyway, the graph after few secs disappeard and doesn’t start anymore. I tried restart MM (not the whole RP). So it’s not the same - in the DEV I can see values, no error, but on the screen no graph.
                btw, great job - everyone, who is able own module is for me like magic-man
                Zdeněk
                  petero-dk @zdenek
                  @zdenek You do not need to reset MM, just call the http://apps.ecomerc.com/nokiahealth/user.php?userid=[youruserid]&a=set and the graph will display for a few seconds.
                  When you want to see it again, call
                  (It is like a remote control for the graph) - yes I know it seems stupid but at the time it was a good idea, it will be changed completely
                  • zdenekZ Offline
                    zdenek @petero-dk
                    @petero-dk said in MMM-NokiaHealth (Withings):
                    oh, I’ve got it. So there is actually no way to display it permanently?
                    and is there way, how to change the scale? or zoom? I mean, to see graph from 0 to 100 kilos doesn’t give detailed info. Let imagine, your weight is 80 kilos and you know, it can be from 70 to 90 and you want to see just this range…
                    thanky
                      petero-dk @zdenek
                      @zdenek not yet, but next version for both things…
                      zdenekZ 1 Reply Last reply Reply Quote 1
                      • zdenekZ Offline
                        zdenek @petero-dk
                        @petero-dk I can’t wait for…thanks
                        • F Offline
                          fabbr
                          Any update on this? I would love to see the graphs from the Nokia Health
                            Bouba830
                            Hello
                            I cannot connect to retrieve the ID
                            I have the impression that the links no longer work!
                            can you help me ?
                            thank you ;)
                            • FoziF Offline
                              Fozi Project Sponsor @Bouba830
                              @Bouba830 try this https://github.com/kodymallory/MMM-withing. This module works. It can be a bit tricky to receive the token (step 7-9 in the installation description) as it has be done within 30 seconds, but keep repeating.
                                Bouba830 @Fozi
                                @Fozi merci mais erreur 404 :(
                                • FoziF Offline
                                  @Bouba830 Sorry missed the ‚s‘ at the end of the link. Here the corrected link
                                  https://github.com/kodymallory/MMM-withings
                                    Bouba830
                                    hello I have a problem, the address callback where have it found?
