    Sync private iCloud calendar with MagicMirror
    162 Posts 58 Posters 434.7k Views 65 Watching
      Beh
      A while ago, I posted a thread for syncing an iCloud calendar with MagicMirror. Unfortunately this solution was just a workaround and you needed to use a Mac which is also synced with your calendar. It was far from being a nice solution.
      I just found out that the tool I was using (vdirsyncer) also supports syncing with iCloud. I wrote a detailed walkthrough for this.
      I’ll re-post this part from the original post:
      Why doing it this way?
      I don’t want my calendar to be available via a public URL like mentioned in the iCloud calendar thread. Even though the public sharing address is quite long, web crawlers can still find them and your private life is publicly available. I just don’t like that scenario. So I wanted a solution that uses encryption and authentication against all services.
      So here’s a really nice solution to sync the mirror with iCloud (privately):
      Get app-specific password from iCloud
      vdirsyncer needs an app-specific password to connect to iCloud. You can create one in your AppleID settings like descibed in Apple’s support document for using app-specific passwords: https://support.apple.com/en-us/HT204397
      Create one and write it down for later.
      Install and set up vdirsyncer
      vdirsyncer needs to be installed on the machine that hosts your mirror software. On my raspbian system, vdirsyncer was not available via apt. So I hat to install it via pip.
      Installation of vdirsyncer
      Now we get vdirsyncer and it’s dependencies:
      sudo apt-get install libxml2 libxslt1.1 zlib1g python3
      pip3 install --user --ignore-installed vdirsyncer
      (This is the quick and easy way, it should suffice for most users. For a more clean way to install it, please refer to https://vdirsyncer.pimutils.org/en/stable/installation.html#the-clean-hard-way)
      Now, change the first line of your vdirsyncer executable to use only python3:
      nano ~/.local/bin/vdirsyncer
      And change the first line to #!/usr/bin/python3
      I needed to create a symlink to the vdirsyncer executable. So we’re doing this:
      sudo ln -s /home/pi/.local/bin/vdirsyncer /usr/bin/vdirsyncer
      Now you should be able to use the vdirsyncer command from the command line.
      Create a folder for the calendar file
      As mentioned in this post, we can put the calendar file into the modules folder to access it via the calendar module. So we create a folder for our calendars:
      mkdir /home/pi/MagicMirror/modules/calendars
      Configure vdirsyncer
      Create a config file in ~/.vdirsyncer/config and open it with nano:
      mkdir ~/.vdirsyncer
      touch ~/.vdirsyncer/config
      nano ~/.vdirsyncer/config
      Here’s an example configuration to use with iCloud. Just copy it into your opened file in nano and enter your iCloud credentials.
      # vdirsyncer configuration for MagicMirror.
      # Move it to ~/.vdirsyncer/config or ~/.config/vdirsyncer/config and edit it.
      # Run `vdirsyncer --help` for CLI usage.
      # Optional parameters are commented out.
      # This file doesn't document all available parameters, see
      # http://vdirsyncer.pimutils.org/ for the rest of them.
      [general]
      # A folder where vdirsyncer can store some metadata about each pair.
      status_path = "~/.vdirsyncer/status/"
      # CALDAV Sync
      [pair iCloud_to_MagicMirror]
      a = "Mirror"
      b = "iCloud"
      collections = ["HERE-GOES-THE-UUID-OF-THE-CALENDAR-YOU-WANT-TO-SYNC"]
      # Calendars also have a color property
      metadata = ["displayname", "color"]
      [storage Mirror]
      # We need a single .ics file for use with the mirror (Attention! This is really slow on big amounts of events.)
      type = "singlefile"
      # We'll put the calendar file to a readable location for the calendar module
      path = "/home/pi/MagicMirror/modules/calendars/%s.ics"
      [storage iCloud]
      type = "caldav"
      url = "https://caldav.icloud.com/"
      # Authentication credentials
      username = "YOUR-ICLOUD-EMAIL-ADDRESS"
      password = "HERE-GOES-YOUR-APP-SPECIFIC-ICLOUD-PASSWORD"
      # We only want to sync in the direction TO the mirror, so we make iCloud readonly
      read_only = true
      # We only want to sync events
      item_types = ["VEVENT"]
      # We need to keep the number of events low, so we'll just sync the next month
      # Adjust this to your needs
      start_date = "datetime.now() - timedelta(days=1)"
      end_date = "datetime.now() + timedelta(days=30)"
      Make sure, you use the start_date and end_date parameters to keep the number of calendar events low. I tried syncing with 700+ events and it is really really sloooooow! Especially when using the singlefile option for the mirror.
      Add your iCloud credentials like shown in the config file.
      Running vdirsyncer as a systemd.timer for automatic sync
      Install the vdirsyncer.service and vdirsyncer.timer files to /etc/systemd/user:
      curl https://raw.githubusercontent.com/pimutils/vdirsyncer/master/contrib/vdirsyncer.service | sudo tee /etc/systemd/user/vdirsyncer.service
      curl https://raw.githubusercontent.com/pimutils/vdirsyncer/master/contrib/vdirsyncer.timer | sudo tee /etc/systemd/user/vdirsyncer.timer
      By default, the syncer is started every 15 minutes. You can change it by configuring the times in the vdirsyncer.timer file:
      sudo nano /etc/systemd/user/vdirsyncer.timer
      Now we activate the timer in systemd:
      systemctl --user enable vdirsyncer.timer
      Let vdirsyncer discover the collections and do the inital sync
      Now, we have to find out, which collection we want to sync. Let vdirsyncer discover everything:
      vdirsyncer discover
      You should get an output like this (depending on the number of calendars you have in iCloud):
      Discovering collections for pair iCloud_to_MagicMirror
      Mirror:
      iCloud:
        - "25CB285C-E163-4E0E-B420-C3FB469B7C00" ("Calendar 1")
        - "9221FEE8-E8B4-4D07-9402-8638529919EC" ("Calendar 2")
        - "953A5477-E405-4ED6-A5C3-473444EACC95" ("Calendar 3")
      warning: No collection "HERE-GOES-THE-UUID-OF-THE-CALENDAR-YOU-WANT-TO-SYNC" found for storage Mirror.
      Should vdirsyncer attempt to create it? [y/N]:
      Choose N for now and press return.
      Now replace the HERE-GOES-THE-UUID-OF-THE-CALENDAR-YOU-WANT-TO-SYNC in the config with the UUID of the calendar you want to sync.
      We assume, we want to sync “Calendar 2”.
      So line 19 of your config should look like this:
      collections = ["9221FEE8-E8B4-4D07-9402-8638529919EC"]
      Now, we can run the discover again and make the first sync:
      vdirsyncer discover
      You should get something loke this:
      Mirror:
      iCloud:
      warning: No collection "9221FEE8-E8B4-4D07-9402-8638529919EC" found for storage Mirror.
      Choose y and press enter. Now we can start the sync with:
      vdirsyncer sync
      You should find a single calendar file in /home/pi/MagicMirror/modules/calendars/ with the UUID of your calendar as filename like 221FEE8-E8B4-4D07-9402-8638529919EC.ics in this example.
      Add the calendar file to the calendar module of the mirror
      Now, we just have to add the URL to the calendar file to our calendar module of the mirror like this:
          module: 'calendar',
          position: 'top_left',   // This can be any of the regions. Best results in left or right regions.
              maximumNumberOfDays: 10,
              maximumEntries: 7,
                              url: 'http://localhost:8080/modules/calendars/221FEE8-E8B4-4D07-9402-8638529919EC.ics',
                              symbol: 'calendar'
      If everything went well, your MagicMirror is now automatically syncing your iCloud calendar with it’s calendar module :)
      schwoediauerS G S kaiK 4 Replies Last reply Reply Quote 7
        spesh
        Does this allow the option for different icons for different calenders? I’m just starting to build mine and would like to sync two seperate iCloud calenders and have them display with different icons/colours
          Beh @spesh
          @spesh
          Yes, this should allow multiple coloured calendars.
          You just have to add the UUIDs for each calendar you want to sync to the collections array in your vdirsyncer config.
          This should create multiple .ics files. One for each calendar. Then you could add each calendar to your MagicMirror config and use the color option described in the default calendar module for your calendars. Just add the colored option to your “global” module config and add a color option to each calendar.
          A calendar config could look like this then (for “Calendar 1” and “Calendar 2” as described above):
              module: 'calendar',
                  colored: true,   // Activate coloring
                  maximumEntries: 7,
                          // "Calendar 1"
                                  url: 'http://localhost:8080/modules/calendars/25CB285C-E163-4E0E-B420-C3FB469B7C00.ics',
                                  symbol: 'calendar'
                                  color: '#123456'   // Assign color
                          // "Calendar 2"
                                  symbol: 'calendar'
                                  color: '#ABCDEF1'  // Assign color
          G A 2 Replies Last reply Reply Quote 0
            Doubleve
            hello how do we get the links calendars icloud thank you
              Beh @Doubleve
              @Doubleve What do you mean?
                Doubleve
                I will like my 3 calendars icloud but I do not see the links of the style
                https://p02calendars.icloud.com/published/2/xxxxxxxxxxxxxxxxxxxxxQhtoAvoFiIwGI1
                To have UUID
                  Beh @Doubleve
                  @Doubleve You don’t need these links, since vdircsyncer discovers your calendars automatically on iCloud and identifies them by their IDs.
                  It is explained in the “Let vdirsyncer discover the collections and do the inital sync” section of the walkthrough.
                  You mirror accesses the calendar saved to a file on your mirror.
                    Doubleve @Beh
                    @Beh error for discover
                    File “/usr/bin/vdirsyncer”, line 7, in
                    from vdirsyncer.cli import main
                    ImportError: No module named ‘vdirsyncer’
                    B F 2 Replies Last reply Reply Quote 0
                      Beh @Doubleve
                      @Doubleve Did you change the first line of the file to #!/usr/bin/python3 ?
                        Doubleve
                        everything is good
                        • L Offline
                          l0cal
                          That sounds good for me. Does it work with reminders on the same way?
                          B schwoediauerS 2 Replies Last reply Reply Quote 0
                            Beh @Doubleve
                            @Doubleve Hmmm…
                            Maybe you have to allow your localhost address to the MagicMirror ipWhiteList option in your config. Just add ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1"], to your config right before the modules option. Maybe the calendar module can not access the .ics file if this is not allowed…
                              Beh @l0cal
                              @l0cal Yes this should work.
                              Just add "VTODO" to the item_types array in your vdirsyncer config as described in the vdirsyncer docs here: https://vdirsyncer.pimutils.org/en/stable/config.html?highlight=VEVENT#storage-caldav.
                              • L Offline
                                l0cal @Beh
                                @Beh yeah that are good news for me.
                                in the last few weeks I was looking for a solution for it and I did not find anything
                                  ribermon
                                  I have a question
                                  So far I managed to sync one calendar from one iCloud account, but I would like to sync also a second calendar from a second iCloud account, is this possible?
                                  Ricardo
                                    Beh @ribermon
                                    Hey @ribermon!
                                    Yes, this should be possible. You just have to add another configuration scheme for your second icloud account to the vdirsyncer config. I didn’t try it, but something like that should work:
                                    [general]
                                    # CALDAV Sync for iCloud 1
                                    [pair iCloud1_to_MagicMirror]
                                    a = "Mirror_iCloud1"
                                    b = "iCloud1"
                                    [storage Mirror_iCloud1]
                                    type = "singlefile"
                                    [storage iCloud1]
                                    type = "caldav"
                                    read_only = true
                                    # CALDAV Sync for iCloud 2
                                    [pair iCloud2_to_MagicMirror]
                                    a = "Mirror_iCloud2"
                                    b = "iCloud2"
                                    [storage Mirror_iCloud2]
                                    type = "singlefile"
                                    [storage iCloud2]
                                    type = "caldav"
                                    username = "YOUR-ICLOUD2-EMAIL-ADDRESS"
                                    password = "HERE-GOES-YOUR-APP-SPECIFIC-ICLOUD2-PASSWORD"
                                    read_only = true
                                      ribermon @Beh
                                        ribermon @Beh
                                        @Beh I manage to discover the calendars from my second iCloud account but then I don’t manage to sync my calendars there, any idea, thanks
                                          Beh @ribermon
                                          @ribermon No I have no idea. But since this is actually a vdirsyncer-problem and has nothing to do with the mirror itself, I suggest you dig the vdirsyncer-Documentation:
                                            bgz
                                            Hi Beh
                                            Sorry if I´m too newbie… I´m following your step-by step and I get stuck in one place…
                                            When creating a config file, I type:
                                            and I get:
                                            Can´t do ‘touch’ on ‘/home/pi.vdirsyncer/config’: The file or directory doesn´t exist
                                            What am I doing wrong?
                                            Thanks.
                                            • 1 / 9
