    Calender module - icloud calender?
    17 Posts 11 Posters 27.1k Views 12 Watching
    • N Offline
      Notumlord
      I would like to use my GF’s icloud calender in the default calender module, is this possible since it seems to only accept .ical URL’s?
      I tried entering webcal://p24-calendars.icloud.com/published/2/ but the calender doesnt load.
      Is there any way to solve this or workaround?
        dgs
        Its work for me
        			module: 'calendar',
        			header: 'Icloud Calendar',
        			position: 'top_left',
        						symbol: 'calendar-check-o ',
        						url: 'https://p02-calendars.icloud.com/published/2/xxxxxxxxxxxxxxxxxxxxxQhtoAvoFiIwGI1-5MBbuND5g_96k2kQyqGV90wUFfxxxxxxxxxxx'
        Note from admin: Please use Markdown on code snippets for easier reading!
        • W Offline
          WeedWood
          Hey There, question: are there only public icloud calendar possible? i dont want to publish my calendar the whole world! :P
            azza_pazza @dgs
            @dgs hi, I’ve got the calendar coming up with ‘no upcoming events’ I’ve got 3 entries in my calendar for this week alone. Any reason this would be?
            • W Offline
              weberaccounts @WeedWood
              @WeedWood That’s what I’ve found.
              • F Offline
                fox
                So its not possible to include a private calendar from icloud?
                  slickric @fox
                  @fox said in Calender module - icloud calender?:
                  Mine displays an iCloud calendar with no problem.
                  • F Offline
                    fox @slickric
                    @slickric said in Calender module - icloud calender?:
                    How do you get the private calendar url?
                    • L Offline
                      lolobyte @fox
                      @fox
                      i think he mean’s a public calendar.
                      • F Offline
                        fox @lolobyte
                        @lolobyte said in Calender module - icloud calender?:
                        @fox
                        I think so. Public is working of course
                          slickric @fox
                          @fox sorry, it is technicially a “public” calendar. I shared it with myself and used that address. No one is going to be able to get access without that URL so I guess it depends on what you define public vs private.
                          • F Offline
                            fox @slickric
                            I have also a family calendar for wife and kids. But neither nor… only public is working.
                            But it is working and i think it is safe.
                            • C Offline
                              cohron
                              @Notumlord said in Calender module - icloud calender?:
                              webcal
                              Instead of webcal:// use http:// or try https://
                              mine worked with http://p07-calendarws.icloud.com/ca/subscribe/1/QWERQWERWERWERWQER
                              • C Offline
                                cohron @cohron
                                @cohron
                                Now it seems the calendar MMM are no longer loading my multiple icloud ics urls. it had been working for a couple of weeks and just stopped. My office365 is loading just fine. I know this is vague just need to figure out where to start looking.
                                • strawberry 3.141S Offline
                                  strawberry 3.141 Project Sponsor Module Developer @cohron
                                  @cohron https://github.com/MichMich/MagicMirror/issues/839
                                  • C Offline
                                    cohron @strawberry 3.141
                                    @strawberry-3.141 Strawberry, your friggin awesome for your involvement here. Unfortunately the ical.js and node-ical.js were not my problem. I did however solve my issue but not sure of the cause.
                                    The icloud calendars urls were no longer valid but still were active in icloud.com. I simply unmarked each calendar as public, clicked save, marked it again as public which generated a new url. A quick copy and paste of each one got the calendar working again. now if i can figure out why the url stopped working in the first place. Hopefully this wont happen again, but we will see.
                                    Also if you have a moment, im trying to figure out how to view the start up outputs where i could have seen each calendar trying to load and likely getting an error. is it in a log somewhere or a special way to start the app?
                                      Beh
                                      @fox @WeedWood
                                      You can use vdirsyncer to sync a private iCloud calendar with your mirror.
                                      I wrote a walkthrough here:
                                      https://forum.magicmirror.builders/topic/5327/sync-private-icloud-calendar-with-magicmirror
                                      @cohron: vdirsyncer can also sync multiple calendars from iCloud
