    Calender module - icloud calender?
    17 Posts 11 Posters 27.4k Views 12 Watching
      slickric @fox
      @fox said in Calender module - icloud calender?:
      So its not possible to include a private calendar from icloud?
      Mine displays an iCloud calendar with no problem.
      foxF 1 Reply Last reply
      • foxF
        fox @slickric
        @slickric said in Calender module - icloud calender?:
        How do you get the private calendar url?
        Issues With MMM-WatchDog known?
        https://forum.magicmirror.builders/post/29827
        Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
        lolobyteL 1 Reply Last reply
        • lolobyteL
          lolobyte @fox
          @fox
          i think he mean’s a public calendar.
          • foxF
            fox @lolobyte
            @lolobyte said in Calender module - icloud calender?:
            @fox
            I think so. Public is working of course
              slickric @fox
              @fox sorry, it is technicially a “public” calendar. I shared it with myself and used that address. No one is going to be able to get access without that URL so I guess it depends on what you define public vs private.
              • foxF
                fox @slickric
                I have also a family calendar for wife and kids. But neither nor… only public is working.
                But it is working and i think it is safe.
                  cohron
                  @Notumlord said in Calender module - icloud calender?:
                  webcal
                  Instead of webcal:// use http:// or try https://
                  mine worked with http://p07-calendarws.icloud.com/ca/subscribe/1/QWERQWERWERWERWQER
                  C 1 Reply Last reply
                    cohron @cohron
                    @cohron
                    Now it seems the calendar MMM are no longer loading my multiple icloud ics urls. it had been working for a couple of weeks and just stopped. My office365 is loading just fine. I know this is vague just need to figure out where to start looking.
                    • strawberry 3.141S
                      strawberry 3.141 Project Sponsor Module Developer @cohron
                      @cohron https://github.com/MichMich/MagicMirror/issues/839
                        cohron @strawberry 3.141
                        @strawberry-3.141 Strawberry, your friggin awesome for your involvement here. Unfortunately the ical.js and node-ical.js were not my problem. I did however solve my issue but not sure of the cause.
                        The icloud calendars urls were no longer valid but still were active in icloud.com. I simply unmarked each calendar as public, clicked save, marked it again as public which generated a new url. A quick copy and paste of each one got the calendar working again. now if i can figure out why the url stopped working in the first place. Hopefully this wont happen again, but we will see.
                        Also if you have a moment, im trying to figure out how to view the start up outputs where i could have seen each calendar trying to load and likely getting an error. is it in a log somewhere or a special way to start the app?
                        • BehB
                          Beh
                          @fox @WeedWood
                          You can use vdirsyncer to sync a private iCloud calendar with your mirror.
                          I wrote a walkthrough here:
                          https://forum.magicmirror.builders/topic/5327/sync-private-icloud-calendar-with-magicmirror
                          @cohron: vdirsyncer can also sync multiple calendars from iCloud
