    Synchronizing private iCloud calendar with MagicMirror - a Workaround
    4 Posts 2 Posters 7.9k Views 2 Watching
      Beh
      I found a solution how to automatically sync a private iCloud calendar to the magic mirror. It’s quite circuitous. And it’s more like a workaround, not a real solution.
      But since you can’t access a private iCloud calendar directly via any API or something similar, this is the only working solution I found.
      Maybe it’s helpful for one of you.
      Why?
      I don’t want my calendar to be available via a public URL like mentioned in the iCloud calendar thread. Even though the public sharing address is quite long, web crawlers can still find them and your private life is publicly available. I just don’t like that scenario. So I wanted a solution that uses encryption and authentication against all services.
      I’m using a shared calendar with my girlfriend via iCloud. I’d use my CalDAV server Baïkal for that, but the current version of the backend (sabre/dav) in Baïkal does not yet support calendar sharing (they’re working on it). So until then, we’re quite stuck with iCloud since all the other CalDAV servers I tried don’t satisfy me and I have good experiences with Baïkal.
      Preconditions
      You’ll need:
      • Computer running macOS
        • iCloud calendar synced in Calendar.app
      • vdirsyncer
      • A CalDAV server (I use Baïkal)
      • MagicMirror (of course)
      How it works
      The Calendar.app saves an .ics file for every calendar event to the hard drive. We can use these event files to use with vdirsyncer and synchronize them with a CalDAV server. So the sync chain would be like the following:
      iCloud < - > Calendar.app -> Filesystem -> CalDAV Server -> MagicMirror
      Steps
      Find the directory of the desired calendar
      macOS’ Calendar.app saves it’s calendar files in /Users/[USER]/Library/Calendars/.
      In this Folder you’ll find several folders with suffixes like .caldav and .calendar depending on your configuration. The folders should be identified by UUIDs. iCloud accounts should have a .caldav suffix.
      Every folder contains a Info.plist file on which you can identify the calendar of the CalDAV account. You just have to look for the one containing your iCloud ID.
      In this folder you can find subfolders with .calendar suffixes. These subfolders also contain an Info.plist file that should have information to identify the desired calendar.
      In the calendar folder is a Events folder that contains all the .ics files with your calendar events. This is the folder we’re looking for.
      CalDAV server
      I won’t explain how to install and set up a CalDAV server, you can use the one of your choice. I have good experiences with Baïkal, but other implementations like DaviCAL or radicale should work as well. You can read more about Baïkal on baikal-server.com oder Baïkals GitHub repo.
      I created an extra user for the mirror. We’ll use magicmirror for the rest of the tutorial.
      Install and configure vdirsyncer
      You can install vdirsyncer via Homebrew on macOS:
      brew install vdirsyncer
      You might want to start vdirsyncer on system startup so it syncs events automatically:
      brew services start vdirsyncer
      Here’s a sample configuration to sync with the CalDAV server:
      # An example configuration for vdirsyncer.
      # Move it to ~/.vdirsyncer/config or ~/.config/vdirsyncer/config and edit it.
      # Run `vdirsyncer --help` for CLI usage.
      # Optional parameters are commented out.
      # This file doesn't document all available parameters, see
      # http://vdirsyncer.pimutils.org/ for the rest of them.
      [general]
      # A folder where vdirsyncer can store some metadata about each pair.
      status_path = "~/.vdirsyncer/status/"
      # Synchronize all collections that can be found.
      # You need to run `vdirsyncer discover` if new calendars/addressbooks are added
      # on the server.
      # CALDAV
      [pair MyPairing]
      a = "Local"
      b = "Remote"
      collections = null
      # Calendars also have a color property
      metadata = ["displayname", "color"]
      # The storage name must be "Events", because it looks for it in the .calendar folder
      [storage Local]
      type = "filesystem"
      # This folder should not go to the Events folder but to the parent directory
      path = "/Users/YOURUSER/Library/Calendars/0b0e91ad-60d1-40e2-85cf-366b2ddb5f1b.caldav/63cf04c6-d391-41af-840c-4e4a4d2ed37b.calendar/Events/"
      fileext = ".ics"
      # This might be important, since you don't want vdirsyncer to change anything in the Calendar.app folder:
      read_only = true
      [storage Remote]
      type = "caldav"
      # "magicmirror" is the username!
      url = "https://baikal.example.org/dav.php/calendars/magicmirror/MYCALENDAR/"
      auth = "digest"
      username = "magicmirror"
      password = "YOURSTRONGPASSWORD"
      For further information about the config, please refer to the vdirsyncer documentation.
      You can discover the new files with the following command:
      vdirsyncer discover
      … and trigger a sync with this command:
      vdirsyncer sync
      When it’s successfully configured and running, vdirsyncer automatically synchronizes the content of the Events folder with the CalDAV server periodically.
      Use the default calendar module with the CalDAV server
      Just add your credentials to the MagicMirror configuration. If you want to use digest authentication (with Baïkal for example), you have to change the sendImmediately option in the calenderfetcher.js to false. You can find it here.
      If you use Baïkal or any other service that uses sabre/dav (like Nextcloud), you have to add the ?export option to the calendar URL as described in the CalDAV thread.
      Here’s an example URL for use with Baïkal:
      https://dav.example.org/dav.php/calendars/[username]/Events?export
      This URL returns an .ics file with the whole calendar containing all the events.
      I hope someone has use for this ;)
        Advokaten @Beh
        @Beh Thank you for this, wizard! I made my calendar public and also do not like that option, really. What I can see using my calendar is just the title and time until event will happen. What I’d also like to see is the ‘description’ I add to my events, for example “Work” as title and “07.00-16.00” as description. Would this be possible using this method? Before I venture on to try this I would like to see a picture on how this looks. Any chance of a visual? Thanks again.
          Beh @Advokaten
          @Advokaten
          The data will be transferred, since vdirsyncer synchronizes the whole calendar data (including description, location, time, title,…). So all the calendar data you enter in your iCloud account will be synchronized to your mirror.
          What you are asking depends heavily on the calendar module you are using on your mirror. I don’t think, that the default module supports this. So I think one needs to change stuff in the calendar module for this to work.
          So I think what you’re asking is not really related to the syncing itself. If you’re already using the default calendar module, you already know how it looks. I didn’t change a single thing on that regarding optics. So the look is 100% similar to the default calendar module.
            Beh
            To all future readers:
            I found a way better solution for this. You can check it out in this thread:
            https://forum.magicmirror.builders/topic/5327/sync-private-icloud-calendar-with-magicmirror
            /cc @Advokaten
