    Blank black screen | Noob
    44 Posts 12 Posters 62.5k Views 11 Watching
      Arod192
      Alright so I fixed the problem of the two instances opening but when I run ‘DISPLAY=:0 npm start’ It’s still blank.
      Any ideas on how to fix this? Like I said before it works when I use "node serveronly’
      • K Offline
        KirAsh4 Moderator
        Go back to the beginning. Move your current config.js to something else, like config.js.backup. Then grab the original config.js and try running that, see if it comes up.
        You only need to set the DISPLAY=:0 if you are connecting remotely.
          Arod192
          Did it using the sample config and renaming it to config.js. I still get a black screen, but if I do “node serveronly” with the same files it works in my browser.
          I’m getting no errors besides the “No helper found for module” (all of them)
          • K Offline
            KirAsh4 Moderator
            With the default config.js you get a blank screen when you try to run 'npm start' ? If so, what’s the hardware? Have you updated the OS? All variables.
              Arod192
              I used the automatic installer located here, https://github.com/MichMich/MagicMirror, and followed every step.
              I’m using a Raspberry Pi 3 Model B.
              I’m running Raspian Jesse 4.4, Node v4.4.3.
              The MagicMirror is up-to-date
              A K 2 Replies Last reply Reply Quote 0
                amanzimdwini @Arod192
                @Arod192
                THIS is the setup that worked GREAT for me:
                https://forum.magicmirror.builders/topic/236/complete-setup-tutorial
                (Surprised KirAsh4 did not mention it. Follow it step by step; first time around will take you 30 min, but after that you will fly through it). Work. It really does.
                • K Offline
                  KirAsh4 Moderator @Arod192
                  @Arod192, that’s a rather old version of node. When you run the automatic install from MM², it installs a more recent version automatically. You shouldn’t have to do that manually.
                  • K Offline
                    KirAsh4 Moderator @amanzimdwini
                    @amanzimdwini, I didn’t mention it … yet … because I like to figure out where the problem is, before I tell someone to start from scratch. :)
                    A 4 Replies Last reply Reply Quote 0
                      Arod192 @KirAsh4
                      @KirAsh4 Update Node.js and I’m still having the problem
                        Arod192 @KirAsh4
                        @KirAsh4 Okay I just changed the language from en to nl (just to see what’ll happen) and now it works!
                        But now everything is in the “nl” language but when I change it back to “en” the screen is black again
                          Arod192 @KirAsh4
                          @KirAsh4 Looks like all languages work but when I change the language to en I get a black screen
                            Arod192 @KirAsh4
                            @KirAsh4 Alright I think I fixed it. What I did was I went into the translations folder and I renamed en.js to en-us.js. After that I went into the config and changed en to en-us.
                              ronny3050 Module Developer
                              @Arod192 I can confirm this is a bug. Hardcoding ‘en’ in config.js causes black-screen, however, leaving it as ’ ’ or node serveronly runs fine.
                              • O Offline
                                overviewcs
                                noob here reporting same issue and same workaround works for me.
                                Exact Same issue and hardware and OS as poster. From a clean build, updated all before running MM auto installer as I thought I had made a mistake my first time around.
                                “used the automatic installer located here, https://github.com/MichMich/MagicMirror, and followed every step.
                                The MagicMirror is up-to-date”
                                server nodeonly -works
                                npm start -does not
                                changing ‘en’ to ‘’ in config.js works as a workaround. It will now open in electron.
                                • K Offline
                                  KirAsh4 Moderator
                                  Odd bug, as I have two different rpi 3s running just fine with 'en' as the value. This makes me wonder … can any of you paste the contents of your ‘/usr/share/X11/locale/’ folder?
                                  $ sudo ls -aF /usr/share/X11/locale/
                                    smithdsl
                                    Hey Everyone,
                                    I was have the same issue. Change from ‘en’ to ’ ’ now it works.
                                    @KirAsh4 this is my “locale” folder.
                                    pi@raspberrypi:~ $ sudo ls -aF /usr/share/X11/locale/
                                    ./            fi_FI.UTF-8/       iso8859-11/  iso8859-6/    ja.SJIS/      locale.dir         sr_CS.UTF-8/   zh_CN.gb18030/    zh_TW.UTF-8/
                                    ../           georgian-academy/  iso8859-13/  iso8859-7/    km_KH.UTF-8/  microsoft-cp1251/  tatar-cyr/     zh_CN.gbk/
                                    am_ET.UTF-8/  georgian-ps/       iso8859-14/  iso8859-8/    ko/           microsoft-cp1255/  th_TH/         zh_CN.UTF-8/
                                    armscii-8/    ibm-cp1133/        iso8859-15/  iso8859-9/    koi8-c/       microsoft-cp1256/  th_TH.UTF-8/   zh_HK.big5/
                                    C/            iscii-dev/         iso8859-2/   iso8859-9e/   koi8-r/       mulelao-1/         tscii-0/       zh_HK.big5hkscs/
                                    compose.dir   isiri-3342/        iso8859-3/   ja/           koi8-u/       nokhchi-1/         vi_VN.tcvn/    zh_HK.UTF-8/
                                    el_GR.UTF-8/  iso8859-1/         iso8859-4/   ja.JIS/       ko_KR.UTF-8/  pt_BR.UTF-8/       vi_VN.viscii/  zh_TW/
                                    en_US.UTF-8/  iso8859-10/        iso8859-5/   ja_JP.UTF-8/  locale.alias  ru_RU.UTF-8/       zh_CN/         zh_TW.big5/
                                    pi@raspberrypi:~ $
                                    Thanks.
                                    • K Offline
                                      KirAsh4 Moderator
                                      And in the EN_US.UTF-8 folder? Is there stuff in there?
                                        smithdsl
                                        pi@raspberrypi:/usr/share/X11/locale/en_US.UTF-8 $ ls -aF
                                        ./ …/ Compose XI18N_OBJS XLC_LOCALE
                                        • K Offline
                                          KirAsh4 Moderator
                                          Yeah that’s odd, it’s the same on mine, so you do have en_US locale installed on the rpi. But why is MM² failing for you, when it’s working fine for me, that’s a bit of a mystery. If you don’t mind, just for grins, would you care to run through only Step 2 in this post: https://forum.magicmirror.builders/topic/236/complete-setup-tutorial/4, specifically the Internationalization part.
                                          • MichMichM Offline
                                            MichMich
                                            This is a real strange situation. I tried it with different language setting, but none of them seem to cause an issue. (Even when using language: 'foobar', it just works fine.) Could one of you who is experiencing the bug, look in the developer’s console for any error messages?
