    MMM-GrafanaCharts and MMM-GrafanaGauges: Display you data with Charts and Gauges. Beautifully.
    29 Posts 13 Posters 30.4k Views 15 Watching
      planet4
      Regarding the black background I think it is solved. Maybe there was some kind of cache problem. After chaning the css files it looks perfect.
      SvenSommerS H 2 Replies Last reply
      • SvenSommerS
        SvenSommer @planet4
        @planet4 good news!
        Can you please share which CSS file, and what you edited?
        Looking for some building inspiration?
        Check out my large, thin and metal framed mirror on robstechlog.com.
        Modules released:
        MMM-GoogleAnalytics
        MMM-GrafanaChart
        MMM-GrafanaGauges
        • foxF
          fox
          Can i also show there other temperatures?
          Like temperatures from 1-wire Dallas sensor or from a http site?
          Issues With MMM-WatchDog known?
          https://forum.magicmirror.builders/post/29827
          Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
          SvenSommerS 1 Reply Last reply
          • SvenSommerS
            SvenSommer @fox
            @fox
            Short answer: No, not the direct way.
            Long answer: You need to write your temperature data into a database which is connected with Grafana. Then you can use this module to display your graph created by grafana.
            One possible solution: This tutorial shows an example, on how to store weather data from an external source in a local influxdb database, which is connected to grafana.
            You could reuse the example code an edit it, to get your data stored in a influxdb database.
            Modules released:
            MMM-GoogleAnalytics
            MMM-GrafanaChart
            MMM-GrafanaGauges
            foxF 1 Reply Last reply
            • foxF
              fox @SvenSommer
              @SvenSommer said in MMM-GrafanaCharts and MMM-GrafanaGauges: Display you data with Charts and Gauges. Beautifully.:
              @fox
              i will try your possible solution :) Thank you
              edit:
              thanks for sharing the link.
              I installed influxDB and grafana as written on your page.
              I also added the datasource to grafana.
              You mean i have to update this script?
              importForecast.js
              • SvenSommerS
                SvenSommer @fox
                @fox Yes, this script is responsible for getting the data into the database.
                If you would like to show other data with Grafana, you need to save the data you get from your sensor.
                Modules released:
                MMM-GoogleAnalytics
                MMM-GrafanaChart
                MMM-GrafanaGauges
                  sceletus
                  How do you manage credential to get access to grafana?
                  Thanks in advance.
                  • Y
                    yours.mukul
                    How to install Grafana? Does that debian work fine on rpi? I am confused since the architecture is different and I think the packages should be different as well.
                    I know its a very stupid question, but please help
                    • SvenSommerS
                      SvenSommer @yours.mukul
                      @yours.mukul
                      Yes just follow these instructions:
                      http://docs.grafana.org/installation/debian/
                      Modules released:
                      MMM-GoogleAnalytics
                      MMM-GrafanaChart
                      MMM-GrafanaGauges
                      • SvenSommerS
                        SvenSommer @sceletus
                        @sceletus
                        Enable authentication in the [http] section of the configuration file /etc/influxdb/influxdb.conf :
                        [http] enabled = true bind-address = ":8086" # change to a specific interface if needed auth-enabled = true # will enforce authentication
                        everything is described in the tutorial on http://robstechlog.com/2017/06/30/personal-weather-chart-module/
                        Modules released:
                        MMM-GoogleAnalytics
                        MMM-GrafanaChart
                        MMM-GrafanaGauges
                        • H
                          hunty1980 @planet4
                          @planet4 Are you able to provide steps on how you managed to update the CSS file to match the black background of the MM?
                          P 1 Reply Last reply
                            planet4 @hunty1980
                            @hunty1980 I used this guide https://forum.magicmirror.builders/topic/1675/graph-module/18
                              planet4
                              @SvenSommer Have not used this module for a while but have now reinstalled Grafana and would like to try it again. However I can not remember how to solve the login to Grafana. I think I opened it up as public the last time but is not an option now. At the moment the mirror just shows erroe as it can not login to the Grafana dashboard. Please advise.
                                planet4
                                I was able to solve the login issues but now its just black. Maybe this module does not work with the new version of Grafana?
                                • SvenSommerS
                                  SvenSommer @planet4
                                  @planet4 Hey, I just tried it with the actual Grafana v6.0.1 (commit: 0c44a04)
                                  It worked for me without any adjustments.
                                  Maybe I can support you, to set it up.
                                  Modules released:
                                  MMM-GoogleAnalytics
                                  MMM-GrafanaChart
                                  MMM-GrafanaGauges
                                    planet4 @SvenSommer
                                    @SvenSommer Thanks for replying. I was actually able to solve it but with version 6 of Grafana black background is more of a trouble. Wrote a short post about this as well.
                                    http://www.planet4.se/grafana-in-magic-mirror/
                                    I am now able to show my Solar production on my mirror. 0,36kW. Will post this in the show my mirror as well. Thanks.
                                    T 1 Reply Last reply
                                    • T
                                      teitlebot @planet4
                                      @planet4 thanks
                                      your post helped me half way
                                      im using home assistant to host grafana so i needed to create an org called home assistant.
                                        planet4
                                        @teitlebot I am using Home Assistant as well but Grafana is not used as an add-in on Hassio. I have it on a separate docker container. However I gave up Grafana in the end. It was to much problems. Now I use MQTT to get all information I want from Home Assistant to my Mirror. Like this:
                                        http://www.planet4.se/magic-mirror-info-via-mqtt/
                                        • T
                                          teitlebot @planet4
                                          @planet4 What other problems did grafana give you? I am also using the mmm hass component to pull in sensor date but maybe I will switch to mmm mqtt. I really wanted to show some nice graph though. Also how did you build the total solar energy sensor saving in hass? I build it in graphana following someones tutorial,
                                          • A
                                            andreasm80
                                            edit reposted to be in same thread…
                                            Have been using this module for a couple of years now without any problems. Yesterday I upgraded my Grafana server and discovered they had implemented a security change where you had to allow_embedded=true. After doing this change I was back on track again, except that I can only see my GrafanaGauges when I point my browser to my MagicMirror IP, it does not show up on the MM screen itself. I see it takes it places and all modules around aligns perfectly around it, but the content onscreen is blank/black. Have been troubleshooting everything from both Grafana side and MagicMirror side. It will not show up on the screen only when I point my browser to the MM, then I see the screen with all content as it should…
                                            Now I am clueless… Not sure if this is module-specific or content from Grafana that does it. My next step to try som iFrame modules to show the same content…
                                            Any ideas?
                                            Regards
                                            With your input, this post could be even better đź’—
