    How to MANUALLY install MM on your Pi. For absolute beginners.
    27 Posts 5 Posters 23.7k Views 5 Watching
    • slametpsS
      slametps @Mykle1
      @Mykle1 said in How to MANUALLY install MM on your Pi. For absolute beginners.:
      @slametps said in How to MANUALLY install MM on your Pi. For absolute beginners.:
      If I remove config.js, the MM display to create a config. Still no clue how to solve this.
      You did a manual install and ran npm install in the MagicMirror directory? He solved his problem by running npm install in the vendor directory. I don’t know if you have the same issue.
      But it seems to me if MM is reporting “Create a config” that MM is launching correctly. You could try getting a fresh copy of the config.js.sample (in case something is wrong with the one you have) and trying again.
      Good luck
      Yap, I just copy config.js from config.js.sample, and got a black screen.
      I will give a try, running npm install in vendor folder.
      regards,
      Slamet PS
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @slametps
        @slametps
        You didn’t answer my question.
        You didn’t try my suggestion.
        You did the one thing that I said I didn’t know was your issue.
        Shrug
        slametpsS 1 Reply Last reply Reply Quote 1
        • slametpsS
          slametps @Mykle1
          @slametps
          Shrug
          Yap, I install MM manually refers to documentation you wrote (and backed up current running MM 2.1.0).
          config. js I mentioned earlier, is a fresh copy from config.js.sample in config folder.
          I did npm-install in MM folder, but not in vendor yet. I’ll try later when I have access to my MM.
          regards,
          Slamet PS
          slametpsS 1 Reply Last reply Reply Quote 0
          • slametpsS
            slametps @slametps
            @slametps
            Shrug
            Finally, MM 2.1.3 was installed successfully by executing:
            cd /root/MagicMirror/vendor
            npm install /root/MagicMirror
            cd /root/MagicMirror/fonts
            npm install
            regards,
            Slamet PS
            axellejamousA 1 Reply Last reply Reply Quote 1
            • axellejamousA
              axellejamous @slametps
              @slametps glad you found it! you basically had the same issue as me except I didn’t have the fonts one. It’s really odd.
              • slametpsS
                slametps @axellejamous
                @axellejamous said in How to MANUALLY install MM on your Pi. For absolute beginners.:
                @axellejamous You should try:
                $ cd {your_magicmirror_folder}/fonts
                $ npm install
                it will install required fonts.
                regards,
                Slamet PS
                • axellejamousA
                  @slametps If you run it with npm start, does it work for you?
                  For me that only solved my issue if I run it with node serveronly.
                  Now there’s 0 errors so I have no clue why my screen still shows up black with npm start.
                  • slametpsS
                    Yap, it works like a charm now (also after I downgraded electron to 1.6.10 (1.7.9 consumes excessive CPU).
                    Firstly, I got the same issue. After I did what I mentioned earlier, it is OK now.
                    regards,
                    Slamet PS
                    • axellejamousA
                      @slametps Yeah had to do the same! But I downgraded to 1.7.9, so I’ll change it to 1.6.10 now thank you! :)
                      • slametpsS
                        Glad to hear that. I just realize an issue with language translations is not working in default modules such as current-weather. Is anyone here experience same issue?
                        regards,
                        Slamet PS
